Posted: Sun Nov 11, 2012 5:38 am Post subject: New LOMU member . . . |
At 08:47 PM 11/10/2012, you wrote:
Re. Metcal
You guys got my curiosity peeked... so I bid and won one on Ebay...
$28 bucks. It just arrived and I took it up to the shop to try it
out... Alas no tip. So I'll will see what I can find on ebay.
Which model did you buy? Are you sure of which
style of tip to acquire?
Question: Most of the soldering I do is wire splice and wire to
connectors...Tefzel 18-24 ga. single and shielded. Only occasional
PCB assembly and/or repair. Most being SMT now but some through
hole. What tips would you recommend?
Here's a catalog of tip styles offered in the STTC
series tips
http://tinyurl.com/d2p28z9
Note the part numbers have a 'x' in them.
Put a "1" in that space and you get a 700
degree tip, a "0" gets you a 600 degree
tip.
About any style tip will get you 'soldered
up for general wiring tasks. I.e., if you
need to solder something together, don't
have an iron, and run to the local RS or
hardware store to get one, what ever they
have in stock has 99% probability of getting
your task done. So the short answer is,
"don't pass up a bargain on any tip style".
Most of my bench work including SMD down to
1206 components is done with tips like 04,
25 or 37. The heaviest tasks like assembling
an enclosure out of copper clad or putting a
terminal on a fat wire calls for a 17 or 65.
Installing a .025 or .050 pitch SMD calls for
the smallest of tips like a 22.
I've acquired these or similar in both 600 and
700 degree sizes. I've not seen much difference
in outcome of the joint that I could attribute
to tip temp.
By the way, when installing new fine pitch
integrated circuits on a board, I find that
boards manufactured with the legacy tin/lead plating
can be simply fluxed, the part held in place,
and solder already in place simply pushed from
the far end of the pad toward the pin to be
soldered. No additional solder required, joints
come out looking like an oven reflow job.
I've only had to order specific tips and pay
close to full freight (12 to 18 dollars) a couple
times. Just ordered some 17's under that condition.
All other tips were acquired in a what-you-see-is-
what-you-get assortment of new/used tips. A little
fist full of used tips can be VERY reasonable.
Over the years, I think I've had perhaps one or two
tips in bundles of used tips be inop.
Good luck and welcome to LOMU (Loyal Order of
Metcal Users).
rv8iator(at)gmail.com Guest
Posted: Sun Nov 11, 2012 3:12 pm Post subject: New LOMU member . . . |
The Metcal is the SP200. Also Eric chimed in that the holder is integral as it may provide a control function when the handpiece is holstered. Thanks for the tip on tips...
Re SMT; I have been using paste on the pads and re-flowing with my trusty Weller. Works fine most of the time.
chris
[quote] Re. Metcal
You guys got my curiosity peeked... so I bid and won one on Ebay... $28 bucks. It just arrived and I took it up to the shop to try it out... Alas no tip. So I'll will see what I can find on ebay.
Question: Most of the soldering I do is wire splice and wire to connectors...Tefzel 18-24 ga. single and shielded. Only occasional PCB assembly and/or repair. Most being SMT now but some through hole. What tips would you recommend?
series tips
tip.
to tip temp.
Metcal Users).
om" target="_blank">www.aeroelectric.com
ooks.com" target="_blank">www.buildersbooks.com
et="_blank">www.homebuilthelp.com
le, List Admin.
-List" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List
http://forums.matronics.com
Posted: Mon Nov 12, 2012 1:42 am Post subject: New LOMU member . . . |
At 05:11 PM 11/11/2012, you wrote:
| Quote: | The Metcal is the SP200.
Okay, those are a different series of tips so
you'll have to flush those quail out of another
bush
http://tinyurl.com/2vpw7s
Hmmm . . . don't think so. It's not mentioned in the
manual
http://tinyurl.com/ab6sm7p
| Quote: | Re SMT; I have been using paste on the pads and re-flowing with my
'Paste'??? Like the black greasy stuff in the
blue snuff can? Be careful of the use of
any form of additional flux on electronics
soldering. Many of the legacy products are
VERY effective for structural soldering where
the surfaces are easily cleaned after . . . but
are exceedingly conductive and corrosive.
Look for a "no-clean" flux pen. Here is one
example of many.
http://tinyurl.com/ashqcvh
It takes only the tiniest 'wetting' of the
surface and one of these pens will last you for
years as long as you don't leave the cap off.
You will find that the smallest surface mount
joints can be made with no solder added to
a tin-lead plated board. This includes the SOT-23
like devices.
Posted: Mon Nov 12, 2012 10:48 am Post subject: New LOMU member . . . |
Bob...
The solder paste is in the .5 cc syringes etc.
http://tinyurl.com/dyjlsrw
I'll try the flux pen as well...  I haven't been able to consistently getÂ
re-flow and good wetting as my trust Weller EC100 tip sometimes won't release
the solder. Â Acts as if the surface tension on the solder melt wont't break.
