LIKE2LOOP(at)aol.com Guest
Posted: Sun Jun 04, 2006 7:28 am Post subject: HS done! Elevators next |
Here is my HS, "flying" from the garage ceiling.
I closed the rudder with the new version of the Proseal, in the self mix caulk tube. Very easy to work with, lots of extra mixed material wasted..... clean up is easy if you dont touch the stuff. I was able to dispense directly to the inside surface of the right skin, then place the trailing edge piece a few clecos from underneath, and add a layer of proseal and then the left skin, without touching the stuff.
Steve
Stephen Blank RV-10 Builder #40499 Cessna 170B flyer
766 SE River Lane Trimming elevator ribs........
Port St. Lucie, FL 34983
772-475-5556 cell - evenings and weekends
28.49 KB |
390 Time(s) |
jjessen
Posted: Sun Jun 04, 2006 7:44 am Post subject: HS done! Elevators next |
Looks like it's flying pretty good. Nice job.
John J
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of LIKE2LOOP(at)aol.com
Sent: Sunday, June 04, 2006 8:28 AM
Subject: HS done! Elevators next
[img]cid:426494315(at)04062006-188E[/img]
Steve
28.49 KB |
393 Time(s) |
bldgrv10450(at)comcast.ne Guest
Posted: Sun Jun 04, 2006 11:05 am Post subject: HS done! Elevators next |
John
If you still need to complete your elevator trims, I have wood clamp blocks for you.
Paul Grimstad,
RV10-40450, assembling tailcone
28.49 KB |
387 Time(s) |
Mike Whisky
Posted: Tue Jun 06, 2006 5:30 am Post subject: Re: HS done! Elevators next |
Good job, any heads up for me regarding the HS, because I just started it now.
Best Regards
Michael
www.wellenzohn.net
_________________ RV-10 builder (flying)
#511 |
