sidsel.svein(at)oslo.onli Guest
Posted: Sun Nov 25, 2012 9:46 am Post subject: SV: Running too cool, considering blocking some of intake |
Graeme,
| Quote: | My 912ULS runs too cool at around 80deg C, as I have the cowl home I am
wondering about blocking some of the radiator air intake off, maybe half
of it
| Quote: | and adding a couple of LED landing lights. Some sort of variable vent
might be
| Quote: | best though. Any suggestions?
I have for several years flown in cold and hot weather with Van's variable
shutter in front of approx. 50% of the radiator - see attached photo (the
photo was taken before I installed an oil thermostat, so I have no plates in
front of the oil cooler anymore). My 912ULS has 50/50 glycol/water, and I
have not experienced problems even on hot airfields. However, to be on the
safe side if flying much in hot summers, the shutter can be removed in 30
minutes for such seasonal flying, as this will allow more air to pass
through the radiator.
I purchased the shutter fra Van's Aircraft in the US, and the Bowden cable
with accessories from Aircraft Spruce.
Svein
LN-SKJ
577.1 KB |
21227 Time(s) |
graeme bird
Posted: Sun Nov 25, 2012 10:06 am Post subject: Re: SV: Running too cool, considering blocking some of intak |
Thats very neat, thanks. I am wondering though if its really a problem to be running at 80deg. I tend to get higher temps initially at take off which would get rid of condensation etc. What happens when the engine is running warmer? I cant see any particular reference in the Rotax manual.
I guess I could just tape over half of it with aluminium tape and see for now.
_________________ Graeme Bird
kit4 (Wagstaff) TBD
Kit 1 G-UMPY - Mono Classic/XS 912S, Woodcomp G(@)gdbmk.co.uk |
dg.watts(at)talktalk.net Guest
Posted: Sun Nov 25, 2012 11:08 am Post subject: SV: Running too cool, considering blocking some of intake |
Graeme,
I always run with at least 50% of the radiator sealed off with duct tape
during the winter months down here in coldest (?) Kent on my monowheel/912S
Dave Watts
G-BXDY
budyerly(at)msn.com Guest
Posted: Sun Nov 25, 2012 1:50 pm Post subject: SV: Running too cool, considering blocking some of intake |
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> [img]cid:011d01cdcb56$29C40C55(at)adminPC[/img][img]cid:011e01cdcb56$29C40C55(at)adminPC[/img] Photo E-mail [url=https://skydrive.live.com/redir.aspx?cid=2161856909618aa7&page=play&resid=2161856909618AA7!290&type=5&authkey=!APxkChnz5qtFle0]View slideshow [/url]| [url=https://skydrive.live.com/redir.aspx?cid=2161856909618aa7&page=downloadphotos&resid=2161856909618AA7!290&type=5&authkey=!APxkChnz5qtFle0]Download images [/url] According to Rotax there is not a technical minimum cylinder temp but I agree that we know that a warmer cylinder will be more efficient and the crankcase and gearbox will not harbor water in the case.
The oil thermostat is one way to get up the oil temp. I have tried to make a simple rear flap to close up the back but you would not believe the pressure coming out of the rear of those radiators and the duct suction pulling on the other side of the flap. A moveable cowl flap will work, but then we're talking repaint of the cowl. So how do we get the glycol temp up? Tape over 1/3 of the glycol cooler is a start. Next is making a removable metal air dam in front of the glycol cooler, but that is not adjustable. So what is needed is an adjustable flap that can be set from the cockpit for those warmer winter days, spring and fall operations or high altitude cruise operations.
Those adjustable slotted cooler shutters are a solution. Unless you need every bit of cooling air in the summer like I do here in Florida.
Mark Ferkin of High wing LLC (Kitfox guy of fame) makes a shutter for the Rotax coolers. It doesn't work well for our setup but the concept works.
Van's aircraft has the slotted flap as addressed above and used on other Northern Europa's but it does block the air needed for summer options.
