M-14P engine and Install Parts for Sale
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> M14PEngines-List
Jeffd
PostPosted: Mon Feb 11, 2013 8:46 am    Post subject: M-14P engine and Install Parts for Sale Reply with quote
M-14P, Series II engine and parts for Sale:
• M-14P Engine, Series II, 300 hours since overhaul, original logbook, includes Western Fittings Kit and Skytronics alternator/regulator. $13,750.
• M-14 Exhaust System, stainless steel, made in USA, includes gaskets. $1375.
• MT Prop Adapter. Adapts Western style flat flange prop to the standard serrated M-14 propshaft. $275.
• Petersen 5 Gallon Oil Tank modified for use with the M-14 engine. Includes mounting brackets, Kimball on/off oil valve, silicone pad heater, oil temp probe fitting, scavenge oil return fitting, custom vent fittings, calibrated dipstick/cap assembly. $500.
• Kimball Air Start Components: Compressed air storage bottle with aux fill fitting, pressure guage, valve manifold with start valve, dump valve and safety valve. $350.
• Kimball Prop Governor Cable Bracket. $45
• Kimball Intake Manifold Drain Kit. $80
• Kimball Prop Governor “Wheel”. $30
• Start Coil. $100
• M-14 Engine Guages, made by UMA, specifically color marked for the M-14: 2.25” tach and tach generator, $120. 1.25” oil pressure, oil temp, volts and CHT, $60 each.
Engine and parts were recently removed in good working order from a flying aircraft
For info or photos mail / call me at jdair(at)sbcglobal.net / 913 634 8531
- The Matronics M14PEngines-List Email Forum -
http://www.matronics.com/Navigator?M14PEngines-List
dab(at)froghouse.org
PostPosted: Mon Feb 11, 2013 12:40 pm    Post subject: M-14P engine and Install Parts for Sale Reply with quote
I'm getting into a project that's designed for an M14P engine. Having
yet collected no parts firewall forward, this could be ideal and I may
be interested in everything. I'm also trying to come up to speed on
these engines so I have a few questions.
First is about the prop adapter. A guy at Barrett Precision Engines last
summer at Oshkosh showed me what the splined propflange looked like. I
assume that's what you mean by the serrated M-14 propshaft. I thought
the MT prop attached directly to that though, and didn't need an adapter.
The prop governor bracket and prop governor wheel, I'm not sure what
those are all about? Are they generally useful or specific to the
installation this engine came out of?
Does the engine include the carburetor? The prop governor? Is it missing
other bits that I should be asking about but haven't thought of?
You mentioned pictures and those would be good.
-Dave
• Start Coil. $100
dsavarese0812(at)bellsout
PostPosted: Mon Feb 11, 2013 1:06 pm    Post subject: M-14P engine and Install Parts for Sale Reply with quote
I'll do my best to answer the questions. They will be within your email
in ALL CAPS.
Dennis
A. Dennis Savarese
334-285-6263
334-546-8182 (mobile)
www.yak-52.com
Skype - Yakguy1
assume that's what you mean by the serrated M-14 propshaft. NO, THAT IS NOT TYPICALLY FOUND ON THE M14P ENGINES. THE SERRATED PROP ADAPTER IS ACTUALLY A PROP FLANGE. BOTH THE MTV PROP AND THE ORIGINAL RUSSIAN PROP HUB ATTACH TO THE PROP FLANGE. thought the MT prop attached directly to that though, and didn't need an adapter.
installation this engine came out of? THE PROP GOVERNOR WHEEL THAT KIMBALL'S SELLS IS A BLESSING, ESPECIALLY FOR NEW INSTALLATIONS, WHEN SETTING THE GOVERNOR HIGH PITCH AND LOW PITCH RANGE.
Does the engine include the carburetor? YES IN MOST CASES. The prop governor? YES, IN MOST CASES. Is it missing other bits that I should be asking about but haven't thought of? ANYTHING ATTACHED TO THE ACCESSORY CASE, LIKE MAGNETOS, AIR COMPRESSOR, TACH DRIVE, AIR START DISTRIBUTOR, GENERATOR OR ALTERNATOR. ALSO YOU SHOULD BE PREPARED TO SPEND A COUPLE OF THOUSAND ON A GOOD SLIP JOINT EXHAUST SYSTEM. CHECK WITH THE KIMBALLS IN FLORIDA FOR THIS.
-Dave
> • Start Coil. $100
mark.bitterlich(at)navy.m
PostPosted: Mon Feb 11, 2013 1:22 pm    Post subject: M-14P engine and Install Parts for Sale Reply with quote
One minor addition to make this even more confusing:
Dennis, correct me on the terminology if you would please.
When ordering a new prop for the M-14P engine from MP, you can NOW specify whether it will mate to the original Russian "flange" (as it were), or to the Western type of prop mount. So if you NOW order a new prop now from MT, you can tell them what it will mount to in which case no adapter will be needed period.
