chevybowtieracing(at)yaho Guest
Posted: Thu Aug 30, 2012 8:09 pm Post subject: Aluminum gear with 5/8 axles |
I am new to the Kolb business we bought a mkIIIc a few mouths ago, I am a little disappointed with the landing gear we have the aluminum legs with 5/8 axles the tires are 600*6 6 ply. Noticed the pilot tire toed out a little need to keep eye on this right! First flight no problem landed find, second flight the axle bent more so I order a new. In the mean time reading in the list found that it is ok to straight them one time so I did look better than when we bought it time to test it out and keep in mind it is weaker now so it will bend easier. After a few fly by's time to land one notch of flaps air speed 50 1/4 of power I got a little fast about three feet off kill the power level off air speed about 45 touch down pow! Left tire flies off right rudder right brake left leg is off the ground that's good slow down and keep the three points down almost stop left starting to dig in and pull to the left stuck in the soft dirt on the side of the runway nose over just a little kill engines and fuel. That could have been really bad I'm not hurt insect the plane nothing but one broken axle oh the propeller is partly missing the tire hit it and my wife got it all on tape. Lesson will not be straightening an more axles. Sorry for going on and on. We have installed a new factory axle in hopes this will never happen again. In reading on this list sounds like axles bending is quite normal i don't like that idea some time you just don't have glass landing it just the facts none of the landings were pancakes. How much better is the 4130 leg and are the axles replaced with larger diameter are are they the same 5/8"?
rickofudall
Posted: Thu Aug 30, 2012 9:30 pm Post subject: Aluminum gear with 5/8 axles |
Mark, I bent and straightened the aluminum gear legs on my Mk III quite a few times, but I never bent an axle. Keep with it and soon you will grease it on every time.The steel gear legs use the same size axle. It's dictated by the size of bearings the wheel manufacturers use.
Rick Girard
On Thu, Aug 30, 2012 at 11:07 PM, Mark <chevybowtieracing(at)yahoo.com (chevybowtieracing(at)yahoo.com)> wrote:
| Quote: | --> Kolb-List message posted by: Mark <chevybowtieracing(at)yahoo.com (chevybowtieracing(at)yahoo.com)>
I am new to the Kolb business we bought a mkIIIc a few mouths ago, I am a little disappointed with the landing gear we have the aluminum legs with 5/8 axles the tires are 600*6 6 ply. Noticed the pilot tire toed out a little need to keep eye on this right! First flight no problem landed find, second flight the axle bent more so I order a new. In the mean time reading in the list found that it is ok to straight them one time so I did look better than when we bought it time to test it out and keep in mind it is weaker now so it will bend easier. After a few fly by's time to land one notch of flaps air speed 50 1/4 of power I got a little fast about three feet off kill the power level off air speed about 45 touch down pow! Left tire flies off right rudder right brake left leg is off the ground that's good slow down and keep the three points down almost stop left starting to dig in and pull to the left stuck in the soft dirt on the side of the runway nose over just a little ki!
http://forums.matronics.com
le, List Admin.
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
- Groucho Marx
elleryweld(at)aol.com Guest
Posted: Fri Aug 31, 2012 2:06 am Post subject: Aluminum gear with 5/8 axles |
the solid axles are a lot stronger also
Ellery Batchelder Jr.
russk50(at)gmail.com Guest
Posted: Fri Aug 31, 2012 4:08 am Post subject: Aluminum gear with 5/8 axles |
Mark
Sorry for your troubles but you did everything right! Congratulations.
I'm sure we'd all love to see this tape -- can you post it?
Russ K
On Aug 31, 2012, at 12:07 AM, Mark wrote:
Posted: Fri Aug 31, 2012 8:07 am Post subject: Aluminum gear with 5/8 axles |
| Quote: | From: Mark <chevybowtieracing(at)yahoo.com (chevybowtieracing(at)yahoo.com)>
Date: August 31, 2012 9:27:17 AM CDT
To: Kolb-List Digest List <kolb-list-digest(at)matronics.com (kolb-list-digest(at)matronics.com)>
Subject: Re: Re: Aluminum gear with 5/8 axles
I am a little
bent more so I order a new. Lesson will not be straightening an more axles. We have installed a new factory axle in hopes this will never happen
It could be that the axle has already been straighten and was brittle to make it snap, it broke right were the brake plate was welded on to the axle. The legs are fine at this time we plan on trying it with the new axle and hope for better results. We bought the mkIIIc for fun it's not very fun if your always replacing and repairing things that breaks when they shouldn't. I would like to find out more about the upgraded 4130 gear and how well it holds up. I saw were John H put 3/4 axles on his mkIIIc I am interested in this would like more info on how this was done. Thanks for the info.
| Sorry not able post the video to the list
Dennis Thate
Posted: Sat Sep 01, 2012 7:21 am Post subject: Re: Aluminum gear with 5/8 axles |
chevybowtieracing ...it happens to best of us . Hang in there!
57.88 KB |
7108 Time(s) |
_________________ Both optimists and pessimists contribute to our society. The optimist invents the airplane and the pessimist the parachute. ~Gil Stern |
Posted: Sat Sep 01, 2012 3:09 pm Post subject: Aluminum gear with 5/8 axles |
Mark
Russ K
