Posted: Mon Feb 25, 2013 11:52 am Post subject: Audio Amplifier heads-up |
I've been working with some interesting
audio amplifier modules with very attractive
pricing and performance numbers for the bux.
They're generally described as 5v powered and
will often cite the ability to run off the USB
port of a computer.
http://tinyurl.com/ag3dey2
http://tinyurl.com/bdkt495
http://tinyurl.com/a7gdp3h
These are 'class D' audio amplifiers (switch mode
power supplies that audio rate modulation
response). I've found that they generally perform
as advertised.
I've found that they're sensitive to the output
impedance of the power supply with respect to
internally generated white nose. Further, they're
not two whippy when it comes to rejection of noise
on the 5v line. Noises on a USB supply port
can vary widely from one computer to the next with
lap-tops being the least likely to offer adequately
conditioned power for these devices.
Further, loud passages in program material will drive
the amplifiers into unstable operation that cause
one to grate their teeth. I've found that a LARGE
capacitor (like 10,000 uF) really tames them down
. . . alternatively, an array of ni-mh cells floated
across the power line work just as well . . . and
makes the amplifier portable.
Just a heads up. Class D is one 'wave of the future'
for not-quite hi-fi audio applications. The prices
and performance are attractive . . . but there
are integration issues the user should be aware of.
If you are already, or plan to fiddle with
these critters, I'd be pleased to compare notes
either here on the List or privately.
Posted: Mon Feb 25, 2013 12:50 pm Post subject: Audio Amplifier heads-up |
audio amplifier modules with attractive
[img]cid:7.1.0.9.0.20130225143836.010c1030(at)aeroelectric.com.0[/img]
port of a computer.
power supplies modulated at audio rates).
I've found that they generally perform as
advertised. Very efficient. I'm presently
listening to some ambient music at pleasant
levels where the two speakers draw an average
of 20 milliamps total at 4v (80 mW power input
to the system).
not too whippy when it comes to rejection of noise
the amplifiers into unstable operation that gives one
pause for the gnashing of teeth. I've found that a LARGE
Just a heads-up. Class D is one 'wave of the future'
If plan to or already are fiddling with
26.66 KB |
2619 Time(s) |
enginerdy(at)gmail.com Guest
Posted: Mon Feb 25, 2013 1:51 pm Post subject: Audio Amplifier heads-up |
Have you taken a look at the output RFI? Or is it reasonably well filtered in your test PCB? With the highly susceptible nature of some flying widgets, I'm curious what your take is.
Daniel
On Feb 25, 2013, at 2:46 PM, "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
[quote] I've been working with some interesting
<fd7795a.jpg>
port of a computer.
to the system).
ceengland7(at)gmail.com Guest
Posted: Mon Feb 25, 2013 2:03 pm Post subject: Audio Amplifier heads-up |
Posted: Mon Feb 25, 2013 6:01 pm Post subject: Audio Amplifier heads-up |
At 03:42 PM 2/25/2013, you wrote:
| Quote: | | Have you taken a look at the output RFI? Or is it reasonably well filtered in your test PCB? With the highly susceptible nature of some flying widgets, I'm curious what your take is. |
Not yet. The current application is terrestrial.
I will explore that characteristic in due course.
Bob . . . [quote][b]
