sidsel.svein(at)oslo.onli Guest
Posted: Thu Dec 06, 2012 9:59 am Post subject: New Lightning builder, Experimental |
To the Lightning-List members,
I am forwarding the below message from Per Pfeffer, who is experiencing a problem with posting the message to the list (this issue will be checked separately with Matt).
Svein Johnsen
Nice to join the club. I have started on a fast building set since August 2012 here in Norway. At the moment I am working on the tail rudder and don't find detailed information on how the rudder cables are attached to the rudder. I will not have a rudder trim but assume that I will have to make a service opening in the rudder to eventually put on a nut on the inside. There are two holes in the rudder but from the outside it does not look like the glass fibre is fortified on the inside. Should there be a washer, piece of aluminium or just Epoxy and Flox on the inside? Understand that information on this was supposed to be in the Newsletter from Arion, October 2010, but do not find it there. Hope for some advises and eventual pictures.
Best regards Per Pfeffer
| | - The Matronics Lightning-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Lightning-List |
sttwig
Posted: Thu Dec 06, 2012 10:22 am Post subject: New Lightning builder, Experimental |
Hello Per,
There is already a nut the hole. Try threading a bolt in there. Here is a quote from an email I got from Nick at Arion:
| Quote: | The rudder has a 10-32 nutplate in it for the U bracket that must be made to
capture the cable eye end. Instead of the u bracket you will you a 10-32 or
3/16" male rodend. You will put it into the rudder in this order, AN3
standard washer against the rudder, screw an AN3 jamnut on the rodend, screw
the rodend in all the way than tighten up the jam nut against the rudder.
This will lock the rodend in place.
To connect the rodend to the cable you will need to make 4 tabs. The tabs
will be about 1.25" long and have 3/16" holes in each end. One tab on each
side of the cable and rod end to hook them up. We use the little 0.090th
pulley tangs provided in the kit, cut one hole off and the other 2 are the
correct spacing for the job.
I have attached a picture.
I hope you get this and it helps.
One of your fellow countrymen here in Yakima, Ola Vestad, recently finished building a Rans S-19 with a Jabiru engine. He is have a great time with it.
Best regards,
Steve Sundquist
Yakima, Washington USA
Kit #48
On 12/6/2012 9:59 AM, Sidsel & Svein Johnsen wrote:
<![endif]--> <![endif]-->
Svein Johnsen
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum You cannot attach files in this forum You cannot download files in this forum
