Icom External Antenna
Goto page 1, 2  Next
zeprep251(at)aol.com
PostPosted: Fri Aug 10, 2012 11:35 am    Post subject: Icom External Antenna Reply with quote
This is actually covered in a March post from Boyd Young, but I need some more particulars if you don't mind.Looks like RG58, but what lengths do I start with before tuning with the SWR meter Boyd?
Thanx G.Aman
 Filesize:  21.8 KB
 Viewed:  14415 Time(s)
jackinkeywest
PostPosted: Fri Aug 10, 2012 12:03 pm    Post subject: Icom External Antenna Reply with quote
For a 1/4 wave antenna in the VHF Airband (118.0-136.0 MHz) about 20" will put you in the middle of the spectrum (127.0 MHz).
Good luck.
Jack in Key West
smime.p7s
 Filename:  smime.p7s
 Filesize:  5.16 KB
 Downloaded:  647 Time(s)
undoctor
PostPosted: Fri Aug 10, 2012 12:21 pm    Post subject: Icom External Antenna Reply with quote
undoctor
PostPosted: Fri Aug 10, 2012 12:37 pm    Post subject: Icom External Antenna Reply with quote
frankf(at)flying-models.c
PostPosted: Fri Aug 10, 2012 12:42 pm    Post subject: Icom External Antenna Reply with quote
One other item I'd like to find out is the best and maybe easiest way to
suppress ignition noise. Is it necessary to go the full gamut and use
resistor plugs, cap, and ignition lead shielding? Will strobes also add
to the noise?
Frank Fanelli
On 8/10/2012 4:01 PM, Lockamy, Jack CIV Atlantic Targets Marine Ops,
AD.5.3.3 / Key West Det wrote:
[quote] For a 1/4 wave antenna in the VHF Airband (118.0-136.0 MHz) about 20" will put you in the middle of the spectrum (127.0 MHz).
Good luck.
Jack in Key West
byoungplumbing(at)gmail.c
PostPosted: Fri Aug 10, 2012 3:51 pm    Post subject: Icom External Antenna Reply with quote
Thanx G.Aman
i started plenty long.. i think about 25 inches, on both legs, the inner connector, and braid... my ham radio club has an antenna analizer, and i used it to figure the final legnths... i will have to measure the next time i go to the airport.
boyd
PostPosted: Fri Aug 10, 2012 4:49 pm    Post subject: Icom External Antenna Reply with quote
Thanks Boyd,
I wondered if I could use the same SWR meter that I had for CB?
G.A.
PostPosted: Fri Aug 10, 2012 4:54 pm    Post subject: Icom External Antenna Reply with quote
Frank,
I'm fighting the same issue with the Jabiru.Resistor plugs made no difference.Shutting the engine off helps the most.
G.Aman
Dana
PostPosted: Fri Aug 10, 2012 5:35 pm    Post subject: Icom External Antenna Reply with quote
At 04:39 PM 8/10/2012, Frank Fanelli wrote:
--> Kolb-List message posted by: Frank Fanelli <frankf(at)flying-models.com>
One other item I'd like to find out is the best and maybe easiest way to suppress ignition noise. Is it necessary to go the full gamut and use resistor plugs, cap, and ignition lead shielding? Will strobes also add to the noise?
You can use resistor plugs, OR resistor caps. Use both together and you can fry your ignition. Shielding always helps. For me, the combination of resistor plugs and the "ANL" setting (automatic noise limiter) on the radio is all I need. Strobes can add noise, but I don't notice any from mine.
-Dana
Congress shall make no law....What part of NO didn't you understand?
PostPosted: Fri Aug 10, 2012 8:57 pm    Post subject: Icom External Antenna Reply with quote
Thanks Boyd,
G.A.
i am doubtfull.... cb is around 50 mhz,,, aircraft centers at 127 mhz,,, i dont think it will cover that mhz spread.( check the owners/ tech manual)
check arrl.org,, and see if there is a ham radio club in your area,, can probabley get some help for free.
boyd
PostPosted: Sat Aug 11, 2012 3:00 am    Post subject: Icom External Antenna Reply with quote
Thanks again Boyd,will let you know how it works out.
G.A. do not archive
PostPosted: Sat Aug 11, 2012 10:33 am    Post subject: Icom External Antenna Reply with quote
Frank,
G.Aman
A large "capacitor" about 21,000 mf always worked best for
me, 447, 582, and the 912 series engines.
