PLBs
davidjoyce(at)doctors.org
PostPosted: Sat Jan 12, 2013 9:05 am    Post subject: PLBs Reply with quote
I have recently heard that the gendarmes have fined
someone over 900 euros for flying in to Le Touquet without
a PLB. When I last heard, I understood that a PLB was
compulsory for a certified aircraft but not for a Permit
aircraft. Can any of our French friends tell me what is
the current law?
Cordialement, David Joyce, G-XSDJ
Remi Guerner
PostPosted: Sun Jan 13, 2013 1:51 am    Post subject: Re: PLBs Reply with quote
Hi David,
Attached is the official publication regarding ELT and PLBs requirements in France. The yellow highlighted lines say : « all aircraft must carry an ELT or PLB except for CNRA, CDNR, CNRAC, CNSK et ULM » . That means that french homebuilts, orphans and microlights are not required to carry a PLB or ELT. So the question is whether or not a foreign Permit aircraft is to be considered as an equivalent of one of those french restricted certificates. I am afraid the answer depends on the gendarme ! To any Europa pilot who would be tentatively fined in France for not carrying a PLB I would suggest to say : « this is a kit built aircraft equivalent to a french CNSK. Therefore, according to Arrêté du 26 mars 2008 I am not required to carry a PLB or ELT ».
That said I believe having a PLB on board is a good thing.
Remi Guerner
F-PGKL
Arrêté du 26.03.2008, Balises 406 MHz.doc
 Filename:  Arrêté du 26.03.2008, Balises 406 MHz.doc
 Filesize:  36.5 KB
 Downloaded:  311 Time(s)
PostPosted: Sun Jan 13, 2013 2:39 am    Post subject: PLBs Reply with quote
Remi, Many thanks . You are a star! David Joyce, G-XSDJ
On Sun, 13 Jan 2013 01:51:40 -0800
Hi David,
PLB or ELT ».
thing.
Remi Guerner
F-PGKL
http://forums.matronics.com/viewtopic.php?p=392159#392159
http://forums.matronics.com//files/arrt_du_26032008_balises_406_mhz_109.doc
Un/Subscription,
Forums!
Admin.
