holger-d(at)shadowbrush.c Guest
Posted: Tue Dec 11, 2012 6:45 pm Post subject: Removable comm antenna |
Hi all,
Knowing next to nothing about antenna installations, can I run this one
by you for a sanity check? I'd like to be able to quickly disconnect the
comm antenna on a regular base so I can throw a full body cover of my
motor glider.
The antenna sits on the top of the fuselage and currently is a simple
1/4 wave SS bent back whip antenna. Now I want to mount the fat part of
a Workman QDS1 inside the fuselage so it's flush with the outer skin.
Then drill a hole in the small part of the QDS1 and install the whisker
analog to Bob's article. Next is screwing an isolated BNC panel mount
into the QDS1 and make an electric connection between the middle
connector of the BNC and the QDS1. The QDS1 is isolated against the
fuselage. Would it need to be shielded as well? I could put it into an
aluminum box. Alternatively to the BNC, I could also go with a 3/8" to
SO-239 adapter.
What do you say, would that work?
Here are links to the parts:
Workman QDS1:
http://www.amazon.com/QUICK-DISCONNECT-Stainless-Antenna-thread/dp/B004X70UCO/ref=pd_sxp_redirect
Isolated BNC panel mount:
http://www.allelectronics.com/make-a-store/item/BNC-148/BNC-JACK-ISOLATED-PANEL-MOUNT-CONNECTOR/1.html
Bob's article:
http://aeroelectric.com/articles/Antennas/DIY_Comm_Ant/DIY_Comm.html
Thanks much!
Holger
Posted: Wed Dec 12, 2012 8:02 am Post subject: Removable comm antenna |
At 08:44 PM 12/11/2012, you wrote:
<holger-d(at)shadowbrush.com>
Hi all,
one by you for a sanity check? I'd like to be able to quickly
disconnect the comm antenna on a regular base so I can throw a full
body cover of my motor glider.
Is this a metal airplane?
Posted: Wed Dec 12, 2012 9:08 am Post subject: Removable comm antenna |
On 12/12/12 8:01 AM, Robert L. Nuckolls, III wrote:
| Quote: | Is this a metal airplane?
Yes, Bob, it's an all metal plane.
Holger
Posted: Wed Dec 12, 2012 9:52 am Post subject: Removable comm antenna |
| Quote: | The antenna sits on the top of the fuselage and currently is a
simple 1/4 wave SS bent back whip antenna. Now I want to mount the
fat part of a Workman QDS1 inside the fuselage so it's flush with
the outer skin. Then drill a hole in the small part of the QDS1 and
install the whisker analog to Bob's article. Next is screwing an
isolated BNC panel mount into the QDS1 and make an electric
connection between the middle connector of the BNC and the QDS1. The
QDS1 is isolated against the fuselage. Would it need to be shielded
as well? I could put it into an aluminum box. Alternatively to the
BNC, I could also go with a 3/8" to SO-239 adapter.
Consider this alternative. Since this is a slow speed
airplane with relatively low duty cycle, perhaps something
simpler and less robust would be attractive.
Mount 7/16 x 1/2" stainless bolt on a phenolic/fiberglas
skin doubler over a clearance hole for bolt head. Drill
and tap both threaded end and head of bolt for 10-32 screw.
Tread antenna-length piece of 3/16" steel rod about 1/2"
of 10-32 thread. Mount bolt on doubler head facing up.
Thread antenna into bolt and secure with lock-nut. Attach
feed line directly to nut-side of bolt with 10-32 screw
and PIDG terminal. Use PIDG terminal to ground the shield
to one of the doubler attach screws.
Low parts count. Low number of mated joints in the RF
current paths.
Antenna can be easily dismounted and stowed.
dlj04(at)josephson.com Guest
Posted: Wed Dec 12, 2012 10:26 am Post subject: Removable comm antenna |
On 12/12/12 2:57 AM, AeroElectric-List Digest Server wrote:
| Quote: | by you for a sanity check? I'd like to be able to quickly disconnect the
motor glider.
You certainly don't need all that extra hardware. Get or make an antenna
that terminates in a BNC male connector, and mount a BNC female
connector on top of the fuselage. You can get panel mount connectors
that install directly on RG-58 cable. Assuming your glider is
fiberglass, add 3 or 4 quarter-wave radial elements from the shell of
the BNC and extending outward along the inside surface of the fuselage.
