Kolb Seat Question
Dennis Thate
PostPosted: Tue Sep 18, 2012 9:07 am    Post subject: Kolb Seat Question Reply with quote
In rough air I feel like I'm sliding around too much for comfort. I'm looking for a seat that conforms and supports the body better then just my flat seat. Anyone have any suggestions.
The Kolb seat in this photo looks Ideal.
 Filesize:  750.97 KB
 Viewed:  14283 Time(s)
phactor9
PostPosted: Tue Sep 18, 2012 10:37 am    Post subject: Kolb Seat Question Reply with quote
My solution? An ugly green $9.95 Walmart / KMart / Academy Sports bass boat seat trimmed of all ribbing and edging. This produces a nice rear-end-shaped bucket that the Kolb Firefly sling then supports quite nicely. Use four 1/4" blind nuts and bolts with metal straps underneath to fasten the shell to the lower seat bar on the Kolb cage. This actually aided in scooting me back an additional 5 - 6 inches (I'm 6' 7").
Then I bought some cheap naugahyde-like fabric and sewed a wedge shaped cushion with a zipper I then filled with extra firm foam, using Velcro to hold it to the seat.
http://phactor.com/BassSeat1.jpg
http://phactor.com/BassSeat2.jpg
Phil H.
FF11-4-76
--- On Tue, 9/18/12, Dennis Thate <retroman(at)frontier.com> wrote:
Subject: Kolb Seat Question
Date: Tuesday, September 18, 2012, 1:07 PM
--> Kolb-List message posted by: "Dennis Thate" <retroman(at)frontier.com (retroman(at)frontier.com)>
http://forums.matronics.com/viewtopic.php?p=383435#383435
http://forums.matronics.com//files/kolb_formed_seat_389.jp= --> http://www.matronics.com/Navigator?Kolb-List< -->
Dennis Thate
PostPosted: Tue Sep 18, 2012 11:41 am    Post subject: Re: Kolb Seat Question Reply with quote
Phil,
Great idea, I'll look into it, and thanks for posting the photos as well .
Carolina Flyer
PostPosted: Tue Sep 18, 2012 1:52 pm    Post subject: Re: Kolb Seat Question Reply with quote
That seat belongs to David LeGrand out of Winston Salem North Carolina. I know because I'm the 1 to turn him on to those seats and he uses them and all his Lazairs and Kolbs that he rebuilds. That seat is the buckets seat that is sold on Aircraft Spruce. it is all fiberglass. The seat cover comes from air-tech,... I would be using 1 of those seats myself but I'm a little too wide for it
Kolb Firestar II
503 C-Box / RK400
Soon to have a
Rotax 670 DCDI
with a C-Box and
RK 400 Clutch
Challenger II
503 Tall Drive
View user's profile Send private message Yahoo Messenger
Carolina Flyer
PostPosted: Tue Sep 18, 2012 1:58 pm    Post subject: Re: Kolb Seat Question Reply with quote
That seat belongs to David LeGrand out of Winston Salem North Carolina. I know because I'm the 1 to turn him on to those seats and he uses them and all his Lazairs and kolbs that he rebuilds. That seat is the buckets seat that is sold on Aircraft Spruce. it is all fiberglass. The seat cover comes from air-tech,... I would be using 1 of those seats myself but I'm a little too wide for it
Kolb Firestar II
503 C-Box / RK400
Soon to have a
Rotax 670 DCDI
with a C-Box and
RK 400 Clutch
Challenger II
503 Tall Drive
Dennis Thate
PostPosted: Tue Sep 18, 2012 2:27 pm    Post subject: Re: Kolb Seat Question Reply with quote
Hand layed up for extreme lightness. Wt. 3 lbs. 10 oz.
Thats it !
The below seat dimensions are as follows,
18" wide
21" high
16" deep.
Thanks C-Flyer
 Filesize:  10.69 KB
 Viewed:  14243 Time(s)
phactor9
PostPosted: Tue Sep 18, 2012 2:47 pm    Post subject: Kolb Seat Question Reply with quote
$9.95 ugly green Bass Boat seat (painted white), trimmed of all ribs and perimeter: 14oz. Hardware: probably one oz.
Phil H.
FF11-4-76
Subject: Kolb-List: Re: Kolb Seat Question
Date: Tuesday, September 18, 2012, 6:27 PM
--> Kolb-List message posted by: "Dennis Thate" <[url=/mc/compose?to=retroman(at)frontier.com]retroman(at)frontier.com[/url]>
Thats it !
Thanks C-Flyer
http://forums.matronics.com/viewtopic.php?p=383465#383465
http://forums.matronics.com//files/aircraft_spruce_144.jpg
[b]ht="http://forums.matronics.com" target="_blank">http://forums.matronics.; - List Contribution Web Site -
p; &nref="http://www.matronics.com/contribution" =======
jbhart(at)onlyinternet.ne
PostPosted: Tue Sep 18, 2012 4:05 pm    Post subject: Kolb Seat Question Reply with quote
Dennis,
I am six feet tall, but very short legs, so that the web seat installed as
it was designed for the FireFly did not allow me to reach the rudder pedals.
To slide my self closer to the rudder pedals, I removed the rivets that
attached the seat to the rear cross tube and tighten the lacing on the top
of the seat. This turned the seat into a true sling seat.
From this I discovered two things. It did slide me forward so that I could
reach the rudder pedals, but at the same time it allowed the lower cheeks to
swing from side to side, and the front seat cross tube cut into the back of
my legs. To remove pressure on the back of the legs, I installed a cheek
board with a memory foam cushion. The uncomfortable lower cheek swing was
controlled by tightening the seat belt.
Also, I use double shoulder belts. In rough air, I have found that I am
quite comfortable as long as my hips do not swing from side to side and my
shoulders do not come off the seat.
Jack B. Hart FF004
Winchester, IN
Richard Pike
PostPosted: Wed Sep 19, 2012 5:33 am    Post subject: Re: Kolb Seat Question Reply with quote
Or you could invest a lot more time, money, and effort and do one of these.
http://www.bcchapel.org/pages/0003/FSII%20seat%20page.html
Richard Pike
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
Dennis Thate
PostPosted: Wed Sep 19, 2012 8:34 am    Post subject: Re: Kolb Seat Question Reply with quote
Richard... that's very extravagant and nice.
I'm going to try this bass fish boat 3.5 pound Indestructible heavy duty plastic polyurethane contoured seat at only $11.96 on sale at Wal mart. I'll let you know how it works out. No more slip/sliding around in turbulence, I hope !
My Physique is a bit of a problem also. Wink
 Filesize:  76.31 KB
 Viewed:  14179 Time(s)
 Filesize:  34.99 KB
 Viewed:  14149 Time(s)
