pilot4pay
Joined: 01 Jan 2007 Posts: 171 Location: Louisville, KY
Posted: Tue Aug 07, 2012 9:19 am Post subject: L-Angle Part No? |
Do any Zenith builders know a part no. for an L-angle .040t and 19mmx19mm?
I was hoping that I could get a part that corresponds to a 601/650, 701/750. or 801.
I'm building a 640, but to order parts from Canada I pay three times the cost of the parts in shipping. If I can get a drawing no from a locally built kit, I can order from the good ol USA, and not pay an arm and a leg for shipping. Called Zenith and the old lady says she knows only one l angle and it's .025 thick. She wasn't going to lift a finger to look any further. I'm sure that there's more than one kind of angle in the other kits, just don't have a set of plans to look it up.
Thanks in advance.
_________________ Craig Smith
CH640 builder
SN: 0078
"Just think how stupid the average person is,
and then realize that half of them are even stupider!"
--George Carlin |
psm(at)att.net Guest
Posted: Tue Aug 07, 2012 9:39 am Post subject: L-Angle Part No? |
Hi Craig,
I agree with the response you got from Zenith. All the "L" parts on my
CH601XL are .025 thick.
You should be able to get a local sheet metal shop to bend some metal
for you. The details that are important are the alloy (6061-t6) and the
bend radius (probably 1/8").
Good luck,
Paul
Camas, WA
On 8/7/2012 10:19 AM, pilot4pay wrote:
Thanks in advance.
Craig Smith
CH640 builder
SN: 0078
--George Carlin
http://forums.matronics.com/viewtopic.php?p=380297#380297
ch701builder(at)yahoo.com Guest
Posted: Tue Aug 07, 2012 9:44 am Post subject: L-Angle Part No? |
For the 701, they are just a standard "L", no real part number, but they are the 0.025" thick parts. Without making some yourself, you might have rely on calling Zenith again. Did you call Zenair or Zenithair?
Zenair.com is in Canada and Zenithair.com is in Missouri.
Keith
CH701 - scratch
Sent: Tuesday, August 7, 2012 11:19 AM
Subject: L-Angle Part No?
--> Zenith-List message posted by: "pilot4pay" <pilot4profit(at)sbcglobal.net (pilot4profit(at)sbcglobal.net)>
Thanks in advance.
Craig Smith
CH640 builder
SN: 0078
--George Carlin
<-List" target="_blank">http://www.matronics.com/Navigator?Zenith-Listontent also available via the Web nbsp; -Matt Dralle,============
Posted: Tue Aug 07, 2012 9:50 am Post subject: L-Angle Part No? |
I don't know of a 0.040 L in the 601 or 701.
FWIW I bend my own 0.025 standard L's is a simple wooden press brake. The
same technique should work for 0.040. I wrote an article on this for the
Zenith newsletter in 2009. If you are interested I can e-mail you the text
and photos.
-- Craig Payne
pmaxpmax(at)HOTMAIL.COM Guest
Posted: Tue Aug 07, 2012 9:54 am Post subject: L-Angle Part No? |
The specs for the L-angles are specified in some of the up-front documentation, (builders general instructions) and when I received them the only part number on the label was "L Angle".
This is from memory.
Phil Maxson
601XLB/Corvair
carlossa52(at)gmail.com Guest
Posted: Tue Aug 07, 2012 9:58 am Post subject: L-Angle Part No? |
Craig, the "generic" L angles do not have part numbers, they are simply marked "L" in the plans and they are 0.025" thick. Is there any other clue you can provide so people can try to locate your particular L angle in the plans? For instance, is it in the wings, fuse, tail feathers? You could also try to talk to (or email) Caleb.Good luck CarlosCH601-HD, plans
On 7 August 2012 13:19, pilot4pay <pilot4profit(at)sbcglobal.net (pilot4profit(at)sbcglobal.net)> wrote:
[quote]--> Zenith-List message posted by: "pilot4pay" <pilot4profit(at)sbcglobal.net (pilot4profit(at)sbcglobal.net)>
Thanks in advance.
Craig Smith
CH640 builder
SN: 0078
--George Carlin
jaybannist(at)cs.com Guest
Posted: Tue Aug 07, 2012 10:06 am Post subject: L-Angle Part No? |
Did you not use part number 6B2-1 or 6B2-2 ?
Jon(at)joncroke.com Guest
Posted: Tue Aug 07, 2012 10:19 am Post subject: L-Angle Part No? |
If you don't mind 20 X 22 X .040 then use: 7F3-1
That is the 701 Fuselage longeron
Jon
steve.freeman(at)syntaxds Guest
Posted: Tue Aug 07, 2012 10:34 am Post subject: L-Angle Part No? |
Rear Top Longeron 6-B-2 -1 on the 650 plans is .040 material bent to 90
degrees. it is 1,970 mm long with 20mm flanges. If the extra 3mm on the
flanges is not a problem this would be a good fit.
6-B-2-2 is the same thin but only 200mm long.
Any angle that is not a standard .025 "L" angle with 20mm flanges will have
a specific part number as it is not an "L" angle.
A .040 angle would be tough to make on your own if you don't have a good
brake.
Steve
PS Shirley is a piece of work sometimes!
malcolmhunt(at)mha1.fsbus Guest
Posted: Tue Aug 07, 2012 11:11 am Post subject: L-Angle Part No? |
Craig
Had a look at the CH601XL, CH701SP and CH750 plans and no standard angles
in 0.040" material is called; up the following parts are in 0.040" and all
have .125" root radius.
On the 601XL the rear Longerons (6B2-1) have 22 x 22 legs, the firewall
stiffeners 6B6-3 have 22 x 40 legs and the seat panel angle (6B16-5) have 20
x 20 legs.
On the 701SP the Longerons (7F3-1) have 20 x 22 legs, top angle stiffener to
firewall (7F7-7SP) both legs 20 as are those to the corner angle (7F9-9SP)
to the fuselage.
On the CH750 the horizontal stabilizer(75T2-1) uses 19x19 with the Cabin
corner angle (75F7- 20 x 20
So there you have it, no standards dimensions. Are you certain that the
legs you require are 19 x 19? If so it would be a simple job to fold some
up.
If you are still uncertain suggest you e-mail Caleb Gerbhardt at Zenithair,
he is always very helpful but may take some days to respond as I think he
likes to keep busy!
Best Regards
Malcolm Hunt
Plans builder from England
JohnDRead(at)aol.com Guest
Posted: Tue Aug 07, 2012 2:09 pm Post subject: L-Angle Part No? |
If your attitude was better the "old Lady" would have given you all the help you need!! If you have a legal set of plans the size of the "L" will be on the plans.
Regards, John
CH701 - Colorado - Jabiru 3300
Cell: 719-494-4567
Home: 303-648-3261
PatrickW
Joined: 27 Oct 2006 Posts: 380 Location: Fort Worth, Texas
Posted: Wed Aug 08, 2012 6:42 am Post subject: Re: L-Angle Part No? |
There's a 19x19 L-angle in the Upgrade package that is .040.
6-ZU-3-4
4 feet long.
Patrick Hoyt
N63PZ