You can then make a dummy plug, maybe dome shaped, that goes on the BNC
when you want to cover the aircraft to protect the connector and let the
cover slide over it freely.
Posted: Wed Dec 12, 2012 12:14 pm Post subject: Removable comm antenna |
| Quote: | You certainly don't need all that extra hardware. Get or make an
antenna that terminates in a BNC male connector, and mount a BNC
female connector on top of the fuselage. You can get panel mount
connectors that install directly on RG-58 cable. Assuming your
glider is fiberglass, add 3 or 4 quarter-wave radial elements from
the shell of the BNC and extending outward along the inside surface
of the fuselage. You can then make a dummy plug, maybe dome shaped,
that goes on the BNC when you want to cover the aircraft to protect
the connector and let the cover slide over it freely.
Another good idea. I seem to recall somebody
here on the list used a 'rubber duck' antenna
for a hand-held as his choice of removable
external antennas.
I have crimp-on, bulkhead mount BNC connectors
in stock if you want to go that route and need
one.
Posted: Wed Dec 12, 2012 1:35 pm Post subject: Removable comm antenna |
On 12/12/12 12:14 PM, Robert L. Nuckolls, III wrote:
<nuckolls.bob(at)aeroelectric.com>
external antennas.
Thank you, Bob and DL for your suggestions.
Bob, your solution isn't fully clear to me. Is the 3/16" rod silver
soldered into the 10-32 screw? To disconnect, one would unscrew the
10-32 screw? If the antenna is bent back, that may be a little tricky, no?
I've seen BNC connectors used as antenna bases on ultralights but wasn't
sure about the speed limits. Mine has a 100kts cruise. The BNC
connectors that looked beefy enough also looked pretty draggy. Same for
antennas that have a BNC mount. Bob, you think your crimp-on BNC
connector would support a whip antenna, vs. a rubber duck one? In this
case I'd like to order it from you. I guess I could machine a stainless
steel support sleeve to beef up the antenna side BNC.
Thanks!
Holger
Posted: Wed Dec 12, 2012 4:52 pm Post subject: Removable comm antenna |
No, I'd leave the nut loose for a couple of reasons.
First, it would let you orient a bend and tighten the nut
later (this could be a finger nut made from a piece
of flat sheet with a drilled and tapped hole in the
middle but with enough O.D. to let you hand tighten.
Yeah, it would have a slight 'lengthening' effect
on the antenna which would be shortened accordingly
using SWR meter
(2) heating the rod to silver solder temps in
the thread area places the heat treat of the
material in doubt right at the threads (manufactured
stress riser).
| Quote: | I've seen BNC connectors used as antenna bases on ultralights but
wasn't sure about the speed limits. Mine has a 100kts cruise. The
BNC connectors that looked beefy enough also looked pretty draggy.
Same for antennas that have a BNC mount. Bob, you think your
crimp-on BNC connector would support a whip antenna, vs. a rubber
duck one? In this case I'd like to order it from you. I guess I
could machine a stainless steel support sleeve to beef up the antenna side BNC.
The worst that happens is you break it and need to
replace. If you want a laid back antenna, consider
making the element out of piano wire and leave it
un-bent. A smaller wire will produce less drag,
less stress on connector, and would lay back all
by itself in the breeze.
If you'd like to order a connector, go to the website
catalog, fill out top form data, go to bottom and put
BNC Bulkhead Connector in the comments box. I'll
send you a PayPal invoice.
Over what distances do you expect this antenna/comm
configuration to work? I used to fly my J-3 with a
hand-held fitted with a head-set using a coax taped
half way up the strut and grounded to a sheet copper
'wrapper' and a 1/4 wave trailing wire dangling from
the center conductor.
Worked over the distances (airport traffic area)
and approach to the home field (7-10 miles out).
A trailing wire would be less drag yet.
Posted: Sat Dec 15, 2012 10:06 pm Post subject: Removable comm antenna |
On 12/12/12 4:51 PM, Robert L. Nuckolls, III wrote:
| Quote: | No, I'd leave the nut loose for a couple of reasons.
using SWR meter
Bob, many thanks for explaining it in detail. With your suggestions in
mind, I picked up some parts I had laying around and put this together:
https://www.dropbox.com/sh/rylqm9cect5ndut/XyaFh-jLE2
I'll have to find someone with an SWR meter and cut it to the proper
length. Then we'll see if it actually does what it's supposed to do. But
it's solid, and removed in seconds.
