AW: Fresh air Vents
uvtreith(at)t-online.de
PostPosted: Mon Aug 13, 2012 12:42 am    Post subject: AW: Fresh air Vents Reply with quote
Hi Carl,
I have used the F27 ceiling panel without the holes for the headset connectors, installed swivel ball vents on each side and made a flap with a lever to open and close the fresh air inlet.
This works fine and provides enough fresh air to keep your head cool.
Best Regards,
Bruno
Von: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] Im Auftrag von Carl Pattinson
Gesendet: Montag, 13. August 2012 01:08
An: europa-list(at)matronics.com
Betreff: Fresh air Vents
Hi,
Does anybody have a mod/ design for a vent that can easily be fitted to an existing installation.
I believe the front screen is a structural component so can’t be altered but presumably the side screens could have a vent installed.
I believe that Spruce and Speciality sells design that can simply be bolted into a circular hole cut through the Perspex.
For obvious reasons an approved mod would be preferred.
Carl Pattinson
G-LABS
No infections found in this outgoing message
Scanned by iolo System Shield.
http://www.iolo.com
[b]http://www.matronics.com/Navigator?Europa-List[b]
 Filesize:  10.73 KB
 Viewed:  1597 Time(s)
