The Harbor Freight 2 Ton Shop Crane
jeff(at)westcottpress.com
PostPosted: Fri Feb 15, 2013 1:49 pm    Post subject: The Harbor Freight 2 Ton Shop Crane Reply with quote
.. now on sale for 162.99
Disclaimer clearly states "not for aircraft use"
I'll take my chances.
Jeff Carpenter
40304
 Filesize:  93.31 KB
 Viewed:  3544 Time(s)
Kelly McMullen
PostPosted: Fri Feb 15, 2013 4:42 pm    Post subject: The Harbor Freight 2 Ton Shop Crane Reply with quote
So only use it to pick up engines, not aircraft. Wink
On Fri, Feb 15, 2013 at 2:48 PM, Jeff Carpenter <jeff(at)westcottpress.com (jeff(at)westcottpress.com)> wrote:
[quote]... now on sale for 162.99
Jeff Carpenter
40304
Kelly McMullen
A&P/IA, EAA Tech Counselor
KCHD
flying-nut(at)cfl.rr.com
PostPosted: Fri Feb 15, 2013 4:51 pm    Post subject: The Harbor Freight 2 Ton Shop Crane Reply with quote
The lawyers are taking over. I buy paint stripper .... brand name 'Aircraft Stripper'. The small print: 'Not for use on aircraft'. So sad.
Linn
On 2/15/2013 7:41 PM, Kelly McMullen wrote:
[quote]So only use it to pick up engines, not aircraft. Wink
Jeff Carpenter
40304
Checked by AVG - www.avg.com
02/15/13 [b]
robin(at)PaintTheWeb.com
PostPosted: Fri Feb 15, 2013 5:18 pm    Post subject: The Harbor Freight 2 Ton Shop Crane Reply with quote
I wrote three different a cheeky replies to this email and deleted them all. My restraint is improving!
Robin
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Linn
Sent: Friday, February 15, 2013 4:51 PM
Subject: Re: The Harbor Freight 2 Ton Shop Crane
Linn
Jeff Carpenter
40304
02/15/13
==============[/b][/quote] V10-List Email Forum -[/b][/quote] >[/b][/quote] :p>[/b][/quote] /o:p>[/b][/quote] tor?RV10-List">http://www.matronics.com/Navigator?RV10-List[/b][/quote] ==============[/b][/quote] bsp; - MATRONICS WEB FORUMS -[/b][/quote] :p>[/b][/quote] tp://forums.matronics.com[/b][/quote] ==============[/b][/quote] bsp; - List Contribution Web Site -[/b][/quote] e> bsp;   -Matt Dralle, List Admin.[/b][/quote] bution">http://www.matronics.com/contribution[/b][/quote] ==============[/b] [b]
johngoodman
PostPosted: Sat Feb 16, 2013 6:34 am    Post subject: Re: The Harbor Freight 2 Ton Shop Crane Reply with quote
Two Ton Crane? I thought they were One Ton Cranes - 2000 pounds.
