Lynn Matteson
Posted: Wed Aug 22, 2012 6:20 am Post subject: Newest GAMI lean test...probably off-topic for most |
I hadn't done a Gami Lean Test since I first installed my Rotec TBI
back in 2009, and so yesterday and today I did another few tests.
Back when I first installed the TBI, the Gami spread was 0.1 on one
test, and two other tests showed a 0.3 spread. This was done using
the Jabiru intake manifold and the rubber tube connecter. Thinking
back, the 0.1 might have been a fluke, or bad reading. Since then, I
had built three different intake manifolds out of aluminum tubing and
plate, using different configurations...updraft, backdraft, etc. The
latest manifold is a "ram induction" manifold with runners 19" long.
I've had this one on for about 16 months.... 236 hours flying time.
Because things were going well with this manifold, I had just
forgotten about actually giving the engine the Gami lean test.
Over the last two days, the tests, at 7000 feet yesterday, and 3300
feet today (MSL), all showed a spread of 0.1......from 2.8 gph to 2.7
gph at 2900 rpm and 7000 feet, and 3.4 to 3.3 gph at 2900 rpm at 3300
feet. During these tests, when going from one fuel flow reading to
0.1 less fuel...leaner....all four EGT readings would drop at the
same time. They would be stabilized at one fuel flow setting, and
about a half-turn of the vernier mixture knob, and all four would
start dropping....every time. So this latest manifold is a keeper, as
far as distributing fuel is concerned.
And that is probably the reason that I can dawdle along, burning as
low as 2.5-2.6 gph and the engine still lives...knocking on wood!
Lynn Matteson
Jabiru 2200, #2062
Prince prop 64 x 30, P-tip
Rotec TBI-40 injection (sleeved to 36mm)
Status: flying with 1336 hrs... (since 3-27-2006)
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
marvinlnaz(at)yahoo.com Guest
Posted: Wed Aug 22, 2012 7:34 am Post subject: Newest GAMI lean test...probably off-topic for most |
OK Lynn, I'll bite. Tell us 'dummies' exactly how you performed your GAMI Lean Tests. Sounds interesting. Also, how about some photos of your latest intake system.
Nice to hear from you.
Marvin
To: jabiruengines(at)yahoogroups.com; jabiruengine-list(at)matronics.com
Sent: Wednesday, August 22, 2012 7:19 AM
Subject: Newest GAMI lean test...probably off-topic for most
--> JabiruEngine-List message posted by: Lynn Matteson <lynnmatt(at)jps.net (lynnmatt(at)jps.net)>
I hadn't done a Gami Lean Test since I first installed my Rotec TBI back in 2009, and so yesterday and today I did another few tests. Back when I first installed the TBI, the Gami spread was 0.1 on one test, and two other tests showed a 0.3 spread. This was done using the Jabiru intake manifold and the rubber tube connecter. Thinking back, the 0.1 might have been a fluke, or bad reading. Since then, I had built three different intake manifolds out of aluminum tubing and plate, using different configurations...updraft, backdraft, etc. The latest manifold is a "ram induction" manifold with runners 19" long. I've had this one on for about 16 months.... 236 hours flying time. Because things were going well with this manifold, I had just forgotten about actually giving the engine the Gami lean test.
Over the last two days, the tests, at 7000 feet yesterday, and 3300 feet today (MSL), all showed a spread of 0.1......from 2.8 gph to 2.7 gph at 2900 rpm and 7000 feet, and 3.4 to 3.3 gph at 2900 rpm at 3300 feet. During these tests, when going from one fuel flow reading to 0.1 less fuel...leaner....all four EGT readings would drop at the same time. They would be stabilized at one fuel flow setting, and about a half-turn of the vernier mixture knob, and all four would start dropping....every time. So this latest manifold is a keeper, as far as distributing fuel is concerned.
And that is probably the reason that I can dawdle along, burning as low as 2.5-2.6 gph and the engine still lives...knocking on wood!
