Posted: Fri Aug 24, 2012 10:04 am Post subject: Resuscitating the Tripplet 630 |
After my reply on this thread, I was recalling some
features of the 630 buried pretty deeply in the grey-matter.
I dug mine out and pulled the case off.
Replacing JUST the one battery is still a good idea but
the cell is 'captured' into position in the battery box
by the case. Proper retention of the battery depends on
the HV battery being installed.
Looking at this configuration sparked an idea that was
easy to implement and worked around the fixture problem.
I cut a couple 3/4" pieces of hobby shop brass with a 9/16" i.d. 19/32" o.d.
[img]cid:.0[/img]
Tape one piece to the (-) end of AA cell so that you have
a recess about 1/8" deep. Tape the other piece to the (+)
end looking for a recess about 1/2" deep. Make a conductive
"plug" to drop into the (+) cavity. Here's a quick-n-dirty
pair of nuts on a 10-32 screw and trimmed flush with a
Dremel.
[img]cid:.1[/img]
Drop the "plug" into the (+) end and place it between
the cell contacts of the 630
[img]cid:.2[/img]
This configuration captures the cell between the contacts even
though the hv battery is not present.
Also, I'm pleased to report that the single AA cell excites ALL
resistance ranges EXCEPT the highest range. A little time
on the lathe could produce adapters fitted more closely
to the dimensions of the AA cell and the mating contacts
on the 630. A pleasant distraction . . .
Another approach would be to make a 'plug' from plastic or
wood that emulates the shape of the 30v battery. You'd want
holes in both ends to clear the 630's battery contacts. Then
use the standard C-cell and exploit the original design
goals for cell retention.
Depending on how determined you are to get it all up and
running, there is sufficient volume inside to house three 9v
alkaline batteries. One where the 30v goes, two on each end
of the battery box over the fuses. A bit of wire, some tack
soldering and double-sided tape for battery retention
could give you a 27v 'work-around' that should bring the
x100K range back to life as well.
Bit lots sells an alkaline 9v for $2 or less.
Bottom line is that there may still be more years of useful
utility left in your venerable ol' workhorse. Working the
flight line at Boeing, the Simpson 260 was all the tool
cribs stocked. We fixed a lot of airplanes with this genere'
of measurement tools.
113.96 KB |
4981 Time(s) |
64.77 KB |
4981 Time(s) |
167.55 KB |
4981 Time(s) |
raymondj(at)frontiernet.n Guest
Posted: Fri Aug 24, 2012 7:52 pm Post subject: Resuscitating the Tripplet 630 |
Bob,
I replied to your 1st post before I read the 2nd. I can get 10
Panasonic 2450 lithium cells for $12 and I'll machine a little case to
make them fit in the 30V position. I think that should take care of it.
I don't know why, but I just like seeing the needle move. Much more
satisfying then the LCD numbers. Too many sci-fi movies when I was young.
Thanks again.
Raymond Julian
Kettle River, MN.
"And you know that I could have me a million more friends,
and all I'd have to lose is my point of view." - John Prine
On 08/24/2012 01:02 PM, Robert L. Nuckolls, III wrote:
| Quote: | After my reply on this thread, I was recalling some
Emacs!
Dremel.
Emacs!
Emacs!
BobsV35B(at)aol.com Guest
Posted: Sat Aug 25, 2012 4:51 am Post subject: Resuscitating the Tripplet 630 |
Good Morning Jeff,
Just waxing nostalgic I guess.
I have a Simpson 260 in one of those beautiful sliding cover cases that I just cannot let go. I also have several Fluke 77s around. However, the 260 has a place of honor on my work bench. It just LOOKS like an instrument ought to look.
Happy Skies.
Very Old Bob
In a message dated 8/24/2012 11:04:24 P.M. Central Daylight Time, JLuckey(at)pacbell.net writes:
When my dad passed away last year I inherited a lot of old electrical equipment, including a 630.
Finding that meter while sorting thru his stuff brought back lots of memories of futzing w/ batteries, lamps & alligator clips as a kid – funny what you remember…
Using 3 9-volters to replace the big battery is a great idea – glad to hear that 27 volts is enough.
Lots of people, especially younger ones, would just throw-away something like this but I find it strangely satisfying to keep an older, good-quality instrument in service, even if it requires a little engineering. Is that due to age or wisdom???
Pardon the philosophical observations,
-Jeff
Posted: Sat Aug 25, 2012 6:41 am Post subject: Resuscitating the Tripplet 630 |
At 05:48 AM 8/25/2012, you wrote:
| Quote: | I'm gonna have to side with Eric on this one. I think you guys are
in a nostalgia induced somnambulism that results in tons of
worthless cr*p laying around the house. By worthless, I mean things
that you will never use again. You'll just walk by it and admire it
occasionally as you worm your way through the make shift aisles to
the kitchen for yet another Ruben sandwich. Some people call it hoarding.
