john(at)fureychrysler.com Guest
Posted: Thu Jun 08, 2006 5:15 am Post subject: RV7 |
I have an RV7 QB kit on the way. I now have to decide on engine. I'm leaning towards TMX IO-360 with Roller tappets and Cold Air forward facing intake. I would appreciate any thoughts on carb-vs-injection, roller tappets, etc. TMX-vs-Superior-vs-Lycomming-vs-??? Have any of you exchanged the Vans cowl, wing tips, wheel pants for the Same James? If so what results did you get. Any input would be appreciated.
John Furey
jclarkmail(at)gmail.com Guest
Posted: Thu Jun 08, 2006 6:09 am Post subject: RV7 |
John,
I have been working with Will James getting the newer "short cowl" (same dimensions as Van's cowl but with the circular inlets) working on a "carbureted O-360". I wnated a different look (customization you know) and hoped there might be a little performance thrown in as a bonus.
I think I have the basics sorted out (there are a few little nuances to work out with the transition from the circular inlet to the Van's airbox) so contact me off-list if you decide to go that route.
I do not have any performance data as the plane is nowhere near flying (yet) but what I am hoping for is enough to offset the drag from the **nosegear** and **steps** that this plane will have.
BTW, Will and Liz have been very nice to work with on this effort. If I were not dragging my feet so much (fingers in too many pies) this plane would have flown a few YEARS ago!!
James
On 6/8/06, John Furey <john(at)fureychrysler.com (john(at)fureychrysler.com)> wrote: | Quote: | I have an RV7 QB kit on the way. I now have to decide on engine. I'm leaning towards TMX IO-360 with Roller tappets and Cold Air forward facing intake. I would appreciate any thoughts on carb-vs-injection, roller tappets, etc. TMX-vs-Superior-vs-Lycomming-vs-??? Have any of you exchanged the Vans cowl, wing tips, wheel pants for the Same James? If so what results did you get. Any input would be appreciated.
John Furey
This is an alternate email. Please continue to email me at james(at)nextupventures.com (james(at)nextupventures.com) .
martin(at)gbonline.com Guest
Posted: Fri Jun 09, 2006 6:28 pm Post subject: RV7 |
John,
I was one of the first users of the Sam James cowl and Plenum. It is designed around a fuel injection system with a forward facing air intake direct to the fuel injector. It is very efficient. You can expect at least a 10 knot increase over Vans standard setup. Also, it will cool much more efficiently. Consider installing your oil cooler behind cyl number 4 as high as possible and tilt back approx. 25 degrees for better performance.
Good Luck. I will look for you at one of the future Air Venture Cup races. I welcome the competition.
Dick Martin
N233M RV8
the fast one
