A swivel tailwheel question
Dennis Thate
PostPosted: Thu Aug 02, 2012 11:41 am    Post subject: A swivel tailwheel question Reply with quote
Has anyone switched to a swivel tail-wheel on their Kolb Firestar. If so what has been the result either positive or negative. Where can I locate one ?
elleryweld(at)aol.com
PostPosted: Thu Aug 02, 2012 11:48 am    Post subject: A swivel tailwheel question Reply with quote
You can get a nice tail wheel like that at TNK I put one on my firestar it was much easier to park it and much better to move around inside the shop it works much better that that Pizza cutter they originally come with
Ellery Batchelder Jr.
undoctor
PostPosted: Thu Aug 02, 2012 12:17 pm    Post subject: A swivel tailwheel question Reply with quote
Ellery, how is it for doing Ubys on the runway?
Narrow runway,,,
Dave Kulp
On Aug 2, 2012, at 3:48 PM, Ellery Batchelder Jr <elleryweld(at)aol.com (elleryweld(at)aol.com)> wrote:
[quote] You can get a nice tail wheel like that at TNK I put one on my firestar it was much easier to park it and much better to move around inside the shop it works much better that that Pizza cutter they originally come with
frank goodnight
PostPosted: Thu Aug 02, 2012 1:28 pm    Post subject: A swivel tailwheel question Reply with quote
Hi Dennis ,
I switched to the full swivel Breakaway tail wheel that kolb sells ( $ 250 ). expensive-- but IMHO--worth the money.
Had it about 125 hrs, no problems. Much easier ground handling And with the addition of 2 small braces helps prevent
the vertical stabelizer breaking that sometimes happen to firestars.
Frank
Firestar II
Sent: Thu, August 2, 2012 2:45:06 PM
Subject: A swivel tailwheel question
PostPosted: Thu Aug 02, 2012 2:02 pm    Post subject: A swivel tailwheel question Reply with quote
it will work just fine properly rigged, set it up so it will not unlock untill at full rudder deflection and you will be just fine
PostPosted: Thu Aug 02, 2012 2:05 pm    Post subject: A swivel tailwheel question Reply with quote
Frank , I would recommend installing the tail post brackets on all Kolbs I just repaired one on a MK3C
Dennis Thate
PostPosted: Sat Aug 18, 2012 9:37 am    Post subject: Re: A swivel tailwheel question Reply with quote
Thanks for the helpful suggestions. I went with a Matco. The Kolb handles so much better....more like a real taildragger. Far better than the Pizza Cutter that came with it.
" I would recommend installing the tail post brackets on all Kolbs "
Ellery Batchelder Jr. "
Can you show a picture of these tail post brackets ?
 Filesize:  29.9 KB
 Viewed:  8677 Time(s)
 Filesize:  34.58 KB
 Viewed:  8667 Time(s)
zeprep251(at)aol.com
PostPosted: Sat Aug 18, 2012 3:59 pm    Post subject: A swivel tailwheel question Reply with quote
[img]cid:tie_8CF4BB4449CE2D4_13AC_8E781[/img]
 Filesize:  171.33 KB
 Viewed:  8658 Time(s)
 Filesize:  170.46 KB
 Filesize:  173.99 KB
dpeters160(at)gmail.com
PostPosted: Sat Aug 18, 2012 4:16 pm    Post subject: A swivel tailwheel question Reply with quote
Could you provide the part number of the Marco tailwheel assembly pictured; I don't seem to be able to find the same on the internet. Thank you. On Aug 18, 2012 5:03 PM, "Gary Aman" <zeprep251(at)aol.com (zeprep251(at)aol.com)> wrote:[quote] [img]cid:tie_8CF4BB4449CE2D4_13AC_8E781[/img]
 Filesize:  171.33 KB
 Viewed:  8655 Time(s)
