ghf4986(at)gmail.com Guest
Posted: Fri Nov 09, 2012 10:24 am Post subject: Motor Mount Issue |
Sent from an IPad
I removed the engine from my XP, 912- bed mount, and noticed that the
bolts that attach the engine brackets length wise in the front to the
cross piece bracket were hitting the lower bed mount bracket.
The bolt size were as directed in the build manual, but there is not
enough room for a lock nut (even a shallow nut) with minimum thread
showing. I ended up installing the bolts in the up position.
Certainly not ideal. My motor mounts are relatively new, only 100
hrs.
I thought I would mention it to others as it is very difficult to see
with the engine installed.
Dennis Adams
| | - The Matronics Pulsar-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
briana(at)xtra.co.nz Guest
Posted: Fri Nov 09, 2012 12:39 pm Post subject: Motor Mount Issue |
Dennis,
I recently had my engine out for the first time in 12 years, and noticed that the bolt heads had at times contacted the front bed mount too. For the same reason as you the bolts are upright, and I had checked at the first installation that there was some clearance. I think over time the rubber mounts soften and allow more movement. I fitted new rubber engine mounts and included a washer under each to raise the engine a smidgen to give more clearance.
Brian
On 10/11/2012, at 7:23 AM, Dennis Adams <ghf4986(at)gmail.com> wrote:
Sent from an IPad
hrs.
Dennis Adams
