ashuramj(at)hotmail.com Guest
Posted: Mon Jun 05, 2006 8:05 pm Post subject: Panasonic LC-RD1217P and Van's Battery Box Misfit |
I just received my new Panasonic battery from Digi-Key per the Nuckolls seminar, and "fit" it into my Firewall Vans Battery Box. It is now jammed half-way in and half-way out. Soaking with Boe-lube has not helped. What is the story on this? Anyone else have a misfit problem like this? I now have two expensive pieces of soon-to-be trash.
dsvs(at)comcast.net Guest
Posted: Mon Jun 05, 2006 8:27 pm Post subject: Panasonic LC-RD1217P and Van's Battery Box Misfit |
The Van's battery box is made to fit the PC 680. You may need to switch batteries or make your own box. Don
[quote] --
flyeyes(at)mac.com Guest
Posted: Mon Jun 05, 2006 8:35 pm Post subject: Panasonic LC-RD1217P and Van's Battery Box Misfit |
Ouch.
I'm guessing that the coefficient of thermal expansive is greater for the box than for the battery. You might try (gently) heating the assembly.
On Jun 5, 2006, at 10:59 PM, Michael Ashura wrote:
| Quote: | I just received my new Panasonic battery from Digi-Key per the Nuckolls seminar, and "fit" it into my Firewall Vans Battery Box. It is now jammed half-way in and half-way out. Soaking with Boe-lube has not helped. What is the story on this? Anyone else have a misfit problem like this? I now have two expensive pieces of soon-to-be trash.
lhelming(at)sigecom.net Guest
Posted: Tue Jun 06, 2006 2:51 am Post subject: Panasonic LC-RD1217P and Van's Battery Box Misfit |
alexpeterson(at)earthlink Guest
Posted: Tue Jun 06, 2006 3:53 am Post subject: Panasonic LC-RD1217P and Van's Battery Box Misfit |
Probably the other way around - plastics thermally expand and contract much more than aluminum. Try the freezer (although if it is mounted to the plane, it might take a large one).
Alex Peterson
RV6-A N66AP 758 hours
Maple Grove, MN
<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" />
| Quote: | From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of James Freeman
Sent: Monday, June 05, 2006 11:33 PM
Subject: Re: AeroElectric-List: Panasonic LC-RD1217P and Van's Battery Box Misfit
Ouch.
rv9jim(at)juno.com Guest
Posted: Tue Jun 06, 2006 5:52 am Post subject: Panasonic LC-RD1217P and Van's Battery Box Misfit |
Mike,
I have the Panasonic battery also and it did the same thing.
However, I did not let it get far enough in to not get it out. I am
doing the mod that someone on the web to their battery box. They removed
the front portion of the box and put steel hinges on each side. By
removing the hinge pins, you remove the front cover and remove the
battery towards the front. I bought the steel hinge from McMaster Carr
(about 3') and cut off what I needed and took what pin length I needed.
The pin is about an inch and half longer than the hinge. I flattened the
top 1/4" so I can drill it for a safety wire to keep it from moving.
Problem solved.
Jim Nelson
FWF RV9-A
nuckollsr(at)cox.net Guest
Posted: Fri Jun 09, 2006 4:28 am Post subject: Panasonic LC-RD1217P and Van's Battery Box Misfit |
At 09:44 PM 6/8/2006 -0400, you wrote:
| Quote: | Hi Bob,
I took a few pix of the mod to the battery box. This should give
you the idea on how it goes together. My first attempt tried to get the
whole "other" battery into the box. However, the Panasonic does not have
the little ridge around the top which holds the battery about 1/4" up
from the bottom. I will file that ridge off the generic battery so it
will go all the way to the bottom. Then again, I might put a spacer in
the bottom to take up that space. I'm not in favor of trimming the
little flange around the top of the "other" battery. It seems to be
where the top and bottom come together. What is your thought on trimming
or spacing for that little protrusion?
I've posted your pictures at:
http://www.aeroelectric.com/Pictures/Battery/RV_Battery_Box
It's unfortunate that the original sizing of this box
was so tight as to be brand specific as to what would
fit inside. There's nothing wrong with allowing generous
clearance around the sides and then slipping a corrugated
cardboard "shims" in to take out the rattle.
Trimming the battery case as you've described is
probably going to be okay too.
For others who have yet to fabricate battery installation
provisions, keep in mind that RG batteries don't need
a box. You can capture the battery's footprint in a
shallow tray . . . sides perhaps 1/2" deep and strap
the battery into the tray with some simple retention
of sheet metal or even nylon webbing.
I note further that your battery of choice is not
Panasonic. The treaded posts for attaching fat wires
offers some challenges. Certainly go to these posts
with 4AWG welding cable fitted with terminals that
are close fit to the screw threads. Torque pretty snug
and safety wire screw head if possible.
These are pretty dinky posts and fastener sizes for
this application. They can be made to work but I'd
suggest some extra attention to make-up for joint
integrity.
< What is so wonderful about scientific truth...is that >
< the authority which determines whether there can be >
< debate or not does not reside in some fraternity of >
< scientists; nor is it divine. The authority rests >
< with experiment. >
< --Lawrence M. Krauss >
