frank goodnight
Posted: Thu Dec 27, 2012 7:02 am Post subject: more ? from a new 701 driver |
[img]cid:1356618760900(at)dclient.mail.yahoo.com[/img] Can some one tell me the technique to use when
practicing departure stalls. MY 912 books tell me not to
exceed 40 degrees from level , due to oil concerns.
At 4,800 RPM I don't think I am getting a stall if i can't go
more vertical than that. The A/C just seems to want
shutter a little then settle into a mushy decent. I haven't tried a fast or whip stall where centrifical force holds
the oil where it's supposed to be.I don't suppose that
would be a departure stall anyway . My approach stalls
are as expected. 1,800 RPM raise the nose and bleed the
airspeed untill the nose falls through no special wing drop.
When the ball is centered it's smooth and predictable.
Thanks for any info.
Frank Goodnight
About 2 hrs in 701
12.03 KB |
2533 Time(s) |
john.marzulli(at)gmail.co Guest
Posted: Thu Dec 27, 2012 9:54 am Post subject: more ? from a new 701 driver |
Also above 40degs the float bowls start sending tons of fuel out of the return line.
I found the critical angle to be about 50degs and that was using some acceleration first and full elevator trim.. A power-on stall is very hard to achieve. Practice them with partial power.
Good luck!
John Marzulli
http://MarzulliPhoto.net/
http://701Builder.blogspot.com/
On Thu, Dec 27, 2012 at 7:02 AM, frank goodnight <frank.goodnight(at)att.net (frank.goodnight(at)att.net)> wrote:
| Quote: | [img]cid:1356618760900(at)dclient.mail.yahoo.com[/img] Can some one tell me the technique to use when
Frank Goodnight
About 2 hrs in 701
12.03 KB |
2527 Time(s) |