Lynn Matteson
Jabiru 2200, #2062
Status: flying with 1336 hrs... - The JabiruEngine-List Email Forum -http://www.matronics.com/Navigat= - MATRONICS WEB FORUMSList ====
Lynn Matteson
Posted: Wed Aug 22, 2012 9:53 am Post subject: Newest GAMI lean test...probably off-topic for most |
Hi Marvin-
I wish I had taken better pictures, but these two pretty much show
what I did. When I was building it, I was thinking of having the
tubes go through a chamber that would have engine oil pumping through
it, but later decided against that and sawed off some of the "oil
box". In this picture, the box is still partly there. I would have
had to finish enclosing the box...a HUGE job, so I quit thinking
along those lines. The actual intake plenum is the trapezoid-shaped
box immediately in front of (to the left) the TBI. The rest of the
box...like where the bolt heads are showing, was to be the oil box.
This shot shows the basic tubes completed, and I'm just starting to
build the plenum box around the tubes. From looking at these shots, I
can see that I need to take some better pictures of the final product.
As far as the Gami lean test is concerned, you start with a rich
mixture, and then start to lean the engine in small increments,
according to the fuel flow meter, watching the EGT readouts. The
temperatures will rise as the engine is leaned, and then you will see
the EGT's reach a peak temperature, and further leaning will cause
the temperatures to start to drop. Normally this "peak and drop" will
happen one cylinder at a time, over the course of leaning in very
small increments....in my case I was leaning by 0.1 gph according to
the flow meter. When I did this test back in 2009 right after I
installed the TBI, (and using the original Jabiru manifold) the rear
two cylinders peaked first, then one of the fronts, and finally the
last one peaked. This was over the course of leaning that covered a
0.3 gph range. On a small engine like the Jabiru 4-cylinder, that
shows that the fuel distribution in the intake manifold is not real
good, but not terrible, either. But with the current manifold that I
built, the EGT's will peak, and the next 0.1 gph reduction in flow
(leaning), causes them all to start dropping right now. This shows
excellent fuel distribution according to the Gami method of lean
testing. The writings of people that I have read....John Deakin, Mike
Busch, to name a couple...say that most carbureted engines don't have
very good fuel distribution, so I'm pretty tickled with my results.
The address for the lean test is: http://www.gami.com/gamijectors/
leantest.php
Some interesting reading about engine operation is found in John
Deakin's writings. Here is the address for a complete index of his
articles, Pelican's Perch:
http://www.avweb.com/news/pelican/182146-1.html
Lynn Matteson
Jabiru 2200, #2062
On Aug 22, 2012, at 11:03 AM, Marvin Williams wrote:
| Quote: | OK Lynn, I'll bite. Tell us 'dummies' exactly how you performed
Marvin
418.32 KB |
19899 Time(s) |
369.02 KB |
19899 Time(s) |
N369LM |
kayberg(at)aol.com Guest
Posted: Wed Aug 22, 2012 1:03 pm Post subject: Newest GAMI lean test...probably off-topic for most |
Glad to hear things are going well for you, Lynn. Others have not been so lucky with the Rotec contraption. At least two other people that I know have tried the Rotec and tossed it. Granted, it was the 3300 Jab, but the engines never ran right and were not reliable enough to fly with.
To others who are considering the Rotec, be prepared to work your way thought some disappointment.
In my opinion.
Doug Koenigsberg
Posted: Wed Aug 22, 2012 1:15 pm Post subject: Newest GAMI lean test...probably off-topic for most |
I have been satisfied with my Rotec on theJabiru 3300.
Installation needs to be as specified.
Marvin
Sent from my "Geeky" iPhone
On Aug 22, 2012, at 2:02 PM, kayberg(at)aol.com (kayberg(at)aol.com) wrote:
[quote] Glad to hear things are going well for you, Lynn. Others have not been so lucky with the Rotec contraption. At least two other people that I know have tried the Rotec and tossed it. Granted, it was the 3300 Jab, but the engines never ran right and were not reliable enough to fly with.
