seat belts
carlossa52(at)gmail.com
PostPosted: Sat Jul 28, 2012 3:39 pm    Post subject: seat belts Reply with quote
Hello, allI need to order seat belts, and would appreciate your suggestions. I found this document explaining the installation of a harness manufactures by Crow Enterprizes (with a "z") that seems interesting. http://www.crowenterprizes.com/Pages/DriverRestraints.htmlIn particular, this one (part number 20114) http://www.parts123.com/parts123/yb.dll?parta~partsort~A2~cadeikca What is the preferred lock, the "latch and link" or "cam lock"? Thoughts, recommendations, suggestions?Thanks for you consideration CarlosCh601-HD, plans No longer a stack of parts [quote][b]
Brad(at)ocbis.com
PostPosted: Mon Jul 30, 2012 8:21 am    Post subject: seat belts Reply with quote
Those are drag racing belts and are required to be extra heavy duty and are replaced every two years. In my opinion, those are way overkill for an airplane. Just the cam-lock buckle itself will weigh more than the typical ‘car’ type system that Zenith puts in the 601 kit. The cam lock is also made for a ‘anti-submarine’ or crotch belt. I would stick with the same kind of belts that are used in commercial airliners or cars.
Thanks - Brad
Brad Rawls
Orange County Brokerage
17782 E. 17th St. #206
Tustin, CA 92780
714-550-0159 voice / 714-550-0869 fax / Brad(at)ocbis.com
From: owner-zenith601-list-server(at)matronics.com [mailto:owner-zenith601-list-server(at)matronics.com] On Behalf Of Carlos Sa
Sent: Saturday, July 28, 2012 4:38 PM
To: zenith-list(at)matronics.com; zenith601-list(at)matronics.com
Subject: seat belts
Hello, all
Carlos
Ch601-HD, plans
 Filesize:  1.6 KB
 Viewed:  2910 Time(s)
