dwconner1(at)sbcglobal.ne Guest
Posted: Thu Nov 29, 2012 7:13 pm Post subject: Alternator connection |
I am using solid state relays instead of the typical coil and contacts
for my main power and starter. The only problem is they are
unidirectional. Standard procedure is to connect the power from the
alternator on the switched side of the contactor. The problem is this
will not charge the battery. I can possibly get a bidirectional relay.
Any ideas? The relays I am using are Power-Gate by Perfect Switch.
You can see them at www.perfectswitch.com.
Thanks, Dennis
| | - The Matronics RV7-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?RV7-List |
rv8iator(at)gmail.com Guest
Posted: Fri Nov 30, 2012 7:26 am Post subject: Alternator connection |
Dennis,
Why not use their bi-directional relay?
http://www.perfectswitch.com/downloads/Relay%20Bi-Directional.pdf
Chris Stone
RV-8
Oregon
On Thu, Nov 29, 2012 at 7:12 PM, Dennis W. Conner <dwconner1(at)sbcglobal.net (dwconner1(at)sbcglobal.net)> wrote:
[quote]--> RV7-List message posted by: "Dennis W. Conner" <dwconner1(at)sbcglobal.net (dwconner1(at)sbcglobal.net)>
I am using solid state relays instead of the typical coil and contacts for my main power and starter. The only problem is they are unidirectional. Standard procedure is to connect the power from the alternator on the switched side of the contactor. The problem is this will not charge the battery. I can possibly get a bidirectional relay. Any ideas? The relays I am using are Power-Gate by Perfect Switch. You can see them at www.perfectswitch.com.
Thanks, Dennis
lectric.com" target="_blank">www.aeroelectric.com
ldersbooks.com" target="_blank">www.buildersbooks.com
" target="_blank">www.homebuilthelp.com
-Matt Dralle, List Admin.
target="_blank">http://www.matronics.com/Navigator?RV7-List
MS -
