Avionics Wire Lister?
billp(at)wwpc.com
PostPosted: Fri Feb 08, 2013 12:46 pm    Post subject: Avionics Wire Lister? Reply with quote
What started out as a little project has gathered mass as it's rolled
along. Go figure...
Has anyone come up with a tool to help with wire listing? Add this unit
and that unit and let you connect the pins and come up with a wire list?
I have seen one from Visual Engineer Inc but I kind of think it's aimed
at people that rewire 2 or 3 Gulfstream's a week. There must be a one
off home built version.
Any thoughts?
Bill
fvalarm(at)rapidnet.net
PostPosted: Fri Feb 08, 2013 1:55 pm    Post subject: Avionics Wire Lister? Reply with quote
Like a pen and paper?
Bevan
billp(at)wwpc.com
PostPosted: Fri Feb 08, 2013 2:17 pm    Post subject: Avionics Wire Lister? Reply with quote
Yeah, like that.
I've got about 8 things that have to wired together and I don't have
enough floor space to lay out all the sheets. Smile
Bill
Bevan
jay(at)horriblehyde.com
PostPosted: Mon Feb 11, 2013 2:43 am    Post subject: Avionics Wire Lister? Reply with quote
I simply put it all down on a spreadsheet. We use a program called EPLAN at
work for this but its very expensive. For the small size of our stuff a
spreadsheet works just fine, and you can tailor the list to suit your needs-
and sort it any way you want to.
It feels like a bit more work at first but it really pays back later when
you are trying to figure out what circuit wire !(at)#$%^&(at) belongs to! Smile
Jay
HH Enterprises
• Supply and installation of top class water filters
for your best drinking experience!
• Aircraft assembly, repair, wiring and avionics
• Flight instruction
• General and Electrical Engineering services
               (NHD Elec Eng, BTech Elec Eng, GDE ELec Eng)
• Great dinner parties and conversation
• General adventuring, climbing, kayaking and living
Blog: www.rawhyde.wordpress.com
Cel: 083 300 8675
Email: jay(at)horriblehyde.com
billp(at)wwpc.com
PostPosted: Mon Feb 11, 2013 9:01 am    Post subject: Avionics Wire Lister? Reply with quote
There's just so much typing all those pin assignment names in. I usually
can cut and paste those but the Garmin manual pdf's I have are copy
protected. Sad
Bill
Jay
HH Enterprises
Cel: 083 300 8675
harley(at)AgelessWings.co
PostPosted: Mon Feb 11, 2013 9:13 am    Post subject: Avionics Wire Lister? Reply with quote
Bill....
Do a screen print (the PRT SCR key) of the appropriate page in the pdf, then copy it into your favorite graphic editing program (Open the program, then CTRL-V...Irfanview for me) then copy and paste what you need from there.
Harley
On 2/11/2013 12:00 PM, Bill Putney wrote:
[quote]I usually can cut and paste those but the Garmin manual pdf's I have are copy protected. Sad
Bill [b]
james(at)etravel.org
PostPosted: Mon Feb 11, 2013 1:49 pm    Post subject: Avionics Wire Lister? Reply with quote
Hi Bill,
What would this bit of software do?  I'm not sure I understand the concept here.  Are you able to write down a few sentences for what the requirement is?  I ask as a software developer who's just finished a contract.
James
On 8 February 2013 20:44, Bill Putney <billp(at)wwpc.com (billp(at)wwpc.com)> wrote:
[quote]--> AeroElectric-List message posted by: Bill Putney <billp(at)wwpc.com (billp(at)wwpc.com)>
What started out as a little project has gathered mass as it's rolled along. Go figure...
Has anyone come up with a tool to help with wire listing? Add this unit and that unit and let you connect the pins and come up with a wire list?
I have seen one from Visual Engineer Inc but I kind of think it's aimed at people that rewire 2 or 3 Gulfstream's a week. There must be a one off home built version.
Any thoughts?
Bill
ric-List" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List
MS -
e -
billp(at)wwpc.com
PostPosted: Mon Feb 11, 2013 2:37 pm    Post subject: Avionics Wire Lister? Reply with quote
Well... If I were king, it would have a list of equipment (i.e. SL30, KX125, Aspen EDF1000,...) and I could pick the ones that wanted. The software would list all the pins and let me highlight (select) pins and click "Connect" and when I was all done, it would output a wire list. Of course it would be nice to be able to edit the list too. If it did checking like not letting me tie incompatible pins together and making sure there is at lease one source pin for whatever sinks there are. If it put out schematic (or single line) drawings that would be cool too.
That's all. Smile
Bill
On Feb 11, 2013, at 1:47 PM, James Kilford <james(at)etravel.org (james(at)etravel.org)> wrote:
[quote]Hi Bill,
James
Any thoughts?
Bill
MS -
e -
st">http://www.matronics.com/Navigator?AeroElectric-List
cs.com
dalemed
PostPosted: Tue Feb 12, 2013 8:50 am    Post subject: Re: Avionics Wire Lister? Reply with quote
<snip>
Jay
Can you show us what the spreadsheet looks like? An image would be worth a thousand words.
Dale
Dale
Zenith Zodiac CH650
PostPosted: Thu Feb 14, 2013 8:24 am    Post subject: Avionics Wire Lister? Reply with quote
I have attached a short pdf shot of my spreadsheet; the left most column is
for the wire numbers; the next column is for any connector that I may have
(I use barrel connectors and a variety of DB connectors that I then give
codes numbers/ names to). The last column describes the circuit that the
wire may be found in. You could add a 'from' and 'to' column, but I think
that that is overkill- all you need is the circuit that the wire is
associated with and then it's easy to find on your diagram.
I always find that you allocate all the numbers in sequence and its all neat
and organised, and then the client, or you, remembers something that needs
power and your neat sequence is all messed up. And that makes finding the
wire numbers very difficult, hence this list.
Jay
HH Enterprises
Cel: 083 300 8675
WiresLegendExample.pdf
 Filename:  WiresLegendExample.pdf
 Filesize:  29.46 KB
 Downloaded:  537 Time(s)