Del Norte, Colorado
PostPosted: Sat Aug 11, 2012 10:35 am    Post subject: Icom External Antenna Reply with quote
-Dana
Rotax 912 series engines use resistor plugs and caps.
Del Norte, Colorado
PostPosted: Sat Aug 11, 2012 4:13 pm    Post subject: Icom External Antenna Reply with quote
John,Where is the best location for the capacitor?
G.Aman
undoctor
PostPosted: Sat Aug 11, 2012 6:07 pm    Post subject: Icom External Antenna Reply with quote
Matt, Kolbers,
I tried to send a reply twice a couple of days ago and both came through with nothing in the message window.
I sent the same reply to myself and it came through OK, so it seems there's a problem with the list. I'm also
getting replys to subjects when I hadn't gotten the original post, so I seem to be missing some posts.
I was responding to Boyd about lots of static on his Icom; I was unreadable to others with my Icom when
I transmitted, although I could hear others just fine. I was told that the problem was that when I pushed
the button on the Icom to talk I was transmitting both through the Icom handheld mic as well as the mic
on my headset, and that if I got a Push To Talk button it would only pick up through my headset. I bought
a PTT and now it works as it should.
FWIW
Dave Kulp
Bethlehem, PA
FireFly 11DMK
On 8/11/2012 8:10 PM, Gary Aman wrote:
[quote]John,Where is the best location for the capacitor?
G.Aman
-----Original Message-----
From: John Hauck <jhauck(at)elmore.rr.com> (jhauck(at)elmore.rr.com)
To: kolb-list <kolb-list(at)matronics.com> (kolb-list(at)matronics.com)
Sent: Sat, Aug 11, 2012 2:33 pm
Subject: RE: Icom External Antenna
--> Kolb-List message posted by: "John Hauck" <jhauck(at)elmore.rr.com (jhauck(at)elmore.rr.com)>
Frank,
G.Aman
Del Norte, Colorado
tp://forums.matronics.com
rickofudall
PostPosted: Sat Aug 11, 2012 6:42 pm    Post subject: Icom External Antenna Reply with quote
What is the nature of your noise, a high pitched squeal is the alternator, a low pitched buzz is the ignition. The alternator will respond to the cap. Place it in the DC + line coming from you regulator going to the battery. Both sides of the wire are through the + terminal on the cap, the - terminal should go to engine ground. For ignition noise you need an inductor coil, you can probably find these from the custom car stereo shops.
Rick Girard
On Sat, Aug 11, 2012 at 7:10 PM, Gary Aman <zeprep251(at)aol.com (zeprep251(at)aol.com)> wrote:
G.Aman
PostPosted: Sun Aug 12, 2012 6:44 am    Post subject: Icom External Antenna Reply with quote
Rick Girard
good reply rick
if you add a capacitor between the inductor coil and the radio. that will be like belt and suspenders. and the closer you can put this to the radio. the less chance you will have for inductance interference getting into the wire after the filters.
boyd
PostPosted: Sun Aug 12, 2012 3:01 pm    Post subject: Icom External Antenna Reply with quote
John, Where is the best location for the capacitor?
G.Aman
Gary A/Kolbers:
On the 12VDC side of the regulator/Rectifier. Attach to
positive and negative.
Del Norte, CO
phactor9
PostPosted: Sun Aug 12, 2012 3:27 pm    Post subject: Icom External Antenna Reply with quote
Isn't that the same as attaching it across the positive terminal of the key ignition and negative battery terminal (or ground)? So that the cap is across the battery positive and negative terminals, but only when the master is on?
Date: Sunday, August 12, 2012, 6:59 PM
G.Aman
Gary A/Kolbers:
mkIIvigator?Kolb-List" sp;--> http://f= - List Contributionsp; &bsp;-->
Dana
PostPosted: Sun Aug 12, 2012 3:35 pm    Post subject: Icom External Antenna Reply with quote
At 02:33 PM 8/11/2012, John Hauck wrote:
--> Kolb-List message posted by: "John Hauck" <jhauck(at)elmore.rr.com>
-Dana
I stand corrected. I guess it's a matter of what the ignition is designed for. It IS a problem on some 2-strokes, though.
-Dana
Don't steal. The IRS hates competition.
Goto page 1, 2  Next
Page 1 of 2