What's this about taking sides? If
anything, this thread has been a cognizant
observation of what these tools represent
in utility, history, and teaching value.
I don't think anyone has suggested that the
260/630 genre' of tools is a substitute for
modern digital instruments. At the same time,
there are things an analog instrument will do
for the observer that a digital instrument cannot.
I still have a lot of vacuum tube era parts
and tools. It is my plan to use them as teaching
tools for my grandchildren . . . assuming they're
interested. Building a vacuum tube receiver or
transmitter requires some skill development in
schematic reading, stripping wire, soldering,
chassis layout, punching/drilling holes, winding
coils (after we calculate how big they should
be), measuring voltages and currents (yes, the
630 will do nicely).
Something a vacuum tube offers that a transistor
can never offer is that you can take it apart.
Hold, feel and see the pieces. Imagine the
boiling of electrons off a hot cathode for
launching toward plate. This, like the experiments
of Hertz, Helmholtz, Faraday, Volta, Ampere, et. als.
is hands-on, see-it, feel-it physics.
At the other end of the spectrum, programming a
micro-controller is a purely intellectual exercise
that has nothing to do with electronics . . . but
without it, you cannot exploit the value that
electronics can deliver. They are joined at the
hip. The elegant solutions are achieve a working
understanding of both.
When I was in high school, the school board
was participating in a dual-track science education
experiment. One group of students took chemistry
and physics in the contemporary setting while
another group studied using more 'modern aids'
like films and 'less sophisticated' and hardware-
store/lumber-yard tools and materials. This was
carried out in two Wichita high schools. The
question to be answered was, "Can science be
adequately taught in less endowed schools using
more rudimentary tools and processes?"
Don't know how powers-that-be viewed the
outcome of the studies for teaching methods.
I took the experimental course in chemistry.
I found out from my chemistry teacher years
later that I made the highest score in Wichita
going in, and the highest score coming out.
I can personally attest to the fact that the
shiny tools and latest processes do not drive
the outcome of a teaching process so strongly
as modern 'educators' would have us believe.
I think the point of this discussion is to
explore the physics and utility of any tool
for understanding and without prejudice for
it's less than modern shortcomings. Would
you similarly denounce a builder's choice to
build a replica J-3 as opposed to a Sonex?
If this discussion was about applying modern
materials and systems to a 1940's restoration,
would you decry the effort as whipping a
dead horse? As one of my heros, Richard Feynman
suggested in the tile of his book, there is
a lot of pleasure to be gained from finding
things out.
http://www.youtube.com/watch?v=Bgaw9qe7DEE&feature=related
Those who do not find pleasure in such endeavors
are certainly free to focus their efforts elsewhere
but let us refrain from obstructing the pleasure
of others.
Posted: Sat Aug 25, 2012 7:17 am Post subject: Resuscitating the Tripplet 630 |
At 04:38 PM 8/24/2012, you wrote:
Bob,
to make them fit in the 30V position. I think that should take care of it.
Cool. Send me some pix.
Bob McC
Posted: Sat Aug 25, 2012 7:23 am Post subject: Resuscitating the Tripplet 630 |
While the modern digital instruments can be inexpensive and exceedingly accurate, sometimes that accuracy can be an issue especially when dealing with changing values. Trying to visualize constantly changing numbers or even read their value if the changes are rapid can be very frustrating, sometimes impossible. The old analogue instruments, while they may not read to the ultimate resolution, average changing values very well and in that dynamic situation, where the digital is useless, can give a nice, relatively stable, easy to see, reading. If what you’re looking for is a steadily falling or rising value, then the analogue will show a nice steady needle movement (or an erratic one to show a not-so-steady change) whereas the rapidly changing numbers on a digital display don’t help. You’ll have almost no idea of what is going on. (Measuring the resistance of a potentiometer with both a digital and an analogue meter while smoothly turning the shaft from one extreme to the other to determine if there are any dead spots or if the pot is a linear or logarithmic taper for instance will quickly show the superiority of the analogue meter. If you want to know the precise value of a fixed resistor then the digital will be superior)
In short both types are useful. Sometimes the digital is better, sometimes the analogue beats it by a mile. As in most things - - “It depends”
Only my .02¢ opinion
Bob McC
_________________ Bob McC
Falco #908
(just starting) |
Posted: Sat Aug 25, 2012 7:43 am Post subject: Resuscitating the Tripplet 630 |
Well, by your definition: "just walk by it and admire it occasionally"
makes it cr*p. All art is cr*p. Gotta disagree.
I'll say no more on this topic because it doesn't further electron
herding skills.
Thanks to everyone for sharing their opinions.
Raymond Julian
Kettle River, MN.
On 08/25/2012 05:48 AM, Henador Titzoff wrote:
| Quote: | I'm gonna have to side with Eric on this one. I think you guys are in a
nostalgia induced somnambulism that results in tons of worthless cr*p
laying around the house. By worthless, I mean things that you will never
use again. You'll just walk by it and admire it occasionally as you worm
your way through the make shift aisles to the kitchen for yet another
Posted: Sat Aug 25, 2012 7:52 am Post subject: Resuscitating the Tripplet 630 |
Will do, but it'll be a while before it makes it to the top of my
priority list, so don't hold your breath.