Holger
Posted: Sun Dec 16, 2012 8:05 am Post subject: Removable comm antenna |
| Quote: | Bob, many thanks for explaining it in detail. With your suggestions in
Holger, that looks fine. If everyone were as able to deal with a small
machining project like that as you are, there wouldn't be so many
lashed-up antennas out there. An SWR check will be useful but don't be
too worried about it. You should expect better than 2:1 over a range of
a few MHz. Trim the length so the center of this range is the center of
the range of frequencies you normally use.
Posted: Sun Dec 16, 2012 9:03 am Post subject: Removable comm antenna |
Bob, many thanks for explaining it in detail. With your suggestions in mind, I picked up some parts I had laying around and put this together: https://www.dropbox.com/sh/rylqm9cect5ndut/XyaFh-jLE2
I'll have to find someone with an SWR meter and cut it to the proper length. Then we'll see if it actually does what it's supposed to do. But it's solid, and removed in seconds. |
Nice work! I'd like to add your photos to the archives on
aeroelectric.com.
Help me out a bit . . .
[img]cid:.0[/img]
It appears that your coax center conductor
is attached to the 4-bolt flange (pop rivet?)]
which in turn is insulated from the mounting
bolts with a combination of insulating bushings
and washers. Where does the coax shield find
connection to the groundplane/skin?
It's not clear how the antenna element is retained
on the aircraft/
As D.L. suggested, SWR isn't a terribly critical concern.
If you cut it for an overall length from skin to tip
of 22", you're going to be close enough for government
work.
It would be interesting to see a plot of your measured
SWR over the range of interest at say 1 Mhz steps. If
you've got better things to do on your airplane, don't
let this academic exploration get too high on the list
of priorities.
64.36 KB |
7167 Time(s) |
Posted: Sun Dec 16, 2012 10:24 am Post subject: Removable comm antenna |
On 12/16/12 9:02 AM, Robert L. Nuckolls, III wrote:
| Quote: | It appears that your coax center conductor
on the aircraft/
D.L., Bob, thanks again! I'll go with 22 inches until I find someone
with a SWR meter. If this person and I can get the data for the plot, I
will send it to you, Bob.
That's correct, the coax center is attached to that rectangular flange
with a PIDG terminal. There is a threaded hole in the flange for it. The
flange is welded to a SS tube that receives the antenna rod. As you
said, the flange and tube is insulated against ground. I measured for
conductivity. There is a spring in the tube, just to make sure there's
good contact.
The coax shield is connected to ground a few inches away. I left that
unchanged from the previous whisker antenna installation.
That riveted skin doubler is the result of my damaging the original
antenna on the ground. Not going to happen anymore. But the main thing
is, I can now sew a full cover to keep it dry outside, and won't have to
put it on a trailer when a bit of wet weather is moving in. Means more
flying for me! )
Holger
BobsV35B(at)aol.com Guest
Posted: Sun Dec 16, 2012 10:39 am Post subject: Removable comm antenna |
Good Afternoon Holger,
Great workmanship! What I really love is that V-Tail. <G> What kind of a machine is it?
Happy Skies,
Old Bob
Downers Grove, Illinois
V-Tail Aficionado
In a message dated 12/16/2012 12:25:01 P.M. Central Standard Time, holger-d(at)shadowbrush.com writes:
| Quote: | --> AeroElectric-List message posted by: Holger Selover-Stephan <holger-d(at)shadowbrush.com>
on the aircraft/
good contact.
flying for me! )
Holger
Posted: Mon Dec 17, 2012 1:01 am Post subject: Removable comm antenna |
Thanks, Old Bob, and that's a little, humble Monnett Moni. Sometimes the shadow of this V-tail makes it look like a fighter jet! Its day job, though, is providing its owner with cheap (2gal/hr), but very enjoyable flying: http://www.youtube.com/watch?v=M_FvBS6MncA . The V-tail works splendidly, the pilot is trying his best.
Holger
On 12/16/12 10:38 AM, BobsV35B(at)aol.com (BobsV35B(at)aol.com) wrote:
[quote] Good Afternoon Holger,
Happy Skies,
Old Bob
V-Tail Aficionado
