Light reading
rickofudall
PostPosted: Mon Dec 31, 2012 7:39 pm    Post subject: Light reading Reply with quote
A neighbor of mine suggested a NACA report about simplified propeller design written by Fred Weick (designer of the Ercoupe, among other work) and while I was searching the database I found the attached report. Given the thick wing and the testing of both tractor and pusher configurations I thought some of you might enjoy it, too.
Rick Girard
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
  - Groucho Marx
TR_196_Wind_Tunnel_Tests_of_Several_Tractor_and_Pusher_Propeller_Wing_Extension_Shaft_Arrangements.pdf
 Filename:  TR_196_Wind_Tunnel_Tests_of_Several_Tractor_and_Pusher_Propeller_Wing_Extension_Shaft_Arrangements.pdf
 Filesize:  1.69 MB
 Downloaded:  905 Time(s)
Thom Riddle
PostPosted: Tue Jan 01, 2013 8:28 am    Post subject: Re: Light reading Reply with quote
Rick,
I finally got through it. Interesting reading. Thanks for posting.
I don't recall ever seeing an airplane with wing mounted engine and extension shaft, either pusher or tractor, but there probably are some. The BD-5 comes to mind for fuselage mounted pusher with extension shaft.
Thom Riddle
Buffalo, NY (9G0)
- Anonymous
