theskunk
Posted: Fri Jan 25, 2013 3:19 pm Post subject: Pulsar II |
Hi,
Myself and a partner (or two) are looking into taking the plunge on a Pulsar II with about 100 hrs on it (Apparently its been sitting for the last 10 years, and only started flying a year ago). Condition inspection has been brought up to airworthy, however some of the weights/speeds/climbs aren't quite what i'm used to seeing, and am in hopes that somebody can clarify what I'm finding here.
I'm being told cruise will be around 115mph with a Jabiru 2200 motor, on 4-4.5gph.
Climb = 700fpm (seems low?)
Gross = 1200lbs - can this be bumped up to 1300?
I'm also reading that wheel pants from a RV12 (at least the nose) will improve performance a bit.
What other questions should I be asking this seller particular to the Pulsar aircraft? Both myself and the airplane are in NC, in case anybody knows the plane/seller.
Thanks!
lwheat2083(at)gmail.com Guest
Posted: Fri Jan 25, 2013 7:10 pm Post subject: Pulsar II |
I own a Pulsar III which was put in service on March 15 2012. I have a Jabiru 2200 with a ground adjustable Sensenich prop. I am experiencing 140 at 2950 rpm at about 4-4.5/hr. I think that when the airplane is registered ar a certain weight that is it. I am at max 1250 and have not had any trouble at gross. Two people at 230+ and full fuel. It is cramped, no doubt, but manageable. If you would like more info you can email me at lwheat2083(at)gmail.com (lwheat2083(at)gmail.com) and I also have some videos on You Tube of some test flight. Look for Pulsar III test flights.
On Fri, Jan 25, 2013 at 3:19 PM, theskunk <rob.wilmoth(at)gmail.com (rob.wilmoth(at)gmail.com)> wrote:
| Quote: | --> Pulsar-List message posted by: "theskunk" <rob.wilmoth(at)gmail.com (rob.wilmoth(at)gmail.com)>
Hi,
Thanks!
http://forums.matronics.com/viewtopic.php?p=393065#393065
target="_blank">http://www.matronics.com/Navigator?Pulsar-List
le, List Admin.
Larry Wheat [quote][b]
