Gary.A.Sobek
Posted: Mon Nov 19, 2012 11:57 am Post subject: A&p and Repairman Paper Certificates |
Got this notice from the FAA and figured I would spread it. All Paper Certificates including Repairman need to be replaced with the plastic ones.
A&P Certificate Replacement
Notice Number: NOTC4449
If you have already replaced your paper A&P certificate, then this message is not for you. On the other hand, if your A&P certificate is still printed on paper, please read carefully.
The FAA is under a mandate to replace all paper certificates with plastic certificates. If you do not replace your paper certificate on or before March 31, 2013, you will no longer be able to exercise your privileges!
All certificated Airmen, including mechanics, repairmen, pilots, etc., are required to replace their paper copy with a plastic copy, or they will no longer be able to exercise the privileges of that certificate.
The best way to get a new replacement certificate is to follow the instructions at http://www.faa.gov/licenses_certificates/airmen_certification/certificate_replacement/.
The replacement cost is $2.00, unless you still have your Social Security Number on your certificate and you ask to have it removed.
Avoid the Rush! Apply today!
Gary A. Sobek
"My Sanity" RV-6 N157GS O-320 Hartzell,
2,630+ Flying Hours So. CA, USA
