Mozam
Posted: Fri Nov 23, 2012 10:56 am Post subject: Cylinder base wrench |
The Russian cylinder base wrench in my tool kit is not the greatest at reaching some nuts. Nor is it possible to set a real torque value using it. I *think* (from my fading memory) the nuts are 14mm, so has anyone used a regular 9/16th cylinder base wrench before?
Or, is there such a thing as a 14mm cylinder base wrench, other than the one in my Russian tool set?
Steve Dalton
Posted: Fri Nov 23, 2012 3:10 pm Post subject: Cylinder base wrench |
Check with George Coy. He makes a cylinder base tool with a socket head that your torque wrench will work with. Off the top of my head I believe it is a 1/2 inch drive but don't quote me on it. It is a thin walled cylinder base wrench so it will fit in those tight spots like between the carb and the sump. Careful not to over torque the tool to hard though or it will split down the side.
Don't remember the base nut size. Been about 19 months since I tore my engine down. I want to say 15 mm was the size though. Have not tried a 9/16 th wrench either.
Doc
On Nov 23, 2012, at 12:56 PM, "Mozam" <sdalton(at)hughes.net> wrote:
Steve Dalton
http://forums.matronics.com/viewtopic.php?p=388749#388749
wlannon(at)shaw.ca Guest
Posted: Fri Nov 23, 2012 7:41 pm Post subject: Cylinder base wrench |
I regularly use a 9/16" Pratt & Whitney cylinder base wrench but since it is
0.011" bigger than 14 mm you need to be sure it is in good condition.
Been meaning to check with Snap - On re a 14 mm one but so far have not done
so. A standard 14 mm crow foot will not work.
Walt
dougsappllc(at)gmail.com Guest
Posted: Sat Nov 24, 2012 8:08 am Post subject: Cylinder base wrench |
Russian and Chinese cyl base nuts are both 14mm.I carry the Chinese cyl base nut wrenches in stock.
Please contact me off list if interested.
Hope everyone had a great Thanksgiving.
Doug
On Fri, Nov 23, 2012 at 10:56 AM, Mozam <sdalton(at)hughes.net (sdalton(at)hughes.net)> wrote:
[quote]--> Yak-List message posted by: "Mozam" <sdalton(at)hughes.net (sdalton(at)hughes.net)>
Steve Dalton
="_blank">www.aeroelectric.com
ooks.com" target="_blank">www.buildersbooks.com
et="_blank">www.homebuilthelp.com
le, List Admin.
rget="_blank">http://www.matronics.com/Navigator?Yak-List
samira.h(at)shaw.ca Guest
Posted: Sun Nov 25, 2012 7:09 am Post subject: Cylinder base wrench |
Hi Steve,
if you have a bench grinder you could do the job
in a few minutes. Just grind the top end of the
cyl. base wrench into the shape of a 7/8" hex nut
and slide the matching 6-point socket on, please see
attached picture. Now you can use your torque
wrench, extension, ratchet, etc.
You can use this technique also to modify some of
the other engine tools as well.
Hope that helps.
cheers
Elmar
704.65 KB |
6782 Time(s) |
Mozam
Posted: Mon Nov 26, 2012 5:47 am Post subject: Re: Cylinder base wrench |
Elmar, great idea!
Doug, are the Chinese wrenches you carry the same as the Russian ones with a T-handle at the end to "hand-tighten" the nuts?
Steve
Posted: Mon Nov 26, 2012 11:59 am Post subject: Cylinder base wrench |
Yes they are the same. I have cut the T handle top off mine and welded on a socket so I could use my torque wrench.
Doug
On Mon, Nov 26, 2012 at 5:47 AM, Mozam <sdalton(at)hughes.net (sdalton(at)hughes.net)> wrote:
Elmar, great idea!
Steve
http://forums.matronics.com/viewtopic.php?p=388957#388957
le, List Admin.
