Ribs pre-fluted?
PFolbrecht(at)starkinvest
PostPosted: Thu Jan 12, 2006 8:25 pm    Post subject: Ribs pre-fluted? Reply with quote
The ribs in my empennege kit, at least the HS ribs, all came pre-fluted. I did not think this was the norm - is it?? The job was done well enough that no additional work was necessary.
do not archvie
william(at)gbta.net
PostPosted: Thu Jan 12, 2006 9:02 pm    Post subject: Ribs pre-fluted? Reply with quote
I had some parts on my HS that were pre fluted also (I think they were the
ribs but cannot remember for sure).
Bill
dan(at)rdan.com
PostPosted: Thu Jan 12, 2006 9:18 pm    Post subject: Ribs pre-fluted? Reply with quote
I am at the rib stage of my -8 HS and they are not fluted , but appear to need very little fluting,
just working with them to make them the best I can,
Dan
-8
do not archvie
Michael Wynn
PostPosted: Thu Jan 12, 2006 10:17 pm    Post subject: Ribs pre-fluted? Reply with quote
Hi Paul,
I bought my tail kit about a year ago. Definitely not pre-fluted. I can't
imagine that they would take the time to do that. ? Pre-owned kit?
Michael Wynn
RV-8, Wings
San Ramon, California
Michael Wynn
RV 8
San Ramon, CA
smittysrv
PostPosted: Fri Jan 13, 2006 5:10 am    Post subject: Ribs pre-fluted? Reply with quote
I'm not surprised. Vans seems to make constant improvements as far as ease
of construction. The instructions on my RV-9A tail kit said that the
elevator horns had to "aligned" for drilling into the spar and end rib
since the holes are not pre-drilled in the spar and rib. Went I went to do
this part, I found that the holes were already drilled. COOL!
Smittys RV-9A
http://SmittysRV.com
do not archvie
Smittys RV-9A
SmittysRV.com
Mike Crowe
PostPosted: Fri Jan 13, 2006 6:53 pm    Post subject: Re: Ribs pre-fluted? Reply with quote
I work at Alexander Tech Center as an instructor on the tail kit program.
Some of the RV9 and RV10 HS ribs come fluted.
Mike Crowe
PostPosted: Fri Jan 13, 2006 8:27 pm    Post subject: Ribs pre-fluted? Reply with quote
It was not a pre-owned kit. I bought it in June, actually, but had to take a 5.5 month hiatus from the project.
~Paul
~9A QB #1176 Enjoying every minute of it so far.