Raymond Julian
Kettle River, MN.
On 08/25/2012 10:16 AM, Robert L. Nuckolls, III wrote:
<nuckolls.bob(at)aeroelectric.com>
> Bob,
Posted: Sat Aug 25, 2012 8:47 am Post subject: Resuscitating the Tripplet 630 |
At 10:52 AM 8/25/2012, you wrote:
Understand. My do-do list is immeasurable and constantly
getting stirred by a 'pleasurable curiosity' of the moment
. . . I readily confess to being ADD on a grand scale.
It probably frustrated my teachers but since I wasn't disruptive,
they left me alone to suffer my intellectual chaos in
private. So back to the sheet rock and plumbing task at
hand . . .
JLuckey(at)pacbell.net Guest
Posted: Sat Aug 25, 2012 8:48 am Post subject: Resuscitating the Tripplet 630 |
Bob,
There was a Simpson 260 in my dad’s stuff as well – in the same kind of case as you describe. I think it will get a place of honor on the test bench, too.
Just for grins I looked on ebay: they go for $20-$200. Does anyone remember what they sold for new?
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of BobsV35B(at)aol.com
Sent: Saturday, August 25, 2012 05:50
Subject: Re: AeroElectric-List: Resuscitating the Tripplet 630
Good Morning Jeff,
Happy Skies.
Very Old Bob
-Jeff
Checked by AVG - www.avg.com
08/24/12 [quote][b]
Posted: Sat Aug 25, 2012 9:24 am Post subject: Resuscitating the Tripplet 630 |
At 11:48 AM 8/25/2012, you wrote:
| Quote: | Bob,
Just for grins I looked on ebay: they go for $20-$200. Does anyone remember what they sold for new? |
Yup, at least in 1961 both the Tripplet 630 and Simpson 260 sold for
about $70. That's about $500 in today's dollars. It was a week's
wages for me at my first job in aviation at Boeing.
Bob . . . [quote][b]
Posted: Sun Aug 26, 2012 6:58 am Post subject: Re: Resuscitating the Tripplet 630 |
| Quote: | I'm gonna have to side with Eric on this one. I think you guys are in a nostalgia induced somnambulism that results in tons of worthless cr*p
Ruben sandwich. Some people call it hoarding. |
I think the above post was written with tongue in cheek. I thought it humorous. As I make my way though the makeshift isles in my house to the garage, I have to be careful not to knock over the nicknacks that my wife has sitting on every available horizontal surface in the house. Talk about worthless stuff that that some people might admire, but to me it is junk that is in the way. However, the "STUFF" in my workshop is not junk, even though I do not use some of it. There is the EICO Model 232 VTVM that I assembled from a kit way back in the 60s. And of course there is the Simpson 260 and another analog meter and 5 digital meters of various capabilities. And there is a HeathKit capacitance meter that I put together. One of the digital meters has taken over its duties.
Joe
_________________ Joe Gores |
henador_titzoff(at)yahoo. Guest
Posted: Sun Aug 26, 2012 5:28 pm Post subject: Resuscitating the Tripplet 630 |
--- On Sat, 8/25/12, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com> wrote:
things out.
Of course you are correct that we should be free to choose what gives us the most pleasure in life. Certainly the Tripplet meters are great instruments; however, I was responding to the original sender's question about whether it worth resuscitating the meter with a hard to find battery or go with a newer meter for modern day usability. His question didn't talk about having museum pieces on top of lab workbenches or collecting meters for the heck of it. He was concerned about what instrument to use for troubleshooting purposes today, not back in the 1950s-60s.
If I misunderstood the original question and/or offended anyone on this list, I extend my apologies to these people.
I also think there is value in looking at vacuum tubes and other electronics as I believe it helps to understand all technologies; however, the days of simple vacuum tubes are over as far as I can tell. I now get very good insight on the electronics of today by using tools that allow me to "see" what's going on with highly sophisticated electronic systems and products, I use PSpice, MG HyperLynx, Ansys HFSS and several vendors' HDL simulators to get a darn good idea of what's going on where we can't visually see what's going on. I believe I said it here before that all this black magic stuff may be black magic to many, but to us guys who have these tools and know how to use them, it's not. I even know guys who are way better than I am who don't need some of these tools. For example, they know magnetic fields so well they can "see" them without HFSS. Same with the guys who don't need PSpice other than to prove to others are correct. These guys are few and far between, but they're out there. Most of them are older like the Tripplet meters, so I do understand to some degree why some contributors to this list admire Tripplets immensely.
I'm now like the previous contributor who said he wants to get back to herding electrons, except I want to herd holes, too. Like him, this is my last contribution to this thread.
Everyone have a great week!
Henador Titzoff
