AIRCAM Schematic or ideas
toaster73(at)embarqmail.c
PostPosted: Wed Sep 26, 2012 10:58 am    Post subject: AIRCAM Schematic or ideas Reply with quote
I am beginning to work up an electrical plan for a friends Aircam project, twin Rotax 912's with single battery. Anybody out there have a schematic they would like to share for a twin engine rotax or similar to give me a starting point to look over. I looked at the TECNAM P2006T but I don't think I need the complexity of its system and I do not quite understand the Cross bus switch logic they have. I attached for anyone who wants to comment on it.
Chris Lucas
N919AR
RV-10 and Aircam helper
p2006t_manualas_123.pdf
 Filename:  p2006t_manualas_123.pdf
 Filesize:  91.33 KB
 Downloaded:  585 Time(s)
PostPosted: Wed Sep 26, 2012 12:01 pm    Post subject: AIRCAM Schematic or ideas Reply with quote
Obviously, this is a day, fair-weather, vmc fun
machine. There's no obvious value srtiving for
a very failure tolerant system. Suggest you wire
like figure Z16
http://tinyurl.com/7vp9g4e
Except you have two-fat wire feeders to the
starter contactors at the engines. These
same feeders just happen to be a good way
to bring each alternator in to the battery.
Run one alternator at a time with second
for back up.
Busy . . .
PostPosted: Wed Sep 26, 2012 3:17 pm    Post subject: AIRCAM Schematic or ideas Reply with quote
Thanks Bob, Z16 is where I was headed but wondered if I was missing something with "twin engines". Definitely not a machine with a need for complexity.
One clarification... when you say run one alternator at a time do you mean just switch one of the alternators off? How does keeping the designated backup off improve system reliability or procedures?
Busy is a good word for the Tecnam.
-Chris
PostPosted: Wed Sep 26, 2012 4:56 pm    Post subject: AIRCAM Schematic or ideas Reply with quote
for complexity.
Those alternators are designed to run in parallel on a
single bus. Given the sledge-hammer approach to voltage
regulation, it probably wouldn't hurt anything. At the
same time, if one alternator crapped and both were on,
you wouldn't get a low voltage warning annunciating
the failure. You might land with a dead alternator
and not know it until next preflight.
Better to run one alternator at a time. If it craps,
you've got a second alternator which you'll turn on
when the low voltage warning light flashes . . .
you DO plane active notification of low voltage?
PostPosted: Wed Sep 26, 2012 7:48 pm    Post subject: AIRCAM Schematic or ideas Reply with quote
CORRECTION
Those alternators are NOT designed to run in parallel on a
single bus.
PostPosted: Thu Sep 27, 2012 5:52 pm    Post subject: AIRCAM Schematic or ideas Reply with quote
Correction noted.
thanks
Chris
PostPosted: Fri Sep 28, 2012 7:53 am    Post subject: AIRCAM Schematic or ideas Reply with quote
At 08:51 PM 9/27/2012, you wrote:
Correction noted.
thanks
Chris
If it were my airplane . . .
http://tinyurl.com/cf2ppmx
http://tinyurl.com/cg8falj
PostPosted: Sat Sep 29, 2012 4:12 pm    Post subject: AIRCAM Schematic or ideas Reply with quote
Thank you Bob, that is very helpful. Can you explain what happens if the
"standby" alternator is activated while the "main" is active?
Chris
nuckollsr
PostPosted: Sat Sep 29, 2012 7:02 pm    Post subject: Re: AIRCAM Schematic or ideas Reply with quote
Probably nothing serious. But it might mask failure of one alternator when the second one shoulders the loads. A failure that become latent and unnoticed until next preflight. Better that you know it before you land as opposed to just before you wanted to take off.
PostPosted: Sun Sep 30, 2012 4:59 am    Post subject: AIRCAM Schematic or ideas Reply with quote
Right, but I was picking up on your comment that the "alternators are not
designed to run parallel on a single bus".
I have been wondering if there is a load sharing problem that would be
encountered or any other electrical gremlins I am not smart enough to know
about.
Chris
