Posted: Tue Feb 26, 2013 4:22 pm Post subject: trouble with building Contactor 'Cooler' duty controller |
At 02:31 PM 2/26/2013, you wrote:
| Quote: | The contactor no longer does anything when wired thru the device, but it works fine without the device.
V across coil is 0
V at pin 5 after 10 sec. is 11.9 (supply V is 12.7) |
No, need the voltage at pin 3 . . . we need to
know if the critter is dropping into low duty
cycle.
You should see about 12v for a period of time
and then it should drop to 4 volts or so.
Bob . . . [quote][b]
Posted: Wed Feb 27, 2013 3:34 pm Post subject: trouble with building Contactor 'Cooler' duty controller |
At 05:15 PM 2/27/2013, you wrote:
| Quote: | Thanks ! Do you know how much electrical noise this circuit generates ?
All the best
Should be tolerably low. It won't have
any radio frequency issues and conducted
audio frequency noise onto bus is very
low compared with other noises (like
alternator ripple).
