nuckollsr(at)cox.net Guest
Posted: Sat Jun 03, 2006 9:05 am Post subject: Second battery in a TC aircraft |
At 10:36 AM 6/1/2006 -1000, you wrote:
>Bob,
>Please note the two attached drawings (and also please excuse my style).
>I have a Republic Seabee, and I want a dual battery system with the
second battery being always hot, feeding the Hot Battery Bus through a
circuit breaker. The purpose of this battery is to provide power for
things like bilge pumps, anchor light, clocks, and occasionally a GPS
(which has an anchor dragging alarm) without creating the possibility of
discharging the main starting battery.
>I have a single alternator (B&S) that I would like to use to charge both
batteries through a battery charging isolator.
>I might also add a battery parallel switch to allow the hot battery to
serve as a backup battery, but since it is the one that is most likely to
run down, I may eliminate that concept, at least until I gain some experience.
>My question for you is: Do you see any regulatory, operational, or
electrical problems with this arrangement? I think it should work well,
though I don't know if the FAA has any opinions on battery isolator diodes.
>Both batteries are Odyssey PC 1200s of about 40 AH rating.
Don't make this any more complicated than it needs to be. You'll have
to get a 337 approval for the installation of the second battery. FAA
will have no heartburn about the second battery but you'll want your
337 to touch on structural, and crash safety issues.
I don't recommend diodes. Just add a second battery to the system
with it's own battery contactor. You can use either or both batteries
for cranking. The battery bus for the second battery can run gizmos
cited in your note as long as each gizmo is under 5A. This is the
largest always-hot wire the FAA blesses under their rule-of-thumb
for max size of protected wire for crash safety. If you can get
a fuse-block blessed . . . so much the better. Fuses are MUCH faster
and therefore safer than breakers.
Battery bus for second battery needs to be mounted right at the
battery . . . so fuse-blocks work out well.
Here's a Shop Note on dual battery installation in all metal
airplanes.
http://aeroelectric.com/articles/Battery_Grounds/Battery_Grounds.html
Second battery is wired per Z-30 of
http://aeroelectric.com/articles/Rev11/AppZ_R11G.pdf
I've helped a half dozen or so folks install this same system in
things like C-206 on floats. We put the second battery right on
the aircraft CG inside one of the floats. Kept the battery from
using up fuselage volume and simplified crash safety issues.
I wish I could point you to a completed 337 for guidance
but all the installations I worked were for missionaries
and other bush operations in S. America. One pretty much
accomplishes what's necessary to their airplane without
government impediments.
( Experience and common sense cannot be )
( replaced with policy and procedures. )
( R. L. Nuckolls III )
markacarey(at)msn.com Guest
Posted: Fri Jun 09, 2006 12:14 pm Post subject: Second battery in a TC aircraft |
Bob:
I installed a single No. 2 positive wire from the firewall to the tail in my
RV10. I have dual alternators (40 and 20 A B&C) and dual batteries. The
alternators both feed to the firewall connection with 40 amp in-line fuses.
I am using the No. 2 to charge both batteries and have installed a diode to
allow the standby battery to charge while not allowing it to discharge
unless the standby contactor is closed. You said you don't recommend diodes
but it appears you have one shown in Z-14. Your diode appears to allow the
standby alt. to charge the main battery whereas the diode I have in mind
charges the standby battery. Any thoughts??
| Quote: | From: "Robert L. Nuckolls, III" <nuckollsr(at)cox.net>
Reply-To: aeroelectric-list(at)matronics.com
Subject: Second battery in a TC aircraft
Date: Sat, 03 Jun 2006 12:02:03 -0500
>Bob,
experience.
airplanes.