In my opinion.
Doug Koenigsberg
Posted: Wed Aug 22, 2012 4:04 pm Post subject: Newest GAMI lean test...probably off-topic for most |
Thanks Lynn and Barry.
I assume that added volume in the intake system is one of the reasons you have had success Lynn? The Jabiru intake 'manifold' sure doesn't have the volume that it looks like yours has. Seems that your pipes to the heads are bigger also. Am I wrong?
I read the GAMI lean test article. Seems to me that this test replaces the EGT spread criteria for proper cylinder balance. Again, is that what you discern?
The article talked about an engine having a fuel flow spread of .7 gph after GAMIs are installed. I just wonder what the full fuel flow rate is? If it's 15-17 GPH then the flow rate spread would be approximately 5% of total flow rate. I am no where smart enough to know what is good and what isn't. I'll just have to take the 'big boys' word for it. But I do find it interesting that EGT spread isn't talked about much anymore. Or did I just miss it?
FWIW, I had GAMIs installed on my Mooney TLS (TIO 540 as I recall) a long time ago. For what it cost at the time, I didn't think it was worth it. I'll be quick to add that technology has changed (improved) more than I know since then, and perhaps I myself am a little (but not much) wiser now than I was then and it just might be that I would recognize the improvement more now than then. All conjecture obviously.
Fortunately, now that I have been introduced to Fuel Spread tests, I can easily run the test on our Jabiru 3300 with the engine analysis and recording equipment we have, it should be a snap. Fixing (or improving) the issues will be the challenge.
Thanks again for the pictures and your post!
Marvin
Sent: Wednesday, August 22, 2012 10:46 AM
Subject: Re: Newest GAMI lean test...probably off-topic for most
Hi Marvin-
I wish I had taken better pictures, but these two pretty much show what I did. When I was building it, I was thinking of having the tubes go through a chamber that would have engine oil pumping through it, but later decided against that and sawed off some of the "oil box". In this picture, the box is still partly there. I would have had to finish enclosing the box...a HUGE job, so I quit thinking along those lines. The actual intake plenum is the trapezoid-shaped box immediately in front of (to the left) the TBI. The rest of the box...like where the bolt heads are showing, was to be the oil box.
[img]cid:1.448378916(at)web140805.mail.bf1.yahoo.com[/img]
[img]cid:2.448378917(at)web140805.mail.bf1.yahoo.com[/img]
This shot shows the basic tubes completed, and I'm just starting to build the plenum box around the tubes. >From looking at these shots, I can see that I need to take some better pictures of the final product.
As far as the Gami lean test is concerned, you start with a rich mixture, and then start to lean the engine in small increments, according to the fuel flow meter, watching the EGT readouts. The temperatures will rise as the engine is leaned, and then you will see the EGT's reach a peak temperature, and further leaning will cause the temperatures to start to drop. Normally this "peak and drop" will happen one cylinder at a time, over the course of leaning in very small increments....in my case I was leaning by 0.1 gph according to the flow meter. When I did this test back in 2009 right after I installed the TBI, (and using the original Jabiru manifold) the rear two cylinders peaked first, then one of the fronts, and finally the last one peaked. This was over the course of leaning that covered a 0.3 gph range. On a small engine like the Jabiru 4-cylinder, that shows that the fuel distribution in the intake manifold is not real good, but not terrible, either. But with the current manifold that I built, the EGT's will peak, and the next 0.1 gph reduction in flow (leaning), causes them all to start dropping right now. This shows excellent fuel distribution according to the Gami method of lean testing. The writings of people that I have read....John Deakin, Mike Busch, to name a couple...say that most carbureted engines don't have very good fuel distribution, so I'm pretty tickled with my results.
The address for the lean test is: http://www.gami.com/gamijectors/leantest.php
Some interesting reading about engine operation is found in John Deakin's writings. Here is the address for a complete index of his articles, Pelican's Perch:
Lynn Matteson
Jabiru 2200, #2062
| Quote: | OK Lynn, I'll bite. Tell us 'dummies' exactly how you performed your GAMI Lean Tests. Sounds interesting. Also, how about some photos of your latest intake system.
