Kitplanes September Issue
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Lightning-List
nick(at)flylightning.net
PostPosted: Tue Aug 07, 2012 7:41 am    Post subject: Kitplanes September Issue Reply with quote
Here is the article in PDF form for those of you that have not read it yet.
thanks
Nick Otterback
Arion Aircraft LLC
R&D Technical Support
931-680-1781
- The Matronics Lightning-List Email Forum -
http://www.matronics.com/Navigator?Lightning-List
Clive J
PostPosted: Tue Aug 07, 2012 8:54 am    Post subject: Kitplanes September Issue Reply with quote
Reads well, as someone who has gone through the stability and trim issues with the Esqual I can appreciate the improvements.
So now the Esqual is Swedish? And you didn’t crack a mould off the fuselage? What’s that smell? I’ll bet Francesc is turning is his grave.
Good to see you aren’t sitting on your hands, and nice to see Pete gave you the company!
Regards, Clive
From: owner-lightning-list-server(at)matronics.com [mailto:owner-lightning-list-server(at)matronics.com] On Behalf Of Nick Otterback
Sent: 07 August 2012 16:40
To: Lightning-list(at)matronics.com
Subject: Kitplanes September Issue
thanks
Nick Otterback
Arion Aircraft LLC
931-680-1781
vettin74(at)yahoo.com
PostPosted: Tue Aug 07, 2012 9:58 am    Post subject: Kitplanes September Issue Reply with quote
Thanks for the kind words. The company is not mine it is Petes. We are partners along with a few other investors. Pete simply allows me the freedom to further design as needed.
Nick
Sent from my pocket
On Aug 7, 2012, at 11:53 AM, "James, Clive R" <clive.james(at)uk.bp.com> wrote:
[quote] Reads well, as someone who has gone through the stability and trim issues with the Esqual I can appreciate the improvements.
Regards, Clive
Clive J
PostPosted: Tue Aug 07, 2012 10:07 am    Post subject: Kitplanes September Issue Reply with quote
Still in your debt for the fix on the Esqual !
Permit is getting closer but not yet got my hands on it.
Regards, Clive
Sent: 07 August 2012 18:57
To: lightning-list(at)matronics.com
Subject: Re: Lightning-List: Kitplanes September Issue
Nick
Sent from my pocket
On Aug 7, 2012, at 11:53 AM, "James, Clive R" <clive.james(at)uk.bp.com (clive.james(at)uk.bp.com)> wrote:
Regards, Clive
From: owner-lightning-list-server(at)matronics.com (owner-lightning-list-server(at)matronics.com) [mailto:owner-lightning-list-server(at)matronics.com] On Behalf Of Nick Otterback
To: Lightning-list(at)matronics.com (Lightning-list(at)matronics.com)
Subject: Lightning-List: Kitplanes September Issue
thanks
Nick Otterback
Arion Aircraft LLC
931-680-1781
  ===================================>http://www.matronics.com/Navigator?Lightning-List===================================ums.matronics.com">http://forums.matronics.com===================================http://www.matronics.com/contribution">http://www.matronics.com/contribution===================================
elledien
PostPosted: Tue Aug 07, 2012 10:41 am    Post subject: Kitplanes September Issue Reply with quote
Hi Clive,
how are you ?
I read about the Esqual stability and I am curious to know which improvements the Esqual needs.
Did you calculate a good C&G to improve the phugoid ? And what about the max flap setting ?
I remember that you, some time ago, sent a mail with something inherent but forgot it.
Do you have any news ? And what about the PoF for your bird ?
Waiting your news best regards and enjoy your vacation.
Luigi
Da: "James, Clive R" <clive.james(at)uk.bp.com>
A: lightning-list(at)matronics.com
Inviato: Martedì 7 Agosto 2012 20:05
Oggetto: RE: Kitplanes September Issue
Regards, Clive
Subject: Re: Kitplanes September Issue
Nick
Sent from my pocket
Regards, Clive
thanks
Nick Otterback
Arion Aircraft LLC
931-680-1781
  ===================================>http://www.matronics.com/Navigator?Lightning-List===================================ums.matronics.com">http://forums.matronics.com==========http://www.matronics.com/contribution">http://www.matronics.com/contribution===================================
4[/b]http://www.matronics.com/Navigator?Lightning-Li             - MATRONICS WEB FORUMS -[/b] [/quote]5
¦·›~‰í²,Þg(–ŠÓM4ÓGÚqü¢êâz¹ÞÁÊ.®'«8^.(!¶x§€¸¬´IšŠQh®éRÇ­…㶺'‰ËŠËEy«n­ë jø jÚ+¶†ë£Ø^™©ò.+-ºØ¥ŠØž²Ëœ…«ŠËTŸô®nÇ+Š›b¢p­Èb½äžj·!Œ'–†�ì6²º0±à¡jÑ(at)Cá¢Ú,…ªÞjwf¹Èf¹Èf¢·�¨kyñ¶Úÿ0™«k¢xœ±Ê&ü֝Э¢²â‚gŠxŠËa¶Úÿ0™«k¢xœ±Ê&ü֝Э¢²â‚gŠxŠËl4N4€’X(at)E9Lš™è+y«\¢{^žÖ¥²†¯j)ZnW¯‰«ayg›ŠîšjÞ|m¶Ÿÿ~ŠîšÉš¶º'‰Ë¢hm¶Ÿÿ~ŠîšÉš¶º'‰Ë¢oÚâ²Ð¨žÚânëb¢užm(­|ájy2¢çè¯*.®§zº.²Ë©¦Ší
craigsumner(at)comcast.ne
PostPosted: Tue Aug 07, 2012 11:25 am    Post subject: Kitplanes September Issue Reply with quote
Outstanding article! Well done Nick!! Thanks for passing it along.
Craig Sumner
N155JM
Sent: Tuesday, August 07, 2012 10:40 AM
thanks
Nick Otterback
Arion Aircraft LLC
931-680-1781
geather
PostPosted: Wed Aug 08, 2012 2:43 pm    Post subject: Kitplanes September Issue Reply with quote
Nick,
Reading the article in Kit Planes begs the question: Is the new tail design going to be available as an add on kit/ upgrade or would the entire horizontal stabiliser need to be replaced in order to achieve the increased stability?
Geoff Eather (Kit 127)
On 08/08/2012, at 1:40 AM, Nick Otterback wrote:
[quote]Here is the article in PDF form for those of you that have not read it yet.
thanks
Nick Otterback
Arion Aircraft LLC
931-680-1781
<_export_sites_kitplanes_02_data_media_pdfs_Lightning_Strikes_Again.pdf>
ge
PostPosted: Wed Aug 08, 2012 3:16 pm    Post subject: Kitplanes September Issue Reply with quote
We have developed a carbon cuff that will fit over the exsisting tail. Is is very light weight and will not require any disassembly. We are getting a prototype set here to install and write and install guide for. The AZ dealer should have his set now to start installation on his demo. So i would expect by the end of the month we will have everything set in stone for the retrofit
n5pb(at)AOL.COM
PostPosted: Wed Aug 08, 2012 6:26 pm    Post subject: Kitplanes September Issue Reply with quote
Nick, have you decided on a price for the cuff?
also, do you plan on having the Lightning fly-in again this year?
Bear
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Lightning-List All times are GMT - 8 Hours
You cannot download files in this forum
