Van tires special
rv10flyer(at)live.com
PostPosted: Tue Nov 20, 2012 3:47 pm    Post subject: Van tires special Reply with quote
Not sure if everyone saw the deal on VAF
● VansAircraftTIRES.com has a few RV-related specials going on...
- 10% New Builder Special
- 10% Main Tire Special
- fmi: www.VansAircraftTires.com
As many know I worked with Desser/Vans aircraft tires to create a custom fit windscreen. I did so because the windows that are sent from Vans require a whole lot of form fitting and trimming. The price is the same as Vans, maybe lower, and the quality far superior, also Vansaircraft tires, windows are minor tweaks or fit on arrival. I spent hours fitting and refitting my Vans windows, same for the front windscreen, and after all that I had a bulge on the windscreen copilot side that required serious work. The one I received from Desser was amazing and very nice quality. I also got the wingtip lenses- same plug n play deal except they use real acrylic versus the cheap lenses Vans sells.
I gain nothing if you buy from Vans or Vansaircraft, but I owe it to myself to tell other builders when there is a better option out there and this is far superior. If you are coming up at the fuselage or final kit, skip these parts from your Vans order and get it from. Desser.
Lastly, Vans buys their tires, the one you get, from desser, do yourself a favor just get the tires you want- retread, Goodyears, or other direct from Desser. Specially when they have the 10% tire special going on.
Great guys at Desser/Vans aircraft tires, call them if you have any questions
Pascal
