rowlandcarson(at)gmail.co Guest
Posted: Sat Aug 18, 2012 10:33 am Post subject: rotax 912S grounding strap position |
I'm checking through the sizes of terminals that I'll need for various connexions. I cannot find in either the Rotax engine manual or the Europa FWF manual any identification of the point on the engine block that should be used for the electrical ground point.
Is there any existing bolt or nut to which a grounding strap is typically connected? Or is there an empty tapped hole provided into which a screw can be fitted to retain a grounding strap?
in friendship
Rowland
| Rowland Carson ... that's Rowland with a 'w' ...
| <rowlandcarson(at)gmail.com> http://www.rowlandcarson.org.uk
| Skype, Twitter: rowland_carson Facebook: Rowland Carson
| pictures: http://picasaweb.google.com/rowlandcarson
kheindl(at)msn.com Guest
Posted: Sat Aug 18, 2012 12:39 pm Post subject: rotax 912S grounding strap position |
there is an empty tapped hole at the far rear top stbd side where I connected my ground strap.
| Quote: | From: rowlandcarson(at)gmail.com
Subject: Europa-List: rotax 912S grounding strap position
Date: Sat, 18 Aug 2012 19:32:05 +0100
--> Europa-List message posted by: Rowland Carson <rowlandcarson(at)gmail.com>
in friendship
Rowland
Rocketman
Posted: Sat Aug 18, 2012 12:51 pm Post subject: rotax 912S grounding strap position |
Rowland,
I typically ground directly to the exhaust pipe...
Jeff - Baby Blue
On 8/18/2012 1:32 PM, Rowland Carson wrote:
in friendship
Rowland
