rv10free2fly(at)yahoo.com Guest
Posted: Sat Jan 05, 2013 3:44 am Post subject: GTS-800 Upper TCAS Antenna Installation - Another Option |
For those that are interested, we just completed installing the upper TCAS antenna which needs to be mounted to as near as level as practicable, inclusive of a ground plane. We elected to make up a foam moulding which we covered with resin and cloth to suit the shape of the cabin top and of sufficient size to mount the antenna using nut plates.
We placed a layer of tissue cloth and resin down over the cabin top before mounting the antenna plinth on the cabin top to seal the top as we found the cabin top to be porous when we trialled a vacuum bag over the plinth moulding
