Not mass balanced ailerons & cable failure
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Aviation-List
SteveJeff
PostPosted: Sat Dec 29, 2012 3:50 am    Post subject: Not mass balanced ailerons & cable failure Reply with quote
I found that many certified LSA aircrafts and some standard FAR 23 certified don't have mass-balanced surfaces, especialy ailerons. I'm interested in how they are designed to show freedom from flutter, especially control surface flutter and if these aircrafts can handle a disconnected freefloating aileron emergency (due to cable failure, for example).
If they are not prone to develop flutter in normal operation, how things may change if, for example, the aileron cable fails?
The limited speed of LSA is a big factor to avoid flutter in normal operation, so it may not be necessary to have mass-balanced surfaces. In normal operation, the aircraft was flight tested for flutter and also in normal service there were no flutter occurences.
However, the question is, how things change in a cable failure in these aircrafts? Even if it's a very rare occurence, from time to time cables may fail. I'm wondering especially about an aileron cable failure, when the aileron is disconnected and freefloating, how prone is to flutter? In this scenario, is it at risk to (violently) flutter?
As about FAR 23 aircraft, for example, American Champion series (Scout, Citabria..) have no mass-balanced surfaces, especially ailerons.
I hope it wasn't too hard to follow my post, I'm sorry, I was a bit in a hurry writing it. Thank you so much!
- The Matronics Aviation-List Email Forum -
http://www.matronics.com/Navigator?Aviation-List
Griswald3
PostPosted: Thu Feb 06, 2014 8:30 pm    Post subject: Re: Not mass balanced ailerons & cable failure Reply with quote
Thanks for the post!
garryd
PostPosted: Wed Jan 13, 2016 3:29 am    Post subject: Re: Not mass balanced ailerons & cable failure Reply with quote
Great to know info about not mass balanced ailerons & cable failure...
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Aviation-List All times are GMT - 8 Hours
