Posted: Fri Sep 28, 2012 6:39 pm Post subject: SD-8 S704-1 relay with or without Diode when using OVM-14? |
| Quote: | Am I correct in leaving the Diode OUT? The reason being that I'm
using the OVM-14 across the coil and adding the Diode would defeat
the OVM's function.
The diode will not affect OVM operation. Resistors
in the OVM are across the relay coil and provide
some damping action making the diode unnecessary.
plevyakh
Posted: Sun Sep 30, 2012 7:17 am Post subject: Re: SD-8 S704-1 relay with or without Diode when using OVM |
Bob,
Thank-you very much for the replies. I was able to calibrate my OVMs and get them both (SD-8 Alternator, and Ground Power) installed yesterday.
I greatly appreciate all you do for our OBAM community. Without AEC I'd be lost. My electrical system installation is coming right along.
Sincerely,
Howard
_________________ Howard Plevyak
GlaStar / Cincinnati, Ohio |