For oil cooling, I have installed the oil thermostat and it is very convenient and automatic so I'm waiting for it to fail...
I really have only one idea for a moveable Europa style XS coolers with a two inch drop of the oil cooler. If you have one of my cockpit heaters be sure to leave a cutout for the heater or the cockpit heat gets shut off. See below:
Bud Yerly
[url=https://skydrive.live.com/redir.aspx?cid=2161856909618aa7&page=play&resid=2161856909618AA7!291&parid=2161856909618AA7!290&type=1&authkey=!APxkChnz5qtFle0][img]cid:011f01cdcb56$29C40C55(at)adminPC[/img][/url]
Just a simple hinge setup with a flapper door to block the air coming out of the glycol cooler and pivoted near the center to reduce pull and hold forces. An oil cooler thermostat takes care of the oil temps.
[url=https://skydrive.live.com/redir.aspx?cid=2161856909618aa7&page=play&resid=2161856909618AA7!292&parid=2161856909618AA7!290&type=1&authkey=!APxkChnz5qtFle0][img]cid:012001cdcb56$29C40C55(at)adminPC[/img][/url]
I really thought this would work but the force to hold the flap shut against the air outflow from the coolers (and draw of the cowl ramp) is considerable for a hinged flap at the leading edge.
842 Bytes |
21218 Time(s) |
1.11 KB |
21218 Time(s) |
42.29 KB |
21218 Time(s) |
34.23 KB |
21218 Time(s) |
mau11(at)free.fr Guest
Posted: Sun Nov 25, 2012 11:56 pm Post subject: SV: Running too cool, considering blocking some of intake |
Hi Bud I send to you a drawing of my Coolers flap.
Michel AUVRAY
Builder 145
Date: 2012-11-25 22:49
Subject: Re: Re: SV: Running too cool, considering blocking some of intake
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> [img]cid:_Foxmail.0(at)7C019C53-B5F6-405F-A623-F83FB5F99102[/img][img]cid:_Foxmail.1(at)3ED1EF97-21A6-4878-A39E-FFFDDE60289A[/img] Photo E-mail [url=https://skydrive.live.com/redir.aspx?cid=2161856909618aa7&page=play&resid=2161856909618AA7!290&type=5&authkey=!APxkChnz5qtFle0]View slideshow [/url]| [url=https://skydrive.live.com/redir.aspx?cid=2161856909618aa7&page=downloadphotos&resid=2161856909618AA7!290&type=5&authkey=!APxkChnz5qtFle0]Download images [/url] According to Rotax there is not a technical minimum cylinder temp but I agree that we know that a warmer cylinder will be more efficient and the crankcase and gearbox will not harbor water in the case.
Bud Yerly
[url=https://skydrive.live.com/redir.aspx?cid=2161856909618aa7&page=play&resid=2161856909618AA7!291&parid=2161856909618AA7!290&type=1&authkey=!APxkChnz5qtFle0][img]cid:_Foxmail.2(at)931EA0B9-EB61-474F-92DA-0DA2A8F2900F[/img][/url]
[url=https://skydrive.live.com/redir.aspx?cid=2161856909618aa7&page=play&resid=2161856909618AA7!292&parid=2161856909618AA7!290&type=1&authkey=!APxkChnz5qtFle0][img]cid:_Foxmail.3(at)FE63DFED-71E2-4760-9B63-652C5E2C4521[/img][/url]
842 Bytes |
21208 Time(s) |
1.11 KB |
21208 Time(s) |
42.29 KB |
21208 Time(s) |
34.23 KB |
21208 Time(s) |
482.46 KB |
21208 Time(s) |
Posted: Sun Dec 02, 2012 2:51 pm Post subject: SV: Running too cool, considering blocking some of intake |
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> Good for blocking the air bypassing, but we need a flap to actually stop the air going to or from the cooler to warm up the oil.
Bud
842 Bytes |
21153 Time(s) |
1.11 KB |
21153 Time(s) |
42.29 KB |
21153 Time(s) |
34.23 KB |
21153 Time(s) |