However, if you desire to mount an older MT prop that has a Western style mount to a Russian style "serrated flange" you are going to need the prop adapter mentioned by Dennis.
At some point of time, M-14 engines, usually PF models, became available with the Western style of prop mount. How these engines were designated, I am not sure.
Mark Bitterlich
p.s. I hope I have all this correct, as I have only worked on all the above, never owned it all!
PostPosted: Mon Feb 11, 2013 2:06 pm    Post subject: M-14P engine and Install Parts for Sale Reply with quote
Mark is correct. If you happen to purchase an M14 with the western prop
mount, you won't need the adapter for the MTV prop. However, based on my
experiences with the new Whirlwind Scimitar blades installed in the V530
hub, the performance improvements over the Russian paddle prop are quite
noticeable and closely match the climb performance of an MTV prop
installed on an M14P.
The Whirlwind W530 blades are carbon fiber. No wood core. Weights of the
blades are virtually identical due to the fact they are made in a mold.
Cost is about $6K for the blades. Add about $1500 for an overhauled V530
Russian hub and an additional $1500 for the Whirlwind spinner and for
half the price of the MTV 9, you'll see about the same or better
performance. Just my 2 cents.
A. Dennis Savarese
334-285-6263
www.yak-52.com
Skype - Yakguy1
Mark Bitterlich
tigeryak18t
PostPosted: Mon Feb 11, 2013 3:10 pm    Post subject: M-14P engine and Install Parts for Sale Reply with quote
Not counting the lifetime and overhaul of an MT prop!!!
And this is not 2 cents !!
Didier
2013/2/11 A. Dennis Savarese <dsavarese0812(at)bellsouth.net>:
noticeable and closely match the climb performance of an MTV prop installed
on an M14P.
blades are virtually identical due to the fact they are made in a mold. Cost
is about $6K for the blades. Add about $1500 for an overhauled V530 Russian
hub and an additional $1500 for the Whirlwind spinner and for half the price
of the MTV 9, you'll see about the same or better performance. Just my 2
cents.
A. Dennis Savarese
334-285-6263
www.yak-52.com
Skype - Yakguy1
> WD" <mark.bitterlich(at)navy.mil>
> needed period.
> am not sure.
> Mark Bitterlich
Didier Tiger YAK18T
Member of Commemorative Air Force
French Wing
PostPosted: Mon Feb 11, 2013 4:34 pm    Post subject: M-14P engine and Install Parts for Sale Reply with quote
200% correct Didier!
Dennis
A. Dennis Savarese
334-285-6263
www.yak-52.com
Skype - Yakguy1
Didier
> on an M14P.
> cents.
> A. Dennis Savarese
> 334-285-6263
> www.yak-52.com
> Skype - Yakguy1
>> needed period.
>> am not sure.
>> Mark Bitterlich
Etienne Verhellen
PostPosted: Mon Feb 11, 2013 5:51 pm    Post subject: Dragging the French CAA to Court ... NOT A GOOD IDEA Didier Reply with quote
Dragging the French CAA into Court ... NOT A GOOD IDEA Didier Twisted Evil
Hello Didier ! Very Happy
Have just read in 'Aviation & Pilote' (Numero 469 - Fevrier 2013)
that a member of your association A.P.P.A.R.
http://www.net1901.org/association/ASSOCIATION-DE-PILOTES-PROPRIETAIRES-DAVIONS-RUSSES-APPAR,980665.html
Mr Dominique LUCAS
http://wonder-wings.fr/index.php?part=13
wants to drag the French CAA (DGAC) into Court Twisted Evil
L'APPAR veut ester en justice.
NOT a good idea Exclamation My 2 cents Exclamation
https://www.sia.aviation-civile.gouv.fr/dossier%5Caicfrancea%5CAIC_A_2012_08_FR.pdf
https://www.sia.aviation-civile.gouv.fr/dossier%5Caicfrancea%5CAIC_A_2012_08_EN.pdf
Temporary Registration (F-WRxx) have been issued, like this one for instance to Jacques PESCHEL (Andernos) : F-WRUM to RA-1808K
http://www.planecheck.com?ent=da&id=16085
http://www.planecheck.com/eu/image.asp?Imgname=16085/img011094172923.jpg
http://tagazous.free.fr/affichage2.php?img=20360
Mr Benoit PINON and Thomas IACONO from the French CAA are trying to help !
If you guys think it will 'help' to drag these two gentlemen into court ... GOOD LUCK Rolling Eyes
 Filesize:  236.99 KB
 Viewed:  14514 Time(s)
Yak-50 Display Pilot - Airshows - Яковлев Як-50
Yak-52 training anywhere - FI(A) Aerobatic Instructor - Specialised Yak-52.
https://www.yakoteam.com/
https://www.yakovlevs.com/the-team/pilots-and-crew/
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> M14PEngines-List All times are GMT - 8 Hours
