finishing kit ommisions
cjhukill(at)cox.net
PostPosted: Fri Jun 09, 2006 7:57 am    Post subject: finishing kit ommisions Reply with quote
I just sent Barb at Vans a list of the items to omit from my finishing kit. I  previously had her send me an inventory list of the kit, so I knew what was there. As I want to leave my options open for a James cowl, I omitted the cowl top, bottom, left/ right inlets, oil door and core, and all the spinner parts (7 items). I also omitted the tires and tubes, as I like the leakguard tubes and better tires. If anyone wants the actual part numbers of the cowl / spinner parts to omit, I would be happy to fax the list, and save you and Vans the trouble.
Chris Hukill
completing Andair installation
702 591-7551 cel
Tdawson(at)avidyne.com
PostPosted: Fri Jun 09, 2006 8:17 am    Post subject: finishing kit ommisions Reply with quote
I bet if you scan the list, Tim O will be happy to post it on his website . . .
TDT
40025
FF
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Chris Hukill
Sent: Friday, June 09, 2006 11:58 AM
Subject: finishing kit ommisions
Chris Hukill
702 591-7551 cel
Tim(at)MyRV10.com
PostPosted: Fri Jun 09, 2006 9:02 am    Post subject: finishing kit ommisions Reply with quote
Absolutely. Then everyone can just look it up.
I did some updating today of the paint tips to include something sent to
me by Rick Sked, regarding where to paint the cabin if you're getting
Abby's interior: http://www.myrv10.com/tips/painting.html
Also, just got some air-to-air photos posted from last night.
http://www.myrv10.com/N104CD/flights/20060608/index.html
website . . .
TDT
40025
FF
[mailto:owner-rv10-list-server(at)matronics.com] *On Behalf Of *Chris Hukill
*Sent:* Friday, June 09, 2006 11:58 AM
*To:* rv10-list(at)matronics.com
*Subject:* finishing kit ommisions
Chris Hukill
702 591-7551 cel
rvbuilder(at)sausen.net
PostPosted: Fri Jun 09, 2006 9:48 am    Post subject: finishing kit ommisions Reply with quote
Here is the IO-540 & Finish kit contents.  I don't have the stuff crossed out but it is basically what Chris listed below.  I plan on putting together a list of exclusion items based on my engine config once I get to that point.  My engine is the BPA IO-540-X with the cold air induction.  I will be using the special James cowl (for the cold air induction) and also their plenum.
Michael Sausen
RV-10 #352 Working on Fuselage
Recent RV-10 Build Activity
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Tim Dawson-Townsend
Sent: Friday, June 09, 2006 11:16 AM
Subject: RE: finishing kit ommisions
TDT
40025
FF
Chris Hukill
702 591-7551 cel
Finish_Kit_and_IO-540_FF.pdf
 Filename:  Finish_Kit_and_IO-540_FF.pdf
 Filesize:  242.59 KB
 Downloaded:  239 Time(s)
etekberg(at)gmail.com
PostPosted: Fri Jun 09, 2006 10:29 am    Post subject: finishing kit ommisions Reply with quote
Is that a 300hp engine?  Is that fuel injected?  Can you use that cowling with fuel injection?  Are you concerned with exceeding Van's Vne at altitude?  Sorry for all the questions, just trying to learn.
Eric Ekberg
RV-10 583 - Empennage
On 6/9/06, RV Builder (Michael Sausen) <rvbuilder(at)sausen.net (rvbuilder(at)sausen.net)> wrote:
Michael Sausen
From: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com) [mailto: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)] On Behalf Of Tim Dawson-Townsend
TDT
40025
FF
From: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com) [mailto:owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)] On Behalf Of Chris Hukill
Chris Hukill
702 591-7551 cel
Tim(at)MyRV10.com
PostPosted: Fri Jun 09, 2006 10:35 am    Post subject: finishing kit ommisions Reply with quote
For those who get the digest version, and for other references,
I've added Michael's file here:
http://www.myrv10.com/tips/kits/index.html
along with other kit parts lists I've had posted there.
Back-up one level for the tips index:
http://www.myrv10.com/tips/index.html
If anyone ever has any updates to contribute, that would be
great. It would be nice to have someone's packing list
info for all the various kits shipping today.
Michael Sausen
<http://www.mykitlog.com/display_project.php?project_id=22>
[mailto:owner-rv10-list-server(at)matronics.com] *On Behalf Of *Tim
Dawson-Townsend
*Sent:* Friday, June 09, 2006 11:16 AM
*Subject:* RE: finishing kit ommisions
website . . .
TDT
40025
FF
Chris Hukill
702 591-7551 cel
PostPosted: Fri Jun 09, 2006 12:48 pm    Post subject: finishing kit ommisions Reply with quote
  It’s the 260HP Lycoming IO-540 “experimental” engine.  No real mods to it other than 9-1 pistons and Allen’s cold air induction.  Don’t forget Lycoming offers a, more expensive and heavier, cold air induction so this really isn’t anything out of the ordinary.  The “I” in IO-540 means it is fuel injected.  I will have the Airflow Performance FMS-300 injector system and dual  Lightspeed III electronic ignition which are also very popular in the experimental world.
  Will James is making two different cowls for the RV-10.  One fits the stock 540 and the other fits the 540 with the cold air induction.  They both will fit on injected engines but the plenum may need a tiny bump in the top for the AFP purge valve.
  VNE isn’t an issue for me.  For one I am probably going to do a three blade MT prop and for two I have the go fast/slow knob to keep me from breaking the speed of light.  As for HP, we will see.  I seriously doubt it will be  anywhere close to 300HP.  Especially with the chastising Allen give's me about using dual LSE III ignitions.  He sees better HP out of mags on the dyno.  Smile
Michael Sausen
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Eric Ekberg
Sent: Friday, June 09, 2006 1:29 PM
Subject: Re: finishing kit ommisions
Eric Ekberg
Michael Sausen
TDT
40025
FF
Chris Hukill
702 591-7551 cel
gorejr(at)bellsouth.net
PostPosted: Thu Jun 15, 2006 2:38 pm    Post subject: finishing kit ommisions Reply with quote
Chris,
If you would fax me a list I would appreciate it. I am also planning on using James wheel pants. Thanks again! 770-412-0540
Date: 2006/06/09 Fri AM 11:58:26 EDT
Chris Hukill
702 591-7551 cel
PostPosted: Thu Jun 29, 2006 9:48 am    Post subject: finishing kit ommisions Reply with quote
Chris,
Could you please re-fax the list of the things you are going to omit. Just got the laptop working again! I am going to get wheel pants from James also. I saw them at Lakeland. Thanks!!! Jim Gore
Chris Hukill
702 591-7551 cel
