		g-iani(at)ntlworld.com Guest
				 Posted: Fri Jan 13, 2006 11:35 am    Post subject: Nylaflow OK for Monowheel? |
				Ron
 Just got round to reading your e-mail and it night help for you to know the
 following.
 The black tube supplied by Europa is 6mm, not 1/4 inch.  It is this size
 because that is the correct size for the master cylinder fitting.  The
 fittings used at the wheel cylinders are the 1/4 inch (you can get them from
 A/C Spruce) and they do seal with the 6mm pipe (but it is easy to pull the
 tube out of the fitting).
 The 1/4 Nylaflow is very good and is now standard on the finger brake
 trigear which uses a different master cylinder with 1/4 connections.
 I understand that it is difficult/impossible to get a good seal to the mono
 and foot brake trigear master cylinder/s with the 1/4 inch tube.
 Ian Rickard  #505 G-IANI XS Trigear
 Europa Club Mods Rep (Trigear)
 e-mail mods(at)europaclub.org.uk
    or direct g-iani(at)ntlworld.com
		gcrowder2
  Joined: 09 Jan 2006 Posts: 136 Location: Golden, Colorado USA
				 Posted: Fri Jan 13, 2006 12:31 pm    Post subject: Nylaflow OK for Monowheel? |
				I didn't like the brake feel with the Nylaflow tubing on my monowheel.
 I switched to the steel braided hose and improved the brake force
 to the brake noticeably.  With the Mono, you need all the brake force
 you can muster!
                                       Glenn
  	  | Quote: | 	 		  From: "G-IANI" <g-iani(at)ntlworld.com>
 Reply-To: europa-list(at)matronics.com
 Subject: RE: Nylaflow OK for Monowheel?
 Date: Fri, 13 Jan 2006 19:34:51 -0000
 Ron
 following.
 from
		mikenjulie.parkin(at)btop Guest
				 Posted: Fri Jan 13, 2006 3:46 pm    Post subject: Nylaflow OK for Monowheel? |
				Glen,
 I fitted a stick mounted master cylinder to my mono.  It is really good and
 has all the braking power necessary. One finger is all that is necessary.
 I can recommend the stick mounted brake - the only drawback is - no brake
 available to the right seat.  Not a problem for me really, I don't trust
 many people with my aircraft anyway.
 regards,
 Mike.
		gcrowder2
				 Posted: Fri Jan 13, 2006 7:47 pm    Post subject: Nylaflow OK for Monowheel? |
				Hey Mike!
   I also have a stick mounted brake lever with a cable going to the master
 cyl on the
 firewall.  Maybe I would change over to the way you are doing it.  Which
 master cyl
 and brake handle setup are you using?  Thanks!
                                     Glenn
 [quote]From: "Mike Parkin" <mikenjulie.parkin(at)btopenworld.com>
 Subject: Re: Nylaflow OK for Monowheel?
 Date: Fri, 13 Jan 2006 23:44:55 -0000
 Glen,
 regards,
 Mike.
		scrimm
  Joined: 09 Jan 2006 Posts: 81 Location: Gilbert, SC   SC99
				 Posted: Fri Jan 13, 2006 8:23 pm    Post subject: Nylaflow OK for Monowheel? |
				Pictures....please
 Steve Crimm
 N42AH
 A058
  _________________ Steve Crimm
N42AH |
				 Posted: Sat Jan 14, 2006 2:55 am    Post subject: Nylaflow OK for Monowheel? |
				Glen,
 Contact M. Bastien at Mdoaircraft(at)aol.com
 M. Bastien is French operates from Biarritz I think.  His Brake
 Caliper/master cylinder is first class, with built in handbrake.  I am very
 pleased with it.  Ivan Shaw flew with the system installed, and he thought
 it was excellent.  They are not cheap though.
 regards,
 M Parkin (GJULZ)
		Dan Bish
				 Posted: Sat Jan 14, 2006 11:52 am    Post subject: Nylaflow OK for Monowheel? |
				I second that request please.
 Dan
 Kit A144 - N914RB
 Tucson, AZ, USA
 [quote]--
  _________________ Kit A144 - N914RB
Mono, 914F
About 40% done, CM finished, most controls, tower, tailplanes, etc. Working on wing incidence and landing gear. |
