Attaching "uninsulated ring terminals" to 4 awg wire...
stuart(at)stuarthutchison
PostPosted: Sun Aug 12, 2012 10:42 pm    Post subject: Attaching "uninsulated ring terminals" to 4 awg wire... Reply with quote
Hi guys,
I haven't read all the posts on this thread ... please forgive me if I'm
covering old ground.
Not everyone's cup-o-tea, but you can make dies like this too. Just cut two
bits of the same steel bar to length, hold them together in a vice, drill a
big hole at the join from the top in one direction and a small hole from the
side. Smooth the end of a rod or pin punch and there you have it, a decent
die you can hold in the vice that will retain the shape of your terminal as
you crimp away the void, prior to solder and heatshrink.
Cheers, Stu
 Filesize:  133.23 KB
 Viewed:  733 Time(s)
