duawil
Posted: Mon Sep 10, 2012 7:35 pm Post subject: Looking for recommendations for heated seats |
Would like to put heating elements in the seat back and seat bottom so my wife can stay warm. Looking for recommendations.
Bought a set from Warmseats.com, but they seem to be a little to large to lay completely flat on the foam between the cushion and the cover.
Thanks.
_________________ Building RV10. |
Strasnuts
Joined: 10 Feb 2009 Posts: 502 Location: Salt Lake City, UT
Posted: Mon Sep 10, 2012 8:16 pm Post subject: Looking for recommendations for heated seats |
I used warm seats on my 10 and they work great. I had Aerosport products do my seats and they were able to install them no problem.
On Sep 10, 2012, at 23:35, "duawil" <aaa(at)pacifier.com> wrote:
Thanks.
Building RV9A with Z-14
http://forums.matronics.com/viewtopic.php?p=382844#382844
_________________ 40936
RV-10 SB N801VR Flying
780 Hours
SuperSTOL 60 hours |
woxofswa
Posted: Mon Sep 10, 2012 11:42 pm Post subject: Re: Looking for recommendations for heated seats |
The gal at Flightline interiors sent me a link to some that she uses. I can't find it right off hand, but I'm sure she'd tell you.
_________________ Myron Nelson
Mesa, AZ
Flew May 10 2014 |
Posted: Tue Sep 11, 2012 3:24 am Post subject: Looking for recommendations for heated seats |
I got a set from Check corporation for my 6A - they're great. Three settings. I set up the wiring so the button is right next to the cabin heat valve on each side. Also wired it up so it is easily removeable for maintenance. DJ installed them when she built my seats.
johngoodman
Posted: Tue Sep 11, 2012 5:45 am Post subject: Re: Looking for recommendations for heated seats |
I got mine from Heated Seat Kits dot com:
http://www.heatedseatkits.com/heatedseatkits/index.html
I got them several years ago, and the prices have obviously gone up. I got the Seat Comfort Systems, but the others look good, as well.
I installed them myself using my seat covers from Abby at Flightline Interiors. They work great, but the lumbar support pad tends to limit the heat in the seat back. I put the buttons on the console between the seats. The relay for seat heat power is fairly large so I installed it underneath the passenger seat. That way, the quick disconnect plugs for the actual heaters can stay between the tunnel cover and the seat track, where they plug into the wires coming out of the tunnel.
John
_________________ #40572 Phase One complete in 2011 |
Posted: Tue Sep 11, 2012 6:05 am Post subject: Looking for recommendations for heated seats |
What does heated seats do for y'all? My perception is that we have an
excess of cabin heat for most conditions(?).
Is it primarily for startup? On for cruise? I assume one would not
have the battery power to pre-warm.
I've never had a car or anything with heated seats so I just don't
know. I'm sure northern ops are more of a challenge. I'm sure my
co-pilot would love me forever if her seat was warmed.
The temperature issue I need to address is a cold draft from rear to
the copilot seat. It seems to be from my unsealed baggage door. Anyone
have a good recommendation?
Bill Watson
michael(at)sausen.net Guest
Posted: Tue Sep 11, 2012 6:11 am Post subject: Looking for recommendations for heated seats |
Here is where I got mine from, Abby incorporated them no problem....
Michael
Posted: Tue Sep 11, 2012 6:29 am Post subject: Looking for recommendations for heated seats |
In my case, it was partially to accomodate my wife's back issue (lumbar). She has heated seats in her car which I have grown to appreciate.
Additionally, the excess heat is directed at the feet initially. My seat heaters allow me to run the cabin heat at a lower level until the entire cabin is warm while providing immediate comfort to the back/butt area.
Strasnuts
Posted: Tue Sep 11, 2012 6:38 am Post subject: Looking for recommendations for heated seats |
Those look just like my warm seats. We trimmed mine as well but only length wise not width wise.
On Sep 11, 2012, at 9:58, Bill Judge <bjudge(at)gmail.com (bjudge(at)gmail.com)> wrote:
[quote]I've got these in my RV-8, they work great and you can trim them:http://www.amazon.com/Setting-Universal-Carbon-Fiber-Heater/dp/B004JOBWZ0/ref=cm_cr_pr_product_top
Bill Judge
N84WJ, RV-8, 815 hrs
http://rv-8.blogspot.com/
780 Hours
duawil
Posted: Tue Sep 11, 2012 7:10 am Post subject: Re: Looking for recommendations for heated seats |
Thanks everyone for all the suggestions/info.
I am going ahead with the install of what I got from Flyboyaccessories.com after discussing it with Abby.
rv10flyer
Posted: Tue Sep 11, 2012 8:18 am Post subject: Re: Looking for recommendations for heated seats |
I have $650 in lightweight and warm cloth seats from a local upholstery shop. It is like A/C...nice to have, but is not necessary.
Bill, Ensure your baggage bulkhead corrugations are sealed off. Pick a cold morning and have someone ride in the back to altitude then leak check everything.
_________________ Wayne G. |
Posted: Tue Sep 11, 2012 9:38 am Post subject: Looking for recommendations for heated seats |
Ahh, yes. I forgot about the corrugations. Mine are covered but not
sealed. Will have to do a test flight.
Bill
On 9/11/2012 12:18 PM, rv10flyer wrote:
Wayne Gillispie
http://forums.matronics.com/viewtopic.php?p=382884#382884
Checked by AVG - www.avg.com
