dlj04(at)josephson.com Guest
Posted: Mon Aug 13, 2012 9:57 am Post subject: Attaching "uninsulated ring terminals" to 4 awg |
Perhaps I'm just being dense, but why not just get the appropriate sized
uninsulated ring terminal for the wire you want to use rather than
stuffing with more copper? If you want to solder a #4 wire, a #6 or
maybe #8 crimp terminal would probably be the right size for a snug fit.
You can also make your own, using soft copper refrigeration tubing --
whatever best fits the wire, squeezed flat (in a press if necessary) and
drilled at the end.
