Tail Post supports
elleryweld(at)aol.com
PostPosted: Sat Aug 18, 2012 5:38 pm    Post subject: Tail Post supports Reply with quote
here is a PIC of the tail post supports that I think John Hauck came up with the tail wheel is much better than that Pizza cutter and it does make it handle more like a tail dragger
[img]cid:tie_8CF4BC1F90C18F8_1794_9D6ED[/img]
Ellery Batchelder Jr.
 Filesize:  2.37 MB
 Viewed:  6873 Time(s)
Dennis Thate
PostPosted: Sun Aug 19, 2012 3:52 am    Post subject: Re: Tail Post supports Reply with quote
Thanks for the photo Ellery.
I beefed up to a thicker aluminum wall tubing and a larger and thicker steel welded gusset and it's all covered up......
I've put it to the test and it seems to have done the trick.
 Filesize:  57.19 KB
 Viewed:  6853 Time(s)
PostPosted: Sun Aug 19, 2012 11:22 am    Post subject: Tail Post supports Reply with quote
in your pic you dont have the supports that show in my pic, thicker aluminum tubing will not help the area of failure you had better take another look at my pic the supports I am talking about are attached to the big Ring that slips over the end of the tail boom tube under the elevators attachment points and attach to the bottom tube that your tail wheel rod slides into this will help this vertical Tube from breaking under side load pressure
Dennis Thate
PostPosted: Sun Aug 19, 2012 1:30 pm    Post subject: Re: Tail Post supports Reply with quote
Ellery,
I respectfully disagree. The non-turnable Pizza Cutter tail wheel puts a side torque on the lower tail-fin midway, so when forced into a tight turn, it will break, where as a swivel wheel eliminates this problem.
Take note where mine broke in two places. I don't believe your concept would offer any solution to this, because you are reinforcing it in the wrong location.
Hope this photo helps clarify things.
 Filesize:  78.46 KB
 Viewed:  6821 Time(s)
neilsenrm(at)gmail.com
PostPosted: Sun Aug 19, 2012 5:32 pm    Post subject: Tail Post supports Reply with quote
Dennis
I have never seen that kind of breakage. I have to ask if plane was built to specifications. My MKIIIC has a fairly strong  .125 wall bottom tube that has in most Kolbs kept that kind of breakage from happening. Normally we see side loads causing the problems Ellery has described the fix for. I have had the turning bogie wheel and now the locking/swivel tail wheel on my MKIIIC both of these wheels can produce the side loads that can cause long term failure of the tail post without the fix.
Rick Neilsen
Redrive VW Powered MKIIIC
On Sun, Aug 19, 2012 at 5:30 PM, Dennis Thate <retroman(at)frontier.com (retroman(at)frontier.com)> wrote:
[quote]--> Kolb-List message posted by: "Dennis Thate" <retroman(at)frontier.com (retroman(at)frontier.com)>
Ellery,
Both optimists and pessimists contribute to our society.  The optimist invents the airplane and the pessimist the parachute.  ~Gil Stern
http://forums.matronics.com/viewtopic.php?p=381274#381274
http://forums.matronics.com//files/two_fractures_101.jpg
le, List Admin.
PostPosted: Sun Aug 19, 2012 6:09 pm    Post subject: Tail Post supports Reply with quote
Thank You Rick I have just repaired my second Tail post on a different kolb in the same place and this is no longer a problem area with the side load supports just my experience but results may differ from other views
PostPosted: Sun Aug 19, 2012 6:47 pm    Post subject: Tail Post supports Reply with quote
Kolbers:
We can thank Dan Horton, one of my flying buddies, for
coming up with the tail post fix. Can't remember how many
times we repaired and modified my mkIII tail post until Dan
came up with the idea of adding external bracing. Haven't
had any problem with mine since.
Sargents, Colorado
zeprep251(at)aol.com
PostPosted: Mon Aug 20, 2012 5:38 am    Post subject: Tail Post supports Reply with quote
Rick,
My FS broke the lower aluminum tube flush with the steel just like the picture.I reinforced it using a thicker tube and months later it broke at the steel tube up by the ring as in the photo.If you just push on the top of the tail post you can quickly identify the side loads that affect these tubes even WITH a swivel tail wheel.I am a believer in these braces but It looks like no one but me feels that way about the tail spring clamp.
IMHO G.Aman MK3C jabiru 2200A 740hrs