I'm hoping this new Metcal will improve this characteristic.Â
 I borrowed a tip from one of the older Metcal stations at work and will try it out.
Thanks for your insights.
chris
 bush
  manual
| Quote: | Re SMT; I have been using paste on the pads and re-flowing with my trusty Weller. Â Works fine most of the time.
  example of many.
  like devices.
lectric.com" target="_blank">www.aeroelectric.com
ldersbooks.com" target="_blank">www.buildersbooks.com
" target="_blank">www.homebuilthelp.com
     -Matt Dralle, List Admin.
ric-List" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List
MS -
uuccio(at)gmail.com Guest
Posted: Mon Nov 12, 2012 1:52 pm Post subject: New LOMU member . . . |
I think I'm also a new LOMU member... Just bought a second hand SP200 on ebay, had to pay up ($70) to get a 230VAC version and then some more for shipping to Italy (and will have to pay import duties, levy and 21% sales tax because the Italian customs are basically thieves), but I'm looking forward to it! Also ordered the other accessories (holder, a few tips) and will add a flux pen too.
Sacha
On 12/nov/2012, at 10:40, "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com> wrote:
bush
manual
example of many.
like devices.
Eric M. Jones
Posted: Mon Nov 12, 2012 4:54 pm Post subject: Re: New LOMU member . . . |
| Quote: | Also Eric chimed in that the holder is integral as it may provide a
manual |
The stand has a big magnet in it that puts the station into "Sleep Mode", which lowers the temperature but does not turn the power off. This reduces heat-up time to a few seconds. See:
www.okinternational.com/binary/articles/AutosleepWorkstands.pdf
www.PerihelionDesign.com
113 Brentwood Drive
Southbridge, MA 01550
(508) 764-2072
emjones(at)charter.net |
email(at)jaredyates.com Guest
Posted: Mon Nov 12, 2012 6:09 pm Post subject: New LOMU member . . . |
It looks like I'll have to wait a few weeks to get one for myself,
after the rest of the aeroelectric list members quit running up the
ebay prices:)
On Mon, Nov 12, 2012 at 4:51 PM, Sacha <uuccio(at)gmail.com> wrote:
Sacha
> bush
> manual
> example of many.
> like devices.
> Bob . . .
Posted: Mon Nov 12, 2012 7:54 pm Post subject: New LOMU member . . . |
http://tinyurl.com/adkgqow
check it out...
...chris
On Mon, Nov 12, 2012 at 6:07 PM, Jared Yates <email(at)jaredyates.com (email(at)jaredyates.com)> wrote:
[quote]--> AeroElectric-List message posted by: Jared Yates <email(at)jaredyates.com (email(at)jaredyates.com)>
ebay prices:)
On Mon, Nov 12, 2012 at 4:51 PM, Sacha <uuccio(at)gmail.com (uuccio(at)gmail.com)> wrote:
> --> AeroElectric-List message posted by: Sacha <uuccio(at)gmail.com (uuccio(at)gmail.com)>
> Sacha
> On 12/nov/2012, at 10:40, "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
>> --> AeroElectric-List message posted by: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)>
>> Â Okay, those are a different series of tips so
>> Â you'll have to flush those quail out of another
>> Â bush
>> Â Hmmm . . . don't think so. It's not mentioned in the
>> Â manual
>> Â 'Paste'??? Like the black greasy stuff in the
>> Â blue snuff can? Be careful of the use of
>> Â any form of additional flux on electronics
>> Â soldering. Many of the legacy products are
>> Â VERY effective for structural soldering where
>> Â the surfaces are easily cleaned after . . . but
>> Â are exceedingly conductive and corrosive.
>> Â Look for a "no-clean" flux pen. Here is one
>> Â example of many.
>> Â It takes only the tiniest 'wetting' of the
>> Â surface and one of these pens will last you for
>> Â years as long as you don't leave the cap off.
>> Â You will find that the smallest surface mount
>> Â joints can be made with no solder added to
>> Â a tin-lead plated board. This includes the SOT-23
>> Â like devices.
>> Â Bob . . .
MS -
mrspudandcompany(at)veriz Guest
Posted: Tue Nov 13, 2012 3:16 am Post subject: New LOMU member . . . |
check it out...
...chris
Rather expensive shipping!!!
Roger
Posted: Tue Nov 13, 2012 5:32 am Post subject: New LOMU member . . . |
That one used to be on my watch list...
On Nov 12, 2012, at 22:53, Christopher Cee Stone <rv8iator(at)gmail.com (rv8iator(at)gmail.com)> wrote:
[quote]http://tinyurl.com/adkgqow
check it out...
...chris
| Quote: | --> AeroElectric-List message posted by: Jared Yates <email(at)jaredyates.com (email(at)jaredyates.com)>
ebay prices:)
> Sacha
>> bush
>> manual
>> example of many.
>> like devices.
>> Bob . . .
MS -
