RotaxEngines-List Digest: 3 Msgs - 08/25/12
rparigoris
PostPosted: Sun Aug 26, 2012 7:48 am    Post subject: RotaxEngines-List Digest: 3 Msgs - 08/25/12 Reply with quote
Hi Damien
"I have been told that this crankcase fretting sometimes happens in the early model engines, such as mine."
I can understand that fretting on the crankcase can cause oil leaking, but in your case did it cause you to not be able to turn your prop?
Thx.
Ron Parigoris
Dick Maddux
PostPosted: Mon Aug 27, 2012 4:55 am    Post subject: RotaxEngines-List Digest: 3 Msgs - 08/25/12 Reply with quote
Ron,
I believe after reaching into the fog of my mind that the engine does not have bearings as such. The crank shaft rides in the case and if the two pieces "rub" together eventually the crankshaft will not be able to turn as the"bearing holes" for the crankshaft get smaller thus squeezing the crankshaft .
Don't quote me now, but I believe that is the reason
      Dick Maddux
      912 UL (old one and so far so good)
Thom Riddle
PostPosted: Tue Aug 28, 2012 2:31 am    Post subject: Re: RotaxEngines-List Digest: 3 Msgs - 08/25/12 Reply with quote
Dick,
The camshaft turns in a bore in the crankcase halves without bearings, but not so the crankshaft, which does have bearings, much like many automotive engines.
Thom Riddle
Buffalo, NY (9G0)
- Anonymous