Marvin
418.32 KB |
19895 Time(s) |
369.02 KB |
19895 Time(s) |
Lynn Matteson
Posted: Wed Aug 22, 2012 4:37 pm Post subject: Newest GAMI lean test...probably off-topic for most |
That's too bad that those owners didn't have whatever it took to deal
with the proper installation, Doug. I've heard of a few who didn't
get it right the first time, but they got help, and are now flying
with it just fine. All these installations have to follow the
suggestions made by the factory...I'm wondering if they did?
Lynn Matteson
Jabiru 2200, #2062
On Aug 22, 2012, at 5:02 PM, kayberg(at)aol.com wrote:
| Quote: | Glad to hear things are going well for you, Lynn. Others have not
In my opinion.
Doug Koenigsberg
N369LM |
Lynn Matteson
Posted: Wed Aug 22, 2012 5:04 pm Post subject: Newest GAMI lean test...probably off-topic for most |
The larger plenum is probably part of the reason, Marvin. The tubes
are the same size as the original...1-1/4" O.D. I built the longer
tubes to take advantage of the "ram" effect, and that might be part
of the reason as well. Perhaps the longer tubes allow for more time
for the mixture to atomize, and this makes for a smoother-running
engine.
No, this is exactly the same test. All you are doing in this test is
verifying that the fuel flow difference between when the first
cylinder's EGT peaks, and the last cylinder's EGT peaks, is very,
very close. That determines how well the engine's air/fuel mixture is
distributed to the engine. If the first to peak is at say, 3.5 gph,
and the last to peak does so when the flow meter reads 3.0 gph,
that's a "GAMI spread" of a half-gallon per hour, and that is not
good distribution. If this were a direct-port injected engine, the
injector nozzles would be changed to bring the flow closer together
between the first, and the last, to reach peak EGT. This is what the
folks at GAMI do. But my engine, using a Rotec TBI, is basically a
carbureted engine, and you can't change individual nozzles like you
can with the direct-port engines.
The EGT spread is still talked about, but not the actual numbers from
what I've read. First you have to get the flow spread as close as
possible, then when that is done, then you can safely run lean of
peak EGT, knowing that each cylinder is enjoying very close to the
optimum share of the fuel/air mixture. If the flow spread is too far
off. some cylinders are too rich while others may be too lean, and
the engine will run roughly when leaned. And that's what all this is
about....being able to run LOP safely and comfortably. When the fuel-
flow spread is close, the EGT spread is close, and the CHT spread
will be close, and that is what makes for longer-lived engines.
Lynn Matteson
Jabiru 2200, #2062
On Aug 22, 2012, at 8:04 PM, Marvin Williams wrote:
| Quote: | Thanks Lynn and Barry.
Marvin
off-topic for most
Hi Marvin-
be the oil box.
<100_1055.jpg>
<100_4853.jpg>
final product.
leantest.php
Lynn Matteson
Jabiru 2200, #2062
> Marvin
N369LM |
BARRY CHECK 6
Posted: Wed Aug 22, 2012 5:26 pm Post subject: Newest GAMI lean test...probably off-topic for most |
Doug:
It with tong in cheek, I have to laugh when you say "work your way through". I joined the RATAX group to gain some insight. But, instead I gained some track shoes to run away from RATAX as quick as possible. They have so many problems it is amazing anyone would even consider that engine. Yet, the they brag about the military using them on UAV's... Sure the military can... They have unlimited funds to keep them running.
Barry
On Wed, Aug 22, 2012 at 5:02 PM, <kayberg(at)aol.com (kayberg(at)aol.com)> wrote:
In my opinion.
