Which 55-60 amp alternator
fvalarm(at)rapidnet.net
PostPosted: Mon Aug 13, 2012 10:27 am    Post subject: Which 55-60 amp alternator Reply with quote
Bob,
Assuming that in order to end up with an externally regulated 55-60 amp
alternator, I will probably have to modify an IR model, which alternator
should I buy to start with.
I want the fans to turn the correct direction (CCW when viewed at the
pulley) for use on a lycoming.
I don't want to pay the big bucks for a B&C unit and don't mind doing the
work to convert it.
Bevan
PostPosted: Tue Aug 14, 2012 7:16 am    Post subject: Which 55-60 amp alternator Reply with quote
At 01:23 PM 8/13/2012, you wrote:
--> AeroElectric-List message posted by: "B Tomm" <fvalarm(at)rapidnet.net>
Bob,
I'm not sufficiently familiar with the
choices to advise you confidently. It would
seem that the driving constraint is purely
mechanical. Research the parts available to bolt
it to the engine including any changes to
the stock pulley.
Unless you're willing to tackle mechanical
integration issues along with electrical, you'd
probably want to limit you search to frames
already supported by off-the-shelf attach
hardware.
That used to be a 'thing' to consider with
external fans with blades optimized for direction
of rotation.
[img]https://encrypted-tbn2.google.com/images?q=tbn:ANd9GcR2RVsXHbk96gX586Gl_JTFHKS_mmDSHKRKUjjI9eeWbpWLysEs[/img]
Modern alternators have internal fans with
little if any 'sculpturing' of the blades
[img]https://encrypted-tbn0.google.com/images?q=tbn:ANd9GcRwC9Tc1fQL5bJpQsZWZ0ybe93jtsul4qEU7xFg2-p7TEfV9fuy[/img]
Rotating an alternator 'backwards' in an
airplane is unlikely to pose any problems.
First, you're exceedingly unlikely to stress
your alternator in a manner that produces
maximum rated internal heating. The cooling
environment under the hood of a car is MUCH
worse than under the cowl of your airplane.
Further, you're going to be spinning the
alternator much faster than the original
application design point . . . cooling is
not a big issue.
work to convert it.
You can run it internally regulated . . . you
could do a mod similar to that offered by Plane
Power for crowbar ov protection and external
control of field power.
Bob . . . [quote][b]
PostPosted: Tue Aug 14, 2012 6:08 pm    Post subject: Which 55-60 amp alternator Reply with quote
Thanks Bob,
The online alternator vendors don't supply data such as mounting bracket dimensions, pulley diameter etc. they just say it fit a particular make and model car.
Can I assume that a 12V 60 amp Denso alternator has the same mounting dimensions as the 60 amp Plane Power that Vans sells?
the stock pulley.
Fair enough. Anyone have any experience with this? I've already wired the plane for external control and crowbar as I agree with the philosophy. So I would like to keep it this way. Nothing lasts for ever. So my theory is to buy two alternators online for the price of one B & C or Plane power. Mod them both for external control and one will be then be a spare. Smile
hardware.
Exactly. Still need top know the dimensional data. Anyone have a Vans, B&C, Plane Power 60amp that it will to measure the mounting bracket boss?
of rotation.
not a big issue.
OK, makes sense. I will not be concerned with direction of fans.
I'm confused by the above statement. Does that not make it externally controlled or is there a variation on a theme here? Is there a document that describes the PP mod?
Bevan
PostPosted: Wed Aug 15, 2012 5:13 am    Post subject: Which 55-60 amp alternator Reply with quote
Let's make a distinction between internally and
externally REGULATED . . . which speaks to the
location of the electronics that exercises dynamic
control of field current for the purpose of
maintaining desired bus voltage. Then there's
a legacy design goal for any-time, any-conditions
control of alternator function by the pilot.
