Tail Wheel Needed
jareds(at)verizon.net
PostPosted: Tue Jan 29, 2013 10:57 am    Post subject: Tail Wheel Needed Reply with quote
A hard landing seems to have damaged the tail wheel and it doesnt want
to lock in place to allow steering.
i'm guessing if i took the time to take it apart i could follow the
diagram i have and get replacement parts.
B ut n the meantime i would like to consider fixin it later and getting
a spare so i can concentrate on the other aspects of getting it running.
Any ideas on aftermarket or used options?
henrysfork1(at)msn.com
PostPosted: Tue Jan 29, 2013 11:14 am    Post subject: Tail Wheel Needed Reply with quote
If is the original they are very easy to fix. There is a small pin that locks in place that is easy to replace. Takes about 10 minutes to fix it.
Dee Young
Model 2
N345DY
Date: Tue, 29 Jan 2013 12:56:08 -0600
Subject: Kitfox-List: Tail Wheel Needed
--> Kitfox-List message posted by: jareds <jareds(at)verizon.net>
Any ideas Archive Search & Download, 7-Day Browse, Chat, FAQ,
&gt========================
PostPosted: Tue Jan 29, 2013 11:26 am    Post subject: Tail Wheel Needed Reply with quote
Awesome.. well i will try to tackle it ... Is it a pin that can be bought or picked from my roll pin supply or hardware store or ordered from kitfox..
Dee Young
Model 2
N345DY
> From: jareds(at)verizon.net (jareds(at)verizon.net)
> To: kitfox-list(at)matronics.com (kitfox-list(at)matronics.com)
> Subject: Tail Wheel Needed
> --> Kitfox-List message posted by: jareds <jareds(at)verizon.net> (jareds(at)verizon.net)
[/b]
lcfitt(at)sbcglobal.net
PostPosted: Tue Jan 29, 2013 11:39 am    Post subject: Tail Wheel Needed Reply with quote
I have a maul tailwheel that I would let go - make a ridiculous offer. If
you are looking new aftermarket, I would recommend one of the Home builders
Special tailwheels from aircraft Spruce. I have owned both the two arm and
the single arm versions and liked them both. One thing, though as I went to
the site to look at them again. The bearings as they come from the
manufacturer are not sealed and are nearly impossible to lubricate. The
bearings they sell are sealed and very easy to replace.
Lowell
Sent: Tuesday, January 29, 2013 10:56 AM
To: "kitfox-list matronics.com" <kitfox-list(at)matronics.com>
A hard landing seems to have damaged the tail wheel and it doesnt want to
B ut n the meantime i would like to consider fixin it later and getting a
vetdrem
PostPosted: Tue Jan 29, 2013 4:11 pm    Post subject: Re: Tail Wheel Needed Reply with quote
I have a pdf file of an excellent article about the care and feeding of a Maule tail wheel,
I have attached it here.
Louie
Maule_Tailwheel.pdf
 Filename:  Maule_Tailwheel.pdf
 Filesize:  828.14 KB
 Downloaded:  1247 Time(s)
wb2ssj(at)rochester.rr.co
PostPosted: Wed Jan 30, 2013 3:35 am    Post subject: Tail Wheel Needed Reply with quote
I would like to see the infomation you have. Please foward to
Wb2ssj(at)rochester.rr.com
Thank You Tex