Doug Koenigsberg
Lynn Matteson
Posted: Thu Aug 23, 2012 6:30 am Post subject: Newest GAMI lean test...probably off-topic for most |
A couple of other possible reasons for the successful Gami lean test
could be the "swirling device" that I built in April, and the exhaust
system that I built/installed in June. I built the swirler and
installed it, but it didn't seem to do a lot for the EGT spread that
I was seeing. I built 5 blades into the swirler, thinking that if I
wanted to change something, I could just rotate the device one bolt
hole either way and the 5 blades would change their orientation
relative to the intake runner tubes. I have never touched it since I
installed it. This was also about the time that I began to disregard
the one cylinder that was always about 80-100 deg. F. cooler than the
rest, EGT-wise. Since that cylinder was always looking good plug-
reading-wise and exhaust pipe color-wise, I just quit chasing that
"rogue" and lived with the off-reading.
Then in June, I bought a 4-into-1 collector and megaphone, tuned to
the specifications of the Jabiru engine. I had to build the pipes
leading to the collector. (The rear pipes on both sides are a few
inches shorter than the front pipes for now, but I plan to correct
that in the near future, further equalizing the breathing of each
cylinder.)
So with the swirler atomizing the incoming charge, and the "almost
tuned" exhaust system helping to scavenge the exhaust gasses....and
thus helping bring in the fresh air/fuel mixture...I feel both of
these features help make the engine breath easier and more equally
between cylinders.
Lynn Matteson
Jabiru 2200, #2062
334.58 KB |
19886 Time(s) |
510.84 KB |
19886 Time(s) |
N369LM |
BobsV35B(at)aol.com Guest
Posted: Thu Aug 23, 2012 6:51 am Post subject: Newest GAMI lean test...probably off-topic for most |
Good Morning Lynn,
Both items look elegant to me!
Any idea how much those tail pipes weigh?
Happy Skies,
Old Bob
In a message dated 8/23/2012 9:30:51 A.M. Central Daylight Time, lynnmatt(at)jps.net writes:
| Quote: | A couple of other possible reasons for the successful Gami lean test
cylinder.)
between cylinders.
Lynn Matteson
Jabiru 2200, #2062
334.58 KB |
19886 Time(s) |
510.84 KB |
19886 Time(s) |
Lynn Matteson
Posted: Thu Aug 23, 2012 8:05 am Post subject: Newest GAMI lean test...probably off-topic for most |
Hi Bob-
I didn't happen to weigh the whole thing, but the 4 bends (1.31 lbs.
ea.) that I got...16 ga.....came to about 5.24 lbs, but I didn't use
all the length, so call that 5 lbs. The collector and megaphone (18
ga.) I'm guessing came to about 5-6 lbs, so maybe 11 lbs total. I'll
weigh it when I go to the hangar later today, as I need to take the
collector and megaphone off soon anyway, so I can polish the
stainless steel again....one of the drawbacks to having an exposed
exhaust system. : )
By the way, here's a shot of one of the two heat muffs that I
built...so there's an additional 3-4 lbs per side. Geez, it may be
heavier than I thought...horsepower cost money, they say.
Lynn Matteson
Jabiru 2200, #2062
On Aug 23, 2012, at 10:50 AM, BobsV35B(at)aol.com wrote:
| Quote: | Good Morning Lynn,
Happy Skies,
Old Bob
401.09 KB |
19884 Time(s) |
N369LM |
Posted: Thu Aug 23, 2012 8:25 am Post subject: Newest GAMI lean test...probably off-topic for most |
Hi Lynn.
I am sure it is lighter than a turbo and undoubtedly a lot more efficient!
Being able to run lean of peak saves weight on fuel required. Ya just gotta make long enough flights to take advantage of the efficiency. <G>
I love it!
Happy Skies,
Old Bob
In a message dated 8/23/2012 11:06:25 A.M. Central Daylight Time, lynnmatt(at)jps.net writes:
| Quote: | Hi Bob-
exhaust system. : )
Lynn Matteson
Jabiru 2200, #2062
Happy Skies,
Old Bob
401.09 KB |
19883 Time(s) |
Posted: Thu Aug 23, 2012 8:33 am Post subject: Newest GAMI lean test...probably off-topic for most |
Thanks for the photos Lynn! Nice job!
