email(at)jaredyates.com Guest
Posted: Mon Aug 13, 2012 11:03 am Post subject: Attaching "uninsulated ring terminals" to 4 awg |
I used a Dremel to cut a slot in the barrel, then pinched the slot
closed and soldered. I found that I was able to solder successfully
without getting the wire anywhere near hot enough to melt the
insulation, so if that's a problem I'd suggest trying less heat. Here
are some pictures, down about half way:
http://jaredyates.com/bearhawk/?p=988
On Mon, Aug 13, 2012 at 1:51 PM, D L Josephson <dlj04(at)josephson.com> wrote:
Perhaps I'm just being dense, but why not just get the appropriate sized
uninsulated ring terminal for the wire you want to use rather than stuffing
with more copper? If you want to solder a #4 wire, a #6 or maybe #8 crimp
terminal would probably be the right size for a snug fit. You can also make
your own, using soft copper refrigeration tubing -- whatever best fits the
wire, squeezed flat (in a press if necessary) and drilled at the end.
