bmwr606(at)yahoo.com Guest
Posted: Sun Jan 13, 2013 12:50 am Post subject: AeroElectric-List Digest: 9 Msgs - 01/12/13 |
piper meridians come from the factory with an anderson connector for charging the main battery
batteryminder sells a model of their charger specifically for the meridian with a mating anderson connector
i have used the meridian as data to get the faa to approve similar installations on type certified aircraft,
similarly, i have used beech a36s using anl current limiters as data to install anls in type certified aircraft, eliminating the expensive and large alternator circuit breaker from the instrument panel when rewiring older aircraft or replacing a failed alternator circuit breaker
scott
Scott A Klemptner
bmwr606 on Yahoo IM
The difference between genius and stupidity is that genius has its limits- Anonymous
Time: 11:42:08 AM PST US
From: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)>
Subject: AeroElectric-List: Anderson PowerPole connectors
I don't know if we've talked about these folks
on the List before . . . but I ran across an current
application where these connectors appear a great
alternative to knife-splices and perhaps even the
Molex/Tyco-Amp white nylon connectors.
I've uploaded a data package for the Anderson PowerPole
connectors to this page on my website:
http://tinyurl.com/cbe2t87
On that page you will also find installation instructions,
tools, and a link to the factory outlet where you can
buy any quantity of housings, pins and accessories
at reasonable prices.
Do a Google on Anderson Powerpole and you'll no doubt
discover many other sources for this unique product
line.