I also modified my air passage into my TBI, but not nearly like yours. I merely bent the top (horizontal) blades of an air straightener I bought from AS downward so as to direct more of the intake air accross the TBI spray bar. It changed the EGT spread, but can't say that it made it significantly better. i.e., changed which cylinder was the hottest. I believe that were I to take enough time to make numerous changes in the air intake to the TBI that I could get my EGTs (thus fuel flow spread) much closer than they are now. Maybe what I should do is just build a 'swirler' like yours and forget the store bought 'straightener'.
As you well know, just changing the power setting changes EGT spread.
Thanks again for the photos.
Marvin
Sent: Wednesday, August 22, 2012 6:04 PM
The larger plenum is probably part of the reason, Marvin. The tubes are the same size as the original...1-1/4" O.D. I built the longer tubes to take advantage of the "ram" effect, and that might be part of the reason as well. Perhaps the longer tubes allow for more time for the mixture to atomize, and this makes for a smoother-running engine.
No, this is exactly the same test. All you are doing in this test is verifying that the fuel flow difference between when the first cylinder's EGT peaks, and the last cylinder's EGT peaks, is very, very close. That determines how well the engine's air/fuel mixture is distributed to the engine. If the first to peak is at say, 3.5 gph, and the last to peak does so when the flow meter reads 3.0 gph, that's a "GAMI spread" of a half-gallon per hour, and that is not good distribution. If this were a direct-port injected engine, the injector nozzles would be changed to bring the flow closer together between the first, and the last, to reach peak EGT. This is what the folks at GAMI do. But my engine, using a Rotec TBI, is basically a carbureted engine, and you can't change individual nozzles like you can with the direct-port engines.
The EGT spread is still talked about, but not the actual numbers from what I've read. First you have to get the flow spread as close as possible, then when that is done, then you can safely run lean of peak EGT, knowing that each cylinder is enjoying very close to the optimum share of the fuel/air mixture. If the flow spread is too far off. some cylinders are too rich while others may be too lean, and the engine will run roughly when leaned. And that's what all this is about....being able to run LOP safely and comfortably. When the fuel-flow spread is close, the EGT spread is close, and the CHT spread will be close, and that is what makes for longer-lived engines.
Lynn Matteson
Jabiru 2200, #2062
Marvin
From: Lynn Matteson <lynnmatt(at)jps.net (lynnmatt(at)jps.net)>
To: jabiruengine-list(at)matronics.com (jabiruengine-list(at)matronics.com)
Hi Marvin-
<100_1055.jpg>
<100_4853.jpg>
As far as the Gami lean test is concerned, you start with a rich mixture, and then start to lean the engine in small increments, according to the fuel flow meter, watching the EGT readouts. The temperatures will rise as the engine is leaned, and then you will see the EGT's reach a peak temperature, and further leaning will cause the temperatures to start to drop. Normally this "peak and drop" will happen one cylinder at a time, over the course of leaning in very small increments....in my case I was leaning by 0.1 gph according to the flow meter. When I did this test back in 2009 right after I installed the TBI, (and using the original Jabiru manifold) the rear two cylinders peaked first, then one of the fronts, and finally the last one peaked. This was over the course of leaning that covered a 0.3 gph range. On a small engine like the Jabiru 4-cylinder, that shows that the fuel distribution in the intake manifold is not real good, but not terrible, either. But with the current manifold that I built, the EGT's will peak, and the next 0.1 gph reduction in flow (leaning), causes them all to start dropping right now. This shows excellent fuel distribution according to the Gami method of lean testing. The writings of people that I have read...John Deakin, Mike Busch, to name a couple...say that most carbureted engines don't have very good fuel distribution, so I'm pretty tickled with my results.