Referring you to an exemplar schematic for an
internally regulated alternator . . .
http://tinyurl.com/8a9uuns
the pathway in green shows how energy from the
battery makes it through a controlling device
(in this case, an N-channel FET) to the alternator
field. Note that both CONTROL and WARNING
functions (red) attach to electronics within
the regulator's circuitry. If something in that
circuitry fails or the FET shorts, then full
battery voltage is applied to the field, regulation
control is lost and you have an over-voltage
condition.
There's been a great deal of discussion in the past
as to the suitability of internally regulated alternators
on airplanes. I have always maintained that I could
not recommend the use of IR alternators because
they could not offer the legacy any-time, any-condition
control by the pilot -OR- an ov protection system
in their off-the-shelf configuration.
B&C's solution to the problem was to remove the
built in regulator and offer an external alternator
control system that included the functional trinity
for alternator management: Regulation, OV management,
LV warning.
Plane power went a different route and simply
broke the field supply path inside the alternator
and brought it out so that absolute, any-time
any conditions control was available to the pilot
-AND- ov protection could be easily implemented.
In this case, Plane Power elected to go with
the crowbar ov protection technique pioneered
in aircraft by yours truly. The concept was
slated to go onto the Beech 38P
http://tinyurl.com/7smb4k5
Unfortunately, that program never made it to
the production line. The last time I saw N336BA,
the fuselage was sitting outside Burt Rutan's
hangar at Mojave.
http://tinyurl.com/cj3n24a
Since that time, crowbar ov protection has
be successfully applied to thousands of installations
in dozens of aircraft.
If you want to convert an off-the-shelf
alternator to your use while embracing the legacy
design goals for engine driven power sources, you
have the option of doing the B&C thingy or the
Plane-Power thingy . . . either one works good
and lasts a long time.
I'm aware of no article which describes the PP
modification. It's difficult even to find local alternator
repair shops that could assist in making the
modifications . . . although it's usually pretty
simple to figure out once the alternator is cracked
open. There have been some articles that described
total bypassing of the internal regulator for going
the B&C approach . . . but I don't enjoy ready
recall for those documents. Perhaps somebody on
the List has a broader insight to your quest.
mrspudandcompany(at)veriz
PostPosted: Wed Aug 15, 2012 5:58 am    Post subject: Which 55-60 amp alternator Reply with quote
Bob . . . [quote]Here is an article published by EAA for conversion of an internal regulated to external regulated alternator. http://www.eaa.org/experimenter/articles/2009-09_howto_alternator.asp Roger[b]
PostPosted: Wed Aug 15, 2012 7:25 am    Post subject: Which 55-60 amp alternator Reply with quote
[/b]for conversion of an internal regulated
[/b]to external regulated
alternator.[/b] [/b]
[/b]
Cool! I'd not seen that particular article. Thanks
for heads-up. A very good article that needed only a few minor corrections. I've captured the article and mirrored
it with comments at:
http://tinyurl.com/crte9xe
PostPosted: Wed Aug 15, 2012 8:51 am    Post subject: Which 55-60 amp alternator Reply with quote
Thanks everyone, we're getting very close here.
It is still unclear to me which 60 amp ND alternator to start with that will fit the Van's mounting bracket (Boss mount?). What have other done?
Bevan
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Roger & Jean Curtis
Sent: Wednesday, August 15, 2012 6:57 AM
Subject: RE: Which 55-60 amp alternator
PostPosted: Wed Aug 15, 2012 12:38 pm    Post subject: Which 55-60 amp alternator Reply with quote
Bevan
Here's a wild (at)#S guess. Here's a Lester #14935 that
fits 85-88 Tercels.
[img]cid:7.1.0.9.0.20120815153159.047a6198(at)aeroelectric.com.0[/img]
Oriley's offers this one for about $100. It's frame geometry
appears the same as the B&C L-60 and others popular with
the OBAM aviation market.
http://tinyurl.com/8vfkj66
If you've got the mount, you could go down to the local parts
store and fit check the alternator with the mount and measure
the offset from boss-mount bolt holes to the pulley centerline.
Of course, you need to find a new pulley too.
 Filesize:  68.54 KB
 Viewed:  3649 Time(s)
