Tapered Top Cowl Pins
Greg McFarlane
PostPosted: Tue Jan 22, 2013 4:21 am    Post subject: Tapered Top Cowl Pins Reply with quote
Here is a quick easy way to allow the 120 top pins to be used to retain that nice fit and stop the cowl ballooning. Place a piece of hardwood about 10 inches long in a vice. Using a CUTTING disc on a 4inch grinder make a straight shallow cut the length of the wood then mark a line across the wood 7inches from one end. Cut the pins to length, hold one end in an electric drill and have an assistant operate the drill at about 1000rpm, hold the rotating pin with one hand on the wood groove and with the other hand a 4 inch grinder with a GRINDING disc. GENTLY and EVENLY apply the grinder to the first 6inches of the pin using the mark on the wood as a guide. Check the diameter as you go, when about 100 discard the assistant and using the drill yourself sand the pin smooth. Sand the end of the pin per plans to give a nice lead in.The pin needs only to be tapered for about 6inches and that allows it to enter and go around the curve in the hinge nicely and keeps everything nice and snug. Cheers from Western Australia
Tim Olson
PostPosted: Tue Jan 22, 2013 5:36 am    Post subject: Tapered Top Cowl Pins Reply with quote
I like it! I'm going to use that on my next cowl, and maybe
even replace my pins with ones like that on my -10.
Hopefully I can do a good job on that pin though, as I can
tell it's going to take a steady hand and some focus.
On 1/22/2013 6:21 AM, Greg McFarlane wrote:
<grbcmcfarlane(at)gmail.com>
the hinge nicely and keeps everything nice and s! nug. Cheers from
Western Australia
http://forums.matronics.com/viewtopic.php?p=392870#392870
toaster73(at)embarqmail.c
PostPosted: Tue Jan 22, 2013 6:22 pm    Post subject: Tapered Top Cowl Pins Reply with quote
Great, I just might give that a go.
-Chris
N919AR