Lynn Matteson
Jabiru 2200, #2062
> Marvin
&biruEngine-List" target="_blank">http://www.matronics.com/Navigator?JabiruEngine-Lista href="http://forums.matronics.com/" target="_blank">http://forums.mat &nbs//www.matronics.com/contribution" target="_blank">http://www.matronics.co==================
Lynn Matteson
Posted: Thu Aug 23, 2012 9:42 am Post subject: Newest GAMI lean test...probably off-topic for most |
I didn't have the gumption to polish the collector and meg, but I DID
take it off and weigh it....2 pounds....and they are both 18 ga.
The Jab muffler...and 6" of extra tail pipe on each exit
pipe....weighed 5 pounds. So probably 4 pounds for the original
muffler as it came from the factory.
All in all, the whole new exhaust system and heat muffs probably
weighs 11 pounds. I was way off on my original guess of the collector
and meg, so I was also probably off on the heat muffs, too....getting
old is a bitch!
Lynn Matteson
Jabiru 2200, #2062
Rotec TBI-40 injection (sleeved to 36m)
Happy Skies,
Old Bob
N369LM |
Lynn Matteson
I can go up and fly around for an hour and use about 3.0-3.2 gallons
of fuel, and that includes the takeoff. I no more than get to
1000-1500' AGL, and I'm leveling off and pulling back on both the
black and the red knobs. I've gotten to where I can grab them both in
one hand and either push or pull...and these are vernier
controls....I must be a frustrated airline pilot. : )
Lynn Matteson
Jabiru 2200, #2062
On Aug 23, 2012, at 12:25 PM, BobsV35B(at)aol.com wrote:
| Quote: | Hi Lynn.
efficient!
efficiency. <G>
I love it!
Happy Skies,
Old Bob
N369LM |
Lynn Matteson
Posted: Thu Aug 23, 2012 9:48 am Post subject: Newest GAMI lean test...probably off-topic for most |
Thanks, Marvin.
Yes, changing the rpm will change the EGT readings all over the
place....the spread AND the location of the hottest cylinder. And
with a 3300, I'd guess it's even worse.
Lynn Matteson
Jabiru 2200, #2062
On Aug 23, 2012, at 12:33 PM, Marvin Williams wrote:
| Quote: | Thanks for the photos Lynn! Nice job!
Marvin
N369LM |
Posted: Thu Aug 23, 2012 10:08 am Post subject: Newest GAMI lean test...probably off-topic for most |
Just a quick question Lynn. Do you swirl the TBI input or output air? I'm guessing output.
Marvin
On Aug 23, 2012, at 10:48 AM, Lynn Matteson <lynnmatt(at)jps.net> wrote:
Thanks, Marvin.
Yes, changing the rpm will change the EGT readings all over the place....the spread AND the location of the hottest cylinder. And with a 3300, I'd guess it's even worse.
Lynn Matteson
Jabiru 2200, #2062
> Marvin
Lynn Matteson
Posted: Fri Aug 24, 2012 2:14 am Post subject: Newest GAMI lean test...probably off-topic for most |
Yup, output...I wanted to mix the air and fuel as much as possible.
Lynn Matteson
Jabiru 2200, #2062
On Aug 23, 2012, at 2:08 PM, Marvin wrote:
Marvin
N369LM |
BARRY CHECK 6
Posted: Fri Aug 24, 2012 2:33 am Post subject: Newest GAMI lean test...probably off-topic for most |
Lynn:
Which way is the swirl pattern in the carb throat, clockwise or counter clockwise?
And how did you determine it?
Barry
On Fri, Aug 24, 2012 at 6:13 AM, Lynn Matteson <lynnmatt(at)jps.net (lynnmatt(at)jps.net)> wrote:
[quote]--> JabiruEngine-List message posted by: Lynn Matteson <lynnmatt(at)jps.net (lynnmatt(at)jps.net)>
Lynn Matteson
Jabiru 2200, #2062
| Quote: | --> JabiruEngine-List message posted by: Marvin <marvinlnaz(at)yahoo.com (marvinlnaz(at)yahoo.com)>
Marvin
le, List Admin.
